Old 02-26-2012, 12:08 AM   #121
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 282
Multi-USB
Originally Posted by regnock View Post
These products look great! I'm looking for a solution that would connect to my Centech fuse box and power 3 usb devices. A iPhone, GoPro HD Hero 2 and Chatterbox X1 slim. Could you build this? If so how much?
Hmmm... got to think about this one a bit.
Our new TAPP 2.1A USB power port will handle the load but making the connections would require a USB hub of some sort. We usually don't recommend using a hub for two reasons: 1st, many users don't calculate their power budget correctly (or at all) so they don't know if their power load falls within the 2.1A max. Secondly, a hub can't be made weatherproof without a lot of ugliness.
We made a couple of our TAPP+ high output USB ports into what we called TAPP Hydra. Rather than having a single USB socket we pulled three USB pigtail out of the case opening. The socket end of the pigtails was just the right size to mate with a TAPP CAPP to create a weatherproof seal. This configuration didn't draw much interest so we never made a production run. I'll look to see if we have any more PCBAs left. If so, would you be interested in trying one out? We should have some pics somewhere. If I can find one I'll post it.
-Shov
Shov3BR is offline   Reply With Quote
Old 02-26-2012, 07:58 AM   #122
regnock
Oddometer: 96
Sure I'd give it a try. Let me know. Thanks.
Past, Present and Future Ride Reports:
http://thecongers.org/
regnock is offline   Reply With Quote
Old 02-26-2012, 11:02 PM   #123
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
What I was planning to do for myself in this situation was to buy a few USB extension cables. Hack them up and splice back together in the length I needed. With some heatshrink tubing and your waterproofing caps, they would be quite water resistant. And for my intended use, it and the components being powered would be removed to a waterproof bag or in my jacket.
Is there a date of availability on the 2.1A? Do you have a price set for it?
I'm thinking, since I have yet to install the 1A, maybe I should upgrade to the 2.1A.
Low594 screwed with this post 02-26-2012 at 11:10 PM
Low594 is offline   Reply With Quote
Old 02-27-2012, 12:13 AM   #124
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 282
That would work. Just be careful of your power budget. An Android phone will pull 1.2A if it is available. TAPP will actually output 2.75A if derated to 40C. Our normal spec ratings for USB power ports is 50C.
We found some USB extension pigtails that had a socket end that was just about a perfect fit for TAPP CAPPs. I'll have a look to see if I can find it again. Our cable supplier said they can make them whatever size we want but minimum order is 1,000 cables so we have to be sure we have a market for them.
TAPP will be priced at $44.95 for both the Universal Mount and Panel Mount. They will be available in early April if we get the two long lead PCBA components that are holding up the parade right now. The tooling for the overmold is finished and we have 25 of each of the two versions that were run on that production tooling. We are quite pleased with the results. We'll get some pics and specs on line soon.
Cheers - Shov
Old 03-16-2012, 08:43 PM   #125
regnock
Oddometer: 96
-Shov
Just wondering if you were still looking into this? Thanks for any help.
Old 03-17-2012, 11:44 AM   #126
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 282
Sorry for the tardy response. I've been working night and day getting our KTM 990 ready for a big ride from London to Magadan.
I did find some bare PCBs with the holes for three USB pigtails but no stuffed ones. It will probably be more expedient to try Low594's idea of doing it with cables. We'll order some extension cables that can be cut up for the assembly
BTW - we are on schedule for early April shipping of the TAPP 2.1A USB power ports in both panel mount and universal mount versions. Pics, specs and descriptions to be available soon!
Old 05-31-2012, 05:44 PM   #127
Lisha
Oddometer: 1
SAE to USB
Have you seen this new thing that's about the size of a cigarette lighter with an SAE connector on one end that goes on your charging cable and has a USB on the other end?
It's on AmericanCrossroaders.com
Lisha is offline   Reply With Quote
Old 06-01-2012, 03:00 AM   #128
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Your title "noob", is accurate! Did you make this account just to spam someone elses thread with your own product?
Old 06-01-2012, 03:13 AM   #129
genghis9021
Arak Connoisseur
genghis9021's Avatar
Oddometer: 239
You're so . . . suspicious.
Li Sha ? AmericanCrossroaders (only a non-native speaker of English could contrive such a name).
2011 Husky TE 630 2011 Husaberg FE 570S
2006 KTM 950 'S' ADV 2005 Suzuki DRZ 400 SM
"The perfect is the enemy of the good." 4 bikes in 3 countries.
Orange, it's the new black Tour.
genghis9021 is offline   Reply With Quote
Old 06-01-2012, 11:55 PM   #130
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,206
Thanks for the replacement TAPP-capped connector cable Don - its working like a charm, & I think we finally confirmed that gremlin. I'll keep an eye on it to see if the original was just a dud or if the installation caused the failure.
KTM LC4 vibes + AquaBox wire routing or my thru-dash wire routing may be at fault...
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 06-03-2012, 05:04 AM   #131
mikeb53
Oddometer: 10
Spam or not, the thing is legit. Got one and it works great.
mikeb53 is offline   Reply With Quote
Old 06-03-2012, 11:56 PM   #132
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Thats fine, its still inappropriate to spam someones elses legit thread!
Old 06-03-2012, 11:58 PM   #133
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
Originally Posted by low594 View Post
thats fine, its still inappropriate to spam someones elses legit thread!
+1
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 06-04-2012, 03:15 AM   #134
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 282
SAE to USB
Thanks for the support guys.
We looked at the device and it has some nice features but suffers the same disadvantage as most other USB power ports - no weather protection when a cable is plugged in. In fact it has no weather protection at all that we can see. Also, no mounting bracket.
That doesn't mean it doesn't have it's place. Just keep it out of the rain and other mud/water situations.
As some of you know I'm on a ride from London to Magadan and it rained for the first twelve days straight! Needless to say I was happy that my Spot tracker and video camera were plugged into weatherproof USB connections.
If you are wondering how I'm powering the Spot from USB have a look at the Spot thread where you will see my mods to convert from battery to USB.
Cheers,
Don (Shov)
Old 06-04-2012, 09:31 AM   #135
KCDakar
What are we waiting for?
KCDakar's Avatar
Oddometer: 3,388
Cheers,
Don (Shov)
So please tell us, will you be making more of these for sale? I have the older spot and would LOVE to have this setup for both my Spot and my POV camera.
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay
Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6
KCDakar is offline   Reply With Quote
Times are GMT -7.   It's 07:02 AM.
