Old 09-27-2013, 12:38 AM   #1
shawy39 OP
Oddometer: 1
yz400f
Hi I have recently bought a 99 yz400f with only a little compression,
I have read a few forums which intercate that it is a common fault for the valves to stick open so I wipped it all of pisten is fine done a pressure test and yep 2 valves were slightly open so got them re seated and cleaned up what I need to no now is what are the torque setting for the head? any help would be great.
chris
shawy39 is offline   Reply With Quote
Old 09-27-2013, 12:44 AM   #2
DakotaRon
DakotaRon's Avatar
Oddometer: 13
Torque Values
Be sure and apply moly lube to the bolt threads and washers before you torque the head. Then torque to 34 ft/lbs using a criss cross pattern sequence. I am glad you found it an easy fix. Happy Roosting!
DakotaRon is offline   Reply With Quote
Old 09-27-2013, 05:21 AM   #3
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,290
I've got the 99 WR400F, what a hoot. All it's lacking is a tag!
PineyMountainRacing is online now   Reply With Quote
Old 09-27-2013, 09:37 AM   #4
dougfromindy
I smell premix
dougfromindy's Avatar
Oddometer: 2,304
yee haww it rocks
great trail bike with big power
my spark plug blew out, no more threads, just fixed it
i got lighting, baja designs 180w ext stator set up
dougfromindy is offline   Reply With Quote
Times are GMT -7.   It's 05:09 AM.
