Old 02-23-2011, 11:09 AM   #76
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
Agreed. That's what I would do if it was my computer and I was headed down the road for an extended period. One of the chargers online looked pretty compact it had good reviews. Better safe than sorry.
Meanwhile if anyone has more info it would be interesting to know what works and what causes smoke to escape from those little chips.
-Don B
Shov3BR is offline   Reply With Quote
Old 02-27-2011, 01:02 PM   #77
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
Hydra-TAPP
Originally Posted by JohnBryer View Post
it'll be inside a tank bag. 6-8 inches would be plenty. SAE on 1 end, and 2-3 USB ports on the other side to charge phone, GoPro, or most any other device would be awesome.
John - we made a couple of attempts to get something that looked decent but can't get there with shrink tube. If there is enough demand we would have to go to our cable supplier and have the junction molded for a saleable product.
Here's the prototype. As you can see it is butt ugly. One thing we did was add both the male and female SAE 2-pin connectors so power was still available for other applications. Even with three TAPPs we are drawing less than 2A so there's plenty left on a 15A circuit.
Old 02-27-2011, 01:12 PM   #78
JohnBryer
Adventure Poser
JohnBryer's Avatar
Oddometer: 935
I have a question and a comment....
Why do you have 2 SAE's?
I assumed the USB's would be stacked kinda like a typical USB hub. They're going to be inside a fairly waterproof container, so they don't really need the waterproof housing.
2005 R1200 GS
2004 R1150 RT
JohnBryer is offline   Reply With Quote
Old 02-27-2011, 01:37 PM   #79
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
The two SAE connectors, one male and one female allow you to still have a SAE power port even with the Hydra plugged in, i.e. it is a splitter. TAPP uses so little power it's a waste to have the SAE plug totally used with it.
With this arrangement you plug in the TAPP and still have an SAE available to plug in other stuff.
We are working on another Hydra idea that would have just the USB sockets split off of one high power regulator. We can't do it with TAPP Lite since it only supplies 1A total. That would be too limiting split three ways.
Old 03-16-2011, 05:20 AM   #80
Turbo Bob
Oddometer: 3
Any more news on updated connections i.e. sae to usb? Could you make an sae to usb with a very short lead I don't even need tap lite as I wouldn't use it in the rain as my unit is not waterproof?
Turbo Bob is offline   Reply With Quote
Old 03-16-2011, 08:22 AM   #81
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
SAE to USB
You can't go directly from SAE to USB due to the voltage difference. USB is 5VDC so you need a voltage regulator to get from 12VDC down to 5VDC. That's what the TAPP Lite does.
Old 03-16-2011, 08:47 AM   #82
Turbo Bob
Oddometer: 3
I thought that might be the case. What about your work on the sae to Tapp Lite, how is that going or could you just make up an sae to Tapp Lite with short lead as I saw you posted before. I just need to go from an sae plug I have near the bars and then a short way with a usb pigtail to operate my Garmin.
Old 03-16-2011, 09:55 AM   #83
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
SAE to TAPP Lite
Sure, that's no problem. Would you still use the Universal Mount to attach the TAPP Lite?
The SAE should be on a fused circuit -do you know what the fuse rating is? We use a 7.5A fuse but the TAPP Lite cable will handle up to 15A. The TAPP Lite itself is internally protected with a auto-resetting fuse so it is safe no matter what. The in-line fuse just protects the cable.
Also, what Garmin are you using. If it is a Nuvi then you will need our Garmin Charging Cable. It is the only cable available that will allow the Nuvi to charge and navigate. More info here:
http://www.advrider.com/forums/showthread.php?t=666156
Let us know how you want to attach and the pigtail length and we'll put something together for you.
Old 03-16-2011, 10:31 AM   #84
Turbo Bob
Oddometer: 3
Yes it has 7.5a fuse, it is a Nuvi a 9" charging cable would be fine and the sae to Tapp Lite could be 6" overall. I don't need a mount just the cables.
Let me know a price.
Thanks,
Bob
Old 03-16-2011, 10:57 AM   #85
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
We can use the TAPP Lite w/o bracket price since the SAE 2-pin connector cost will balance out against the fuse holder and fuse. We normally tack on $5.00 for specials but won't in this case. So the total looks like this:
TAPP Lite w/o bracket PN 150-0048-01 $29.95
Cable, USB, Garmin Charging, USB A - USB Mini RA UP, 9" PN 202-0033-09 $12.95
Shipping, domestic $4.50
Plus sales tax if you live in CA
If you want to go head with the order you will need to call it in since the 150-0048-01 is not on the website
408-725-8010
Old 05-01-2011, 08:05 PM   #86
DingDangKid
El Lechero
DingDangKid's Avatar
Oddometer: 2,558
Any more info on this guy?
2006 Tdub
2006 Wee
DingDangKid is online now   Reply With Quote
Old 05-01-2011, 10:24 PM   #87
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 288
Thanks for the segue It just went to the webmaster on Friday. She was going to try to get it on the webpage over the weekend but I see it didn't get there yet.
Old 05-15-2011, 10:39 PM   #88
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 239
iPad Power
Hi,
I'm certainly happy this is available . . . TAPP™ LITE
USB POWER PORT
with DIN 4165 Plug (BMW).
Is there any update on the iPad-compatible USB adapter. SAE, Powerlet, whatever . . .
Thanks,
Kurt
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good." 4 bikes in 3 countries.
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Old 09-21-2011, 06:15 AM   #89
RamMan4x4
RamMan4x4's Avatar
Oddometer: 224
bump for same day shipping and great customer service
08 Suzuki DR 650SE
99 Suzuki DR 350SE
07 Buell XB12X
RamMan4x4 is online now   Reply With Quote
Old 09-28-2011, 12:05 PM   #90
RamMan4x4
RamMan4x4's Avatar
Oddometer: 224
Finally got around to installing it this weekend...works great!
08 Suzuki DR 650SE
99 Suzuki DR 350SE
07 Buell XB12X
Times are GMT -7.   It's 07:29 AM.
