11-13-2010, 03:31 AM
#61 |
WWC Founding Member
Oddometer: 4,873
#! We're not here for a long time, we're here for a good time.
11-13-2010, 10:43 AM
#62 | |
Oddometer: 113
I'm up for making a Ti 950 AWD ADV frame. Wanna find out how much it costs? I'll leave all the machining of the brackets & fittings to the guy with the big tools. My 1950's Index manual vertical mill doesn't care much for 6/4 ti.Nice Arbor by the way. Can't wait to see the rest of this. |
11-13-2010, 03:52 PM
#63 |
AWD please!!
Oddometer: 3,866
Now that I have a cutter, I need to do some final prep on the fixturing.
You can see here that the bolt and nut are sticking up a little above the top of the head tube. ![]() I need to cut as deep as possible to get through the frame tubes clean. I milled off the stud and nut. I sure hope this works.... Safety glasses on, this job might need a helmet... Final program test before reloading and indicating again. I forgot to get some measurement off the frame that I would need for later, so I had to unclamp the frame, then refixture it. Once it's cut off, no turning back. ![]() ![]() And action. http:// Nice and clean cut. Slow and steady worked out great, to my relief.
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! cjracer screwed with this post 11-13-2010 at 04:06 PM |
11-13-2010, 04:26 PM
#64 |
AWD please!!
Oddometer: 3,866
I had just enough cutter length on the hole saw to get a clean cut completely through the frame tube.
Now I worked on removing the frame and getting setup to cut the opposite side. ![]() I made the base plate so that I can swap on an adaptor bushing to locate the flip side. With two less frame tubes holding the head tube on I needed to rethink how I was going to stabilize the frame. I started to bolt it back down through the head tube. ![]() A few more jack screws along the top frame rails. ![]() Indicate it back in like the other side. Looked plenty stable to me, let's give it a go. http://
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
11-13-2010, 04:34 PM
#65 |
AWD please!!
Oddometer: 3,866
But that's not all.....
The 950 ADV frames have 6 tubes going into the head tube. I now have 4 cut free with 2 more to go. Now's time to get the Sawzall out to start on the center tubes. Those are less critical because I've now recreated the headtube angle w/ the 1st and 2nd cuts in the CNC. This proved to be more time consuming than I thought. I didn't have a great way to keep the frame from moving around the shop. Where is that ROBOT???? In about 2 days time I destroyed a perfectly good KTM 950 ADV frame. ![]() Looks like progress to me, horror to anyone that stopped into the shop over those days. Next step is to get this to fit. ![]() ![]() Looks like more grinding and cutting.
11-13-2010, 05:48 PM
#66 |
Skiing, not riding.
Oddometer: 5,025
Hmmm...
Thinking I couldn't duplicate this with my $99 Home Depot drill press.
950 Adventure ✧ 950 Super Enduro ✧ 450 XC-W Six Days |
11-13-2010, 06:08 PM
#67 | |
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 1,562
When you get done - YOU get to try it first.
'10 Husaberg FE570 '10 BMW R1200GSA "30th anniversary edition" '08 KTM 950SE-R '08 Ducati Hypermotard 1100S |
11-14-2010, 09:45 PM
#68 |
Zoom
Oddometer: 23
A big thanks
Really enjoy reading this build.
Keep it up.
11-14-2010, 11:33 PM
#69 |
Hmmmm, dirt!
Oddometer: 892
A New tube?
That's something impossible over here, that would require replating the bike, a very expensive procedure with complete tech test (need drawings of the frame and calculations of it) Can you just reprint the numbers on your tube without trouble?
950 Rally custom - 690 Enduro Ride ON! |
11-15-2010, 07:15 AM
#70 | |
AWD please!!
Oddometer: 3,866
Honestly, that was the least of my worries. We'll get to that later.....
11-15-2010, 07:35 AM
#71 |
Fast and Far
Oddometer: 6,828
www.GravelTravel.ca Canadas Source For Overland Routes Tales From The Bivouac Rally Print Publications TCAT Trans Canadian Adventure Trail 15, 000 km GPS route across Canada |
11-15-2010, 08:01 AM
#72 |
Oddometer: 10,901
Awesome project! I'm not a fan of AWD on a light MX-based bike, but it'd be just perfect on a heavy adv bike imho. Impressed with your building skills. I'm actually a bit astounded that BMW nor KTM have seen fit to offer an AWD option. Even if you only put 10% of the power to the front wheel it might help quite a lot in mud and such.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
11-15-2010, 08:36 AM
#73 |
Oddometer: 1,022
Best. Thread. Ever.
KTM 500 XCW |
11-15-2010, 08:42 AM
#74 | |
Oddometer: 113
(I'm used to "thin" tubing {0.035} and even with the use of heat sinks there's enough distortion to make post-weld machining necessary) |
11-15-2010, 08:59 AM
#75 | |
AWD please!!
Oddometer: 3,866
