Old 11-11-2010, 07:11 PM   #46
Olas
the darkness
Olas's Avatar
Oddometer: 3,583
Wow. Thank you for sharing this!
FS: Street Legal American Trail Killer!!
Rebuild threads:
'92 XT600
, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 11-11-2010, 09:33 PM   #47
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 5,980
Great Thread, Awesome Project, but where is that Rigid light picture you promised?
Old 11-12-2010, 06:31 AM   #48
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,864
I forgot the camera on the ride.
I'll head out tonight. Should be overcast and dark tonight.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-12-2010, 06:49 AM   #49
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,864
I start with a fixture plate mounted in the CNC.
Pick up the center of the plate w/ a Dial Indicator to find a zero point. I use CAD to draw up a bolt pattern to use toe clamps to hold the frame down. The ADV frames weigh about 24lb, and I can only hold onto the head. My machine is not large enough to secure the entire frame inside the machine. Fingers crossed......hope this works.
The bearings (top and bottom) are 2 differant sizes on the ADV, so I turned a couple adaptors that I can swap out when I flip the frame over. These adaptors fit into the base plate and locate the head tube so it won't move when cutting it.
Old 11-12-2010, 07:31 AM   #50
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,864
After I'm sure the frame is stable enough to take a light cut, I start to align the frame better. I remove the frame and pick up my bottom locator adaptor. That is my Zero point for the cut. Install the frame again and start to install clamps...... doing this by my self, I should build a ROBOT helper as I've run out of hands so many times.
With the bottom zero point established, I need to get the top bearing journal aligned to make the cut straight and not change the head angle. I indicate the front of the frame to make sure it is perpendicular.
And tram the bearing race to confirm I have the frame as perfect as I can get it forward and back, and left to right. I was with in .005-.010", and that could have been an out of roundness condition of the race, pressed into the tube. I feel that's good enough for this application. (That's about 2-3x the thickness of a human hair)
I made some small adjuster screws that could be tweaked against the frame to get the frame in alignment. Tedious process, but now is not the time to cut corners.
So now that I feel happy about holding onto the frame, how do you go about cutting it....??
The frame is almost 9" long and I haven't purchased the LASER cutting attachment yet.
I measure the Outside Diameter (OD) of the new Christini Head Tube. I find a BI-Metal Hole saw that has almost the same OD.
But anyone that has used a hole saw knows that it works off a pilot hole that is drilled into the material. I don't have that.
As I take a break and look out the window, I see I have some spys trying to see what's up.
cjracer screwed with this post 11-12-2010 at 07:36 AM
Old 11-12-2010, 07:45 AM   #51
dozer
dozer's Avatar
Oddometer: 336
dozer is offline   Reply With Quote
Old 11-12-2010, 08:02 AM   #52
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,744
Send a message via Skype™ to Flanny
Cool dude. Keep it coming!
Flanny is offline   Reply With Quote
Old 11-12-2010, 09:46 AM   #53
VertigoCycles
Oddometer: 113
this is an INCREDIBLY interesting thread, thanks for sharing.
I know it's far too late for this project, but anyone who needs a fairly rigid method of putting an arbor on a hole saw for use in a mill would do well to look here: http://www.paragonmachineworks.com/s...pt-261336.aspx Probably cheaper than making your own.
Sean Chaney
Vertigo Cycles
Flickr
VertigoCycles is offline   Reply With Quote
Old 11-12-2010, 10:09 AM   #54
Yellow Pig
Yellow Pig's Avatar
Oddometer: 5,980
This is better than porn!
Old 11-12-2010, 03:51 PM   #55
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,387
Starrett "Oops" hole saw arbor?
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 11-12-2010, 05:01 PM   #56
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 4,396
Great stuff for us MechGeeks! Can't wait for the next installment...
cyborg is offline   Reply With Quote
Old 11-12-2010, 09:44 PM   #57
Questor
More Undestructable
Questor's Avatar
Oddometer: 3,546
Very hooked...
MOAR!
Q~
Old 11-12-2010, 10:27 PM   #58
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,864
Thanks for the link. Might be handy in the future....
BTW, how much would a TI 950 AWD ADV frame run? Cool site.
Old 11-12-2010, 10:38 PM   #59
cjracer OP
AWD please!!
cjracer's Avatar
Oddometer: 3,864
Yes, I did figure something out. The 1/4' drive that comes in the holes saw kits wasn't going to be rigid enough for this application. I also wanted something that would handle the pounding and vibrations an interrupted cut would produce.
The standard arbors I had found only had a jam nut, nothing to stop the hole saw from spinning if it got stuck or wedged while in the cut. There is a lot of surface area on this one. Looks like I'll need to make my own.
I found a chunk of round stock and got to work on the lathe. Then into the mill. Just enough room on the side of the frame setup to widdle this out.
It have 2 dowel pins that keep the hole saw from spinning and a small set screw give me a low profile inside. This would give me the longest depth of cut before the inside of the saw crashed into anything on it's way down.
1" shank to fit in my BT40 tool holder.
And now I have a rigid tool that's ready for some work.
On the left is the wimpy setup that's used in a Hand drill.
On the right is the new "Uber" Cutter. This is a large Hole Saw.
cjracer screwed with this post 11-12-2010 at 10:43 PM
Old 11-12-2010, 11:32 PM   #60
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,551
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2 mk3 auto, 1999 Intruder 1500, 05 Ruckus, 90 DRBIG 800, 79 GS850My last location and updates-Ride Reports
FINNDIAN is offline   Reply With Quote
Times are GMT -7.   It's 02:13 AM.
