Old 01-18-2011, 07:49 PM   #31
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
Very interesting... I must look into these when I get back to my laptop!
Low594 is offline   Reply With Quote
Old 01-19-2011, 08:22 AM   #32
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,237
Originally Posted by Shov3BR View Post
I think you are correct on the Molex part. Especially with that angled end of the housing. Have a look at this drawing to see if the Center-Center distance is correct and if the pin diameter is .093".
http://www.molex.com/pdm_docs/sd/003092021_sd.pdf
-Shov
I found a description here:
http://www.advrider.com/forums/showthread.php?t=51681
from that thread:
Originally Posted by AussieRob
... These are Molex nylon .093" 2 circuit connectors. I got matching plugs from radioshack Part# 1545PRT. ... Plug wiring was + top (pointy end) - bottom (flat end). ...
I didn't find any proper Molex connectors on RS's website, but that P/N found something on Amazon:
http://www.amazon.com/Molex-1545PRT-.../dp/B0026GLVBI
Should I get one and ensure its the right plug before we proceed?
EDIT: I looked a bit more and I think we have the right connector type; the number given by Rob (1545) shows up on the PDF you linked to and the part I found available via Amazon, so I don't think its necessary for me to buy and try... can we get to ordering? Should I call/email your site since my kit is not an option (yet)?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle screwed with this post 01-19-2011 at 08:54 PM
meat popsicle is offline   Reply With Quote
Old 01-19-2011, 11:01 PM   #33
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Molex
MP - no worries on an "official" order at this point. Let me get the Molex connectors and pins. Digi-Key stocks all of it and we have an account with them. We are going to place a Digi-Key order for some PCBA parts so I'll tack on a few connectors and pins. They should get here next week so I'll make up a kit for you. We'll keep the cost the same as the TAPP Lite since the connector replaces the fuse holder, fuse and ring terminals. I'll let you know when it is complete and you can call in your order since there is no part number on the website.
What pigtail length do you want on the TAPP Lite? Since it is a special you might as well get exactly what you want.
-Shov
Shov3BR is offline   Reply With Quote
Old 01-20-2011, 07:46 PM   #34
meat popsicle
Ignostic
Oddometer: 14,237
-Shov
Thanks in advance for the custom kit!
From the Molex connector up to the dash is only a few inches, and from the dash up to the Ram Surface mounted AquaBox (Medium-Wide on the way) is probably only another few inches, so... one foot should be plenty I would think. If we wanted some margin or error that could be bumped a bit - and I'll measure soon so I can offer you some specific numbers.
Old 01-20-2011, 09:07 PM   #35
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Sounds good. We have a few days until the connectors get here.
Old 01-24-2011, 05:04 PM   #36
meat popsicle
Ignostic
Oddometer: 14,237
I had a look and one foot would probably do it, but we should add a bit for cable curves and a bit of slack so the dash can be raised before disconnecting. I could try 1.5' and give you some feedback on the length.
Old 01-24-2011, 07:41 PM   #37
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Sounds good. The connectors are due in tomorrow or Wednesday. Which pin is + (yellow & blue?) and which is negative (brown). I was thinking about just crimping the pins and letting you poke them into the housing but I might was well have the info in case we make more later on.
Old 01-25-2011, 06:24 AM   #38
meat popsicle
Ignostic
Oddometer: 14,237
Brown is ground, but in my picture its not completely clear which wire is going to which side. The quote I copied above, AussieRob (reliable fella) said positive was on the pointy (top) end, and negative was on the flat (bottom) end.
Should I confirm?
Old 01-25-2011, 09:21 AM   #39
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
Should I confirm?
The colors are correct and I'm 85% sure the brown is on the square end and the yellow is the pointy end or top of the house as I think of it!
Old 01-25-2011, 05:16 PM   #40
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Ta Dah!
Thanks Low594 - I was wondering if I should have left the pins out of the housing and have MP punch them in. I now feel confident that it's correct.
Hey - MP send me a message with your shipping address and we'll get this thing to you.
Old 01-25-2011, 08:45 PM   #41
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
No problem! I'll be in line for one soon, I believe! I just noticed that you are in Silly Cone Valley, too!
Old 01-25-2011, 09:00 PM   #42
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Yup - here in the valley enjoying the great weather. Took my trusty '82 Shovelhead out for spin today. Can't believe I rode that thing every day. It shakes like a bulldog passing peach pits, shifts like it has bubble gum in the linkage and no windshield. I'm getting soft riding my Roadie Still love the sound of a shovel tho. Now you know where I get my kickname.
We'll get a post up here as soon as MP has had a chance to try this out. Stay tuned.
-Shov
Old 01-26-2011, 07:47 AM   #43
the venturer
the venturer's Avatar
Oddometer: 1,420
Looks great. Send me one for a test
the venturer is offline   Reply With Quote
Old 01-27-2011, 07:07 AM   #44
meat popsicle
Ignostic
Oddometer: 14,237
-Shov
Just an FYI to everyone: I'll be gone all weekend (F-Sun) so it'll be next week before I can get to this.
But since this showed up I am anxious to get at it!
Old 01-27-2011, 07:52 AM   #45
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Your TAPP Lite should arrive today so you will be able to at least have all the parts together. Have a good weekend. Hope it's a riding one.
Times are GMT -7.   It's 04:21 AM.
