12-03-2010, 06:59 AM
#46 | |
Mr. Resistor
Oddometer: 12
ADV version
That's a great idea....Again, these decisions are ultimately in the hands of Aerostich, but they cater to the ADV rider and should understand where this is going. Bottom line for them is justifying the quantity sold against inventory costs and that plays into it on our side as well. As far as custom configurations, it's no problem from a software standpoint. Hardware mods outside of wire can be a little more challenging. Steve |
12-03-2010, 08:43 AM
#47 | |
The Road Scholar
I would also prefer if the two modules communicated via a wired plug that also supplied power for backlighting the display on the control unit. As it is, the control unit needs to be opened up repeatedly with six screws to replace the double-AA batteries. Not the best design. Garmin manages to have a totally watertight mini-USB plug on their GPS units. They could have used a similar port to connect the two devices and probably reduced complexity, cost, size of the controller (no battery compartment); AND increased reliability (no wireless linking/interference issues), as well as made the controller fully waterproof due to no need for user access inside of it. IMHO, the build quality of the distribution box is questionable as well. To my eyes, it looks like someone took an off-the-shelf project box and cut it out for the various I/O ports/wires. It isn't sealed at ALL. And what is up with the "optional" waterproof roll-top bag as a stop-gap way to keep water out of the distribution module??? First of all, it is a hokey way to address the issue, and will probably be compromised due to vibrations/rubbing in short order. Second, Even the area under the seat can get wet pretty easily in a good rain, if the distribution module is not sealed against water intrusion that bag should be part of the standard package! I can sorta understand using the barrel connectors for the heated gear switched circuits, although they really should be pigtails to extend outside of the roll-top bag so that they can be disconnected easily when not in use. But for the other two generic switched circuits, barrel connectors make no sense at all. You want something that will be a permanent connection. The whole thing just seems like it needed a looking over by a design engineer who actually rides. It seems like it was designed by a software guy... ![]() ![]() And that is just what I can see from a quick look at their website... ![]() Otherwise I can see where it could be an interesting product... But that is just my opinion...
Karl Kugler www.theroadscholar.net 2005 BMW R1200RT w/Hannigan-LT sidecar 2002 BMW R1150RA In Memoriam: Harley, 1993-2010 You will be missed. |
12-03-2010, 09:11 AM
#48 | |
The Road Scholar
![]() I have been adding fuse blocks to my bikes for years, and am always looking for the next, best, thing. ![]() This is the re-wiring that I did for out_rider's sidecar rig this summer. I am showing off the job we did on his rig because it turned out nicer than what I did for my own sidecar, but used the same fuseblock. ![]() We both have a Hannigan sidecar with dual Piaa headlamps switched thru relays to operate as separate Hi/Lo beams, as well as a high-draw servo-screw motor to adjust leanout, a Can-BUS trailer-light wiring relay package, and some other accessory circuits. I think that your module would clean things up nicely, and potentially eliminate at least some of the relays depending upon how it can be set up. ----- One suggestion that I have is to perhaps include longer pigtails for the wires. Or offer a long-wire plug as an option? It would reduce/eliminate splices in the wiring harnesses, which are always a weakness and source of trouble. Another would be if you could offer one low-amperage circuit that was always-ON for those of us who do long-distance riding and like to keep our GPS running to maintain our trip-log timers. And, of course, there are always those of us who need MORE... As you can see, I already have an extra external fuse added to out_rider's six circuit panel. Are there any plans for the 8/10/12 circuit model???
12-08-2010, 01:02 AM
#49 |
Nearly Adventurer
Oddometer: 624
FYI PDM60 Sale Price
Just got an email flyer from aerostich showing the PDM60 to be on sale for a few days for $98.10
I think that they are also shipping to CONUS for a flat $5
Courtney in Seattle '04 Moto Guzzi California EV Touring '04 Moto Guzzi V11 Sport Ballabio |
12-08-2010, 02:48 AM
#50 | |
Oddometer: 1,027
Wow - great deal
I've been thinking and planning for a while now and am convinced this is the right choice for me. One holdback was my new Stebel Nautilus mega-loud horn. It comes with a 20 amp fuse and the PDM60 individual circuit max is 15 amps. I wired up the Stebel on my workbench feeding through a 15 amp mini fuse and could blast away with no problems. I'll try again with a bona-fide amp meter next (need to buy one first - my current multi-meter only measures AC current).
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 |
12-08-2010, 05:45 AM
#51 | |
Oddometer: 791
Radar detector and GPS are running off the bike's aux circuit (7A capability,) and I have enough juice left over to run LED driving lights. Heated gear and SAE connector run straight to the battery, no switching needed. |
12-08-2010, 07:13 AM
#52 | |
Oddometer: 1,027
Need???
I can handle much of what I want to do on my GS with a) direct battery connection and b) use of the BMW unused "aux" header connector tied to ignition. This would require me to have four direct battery connections beyond the bike harness: 1) heated gear, 2) battery tender, 3) Clearwater Krista LED light controller, 4) Stebel horn. My iPhone, LED handguard lights and future Zumo could be run off the BMW aux connector. I don't like the stack of direct battery connections, but the cheapest way to handle this is with the Powerlet "Termin-8" ![]() The PDM60 is a more sophisticated solution that will give me a cleaner wiring setup and future expansion capability. I may add more LED aux lights, radar detector, passenger heat in the future. These are clearly "wants", not "needs". So - I have no good argument, but I still want one...
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 John Smallberries screwed with this post 12-08-2010 at 07:24 AM |
12-08-2010, 09:52 AM
#53 | |
Nearly Adventurer
Oddometer: 624
YOU need this accessory!
After buying the Dorsoduro this summer my CFO put me on supervision. So now I am just an instigator/enabler living vicariously off of other people's farkles.
12-08-2010, 10:02 AM
#54 |
Oddometer: 1,093
12-08-2010, 12:18 PM
#55 | |
So... how exactly would I install this on my 1200RT? I know I need to get into the ignition, but where and how? Or do I just take this to the dealer and have them do it? I had a fuse block on my GSA (may it rest in peace) and I'm trying to get all my goodies back. At some point, I need aux lighting, an Autocom and a charging wire to a handheld ham radio. I already have my Gerbing plug wired direct but would not rule out running it through this thing. I may also add a GPS. cliffy109 screwed with this post 12-08-2010 at 12:31 PM |
12-08-2010, 12:31 PM
#56 |
Oddometer: 1,027
Install
We are all waiting for Guru-Steve to post some install photos. Looking at the diagrams, all seems simple enough. Two leads directly to the battery for power and ground. One lead spliced into an ignition-controlled circuit. (On my GS I plan to use the diagnostic plug as it will be close by.). An option is an additional lead to a separate switch for control independent of ignition. After that, power leads to each gadget. You can chose to ground each to the frame or run a dedicated ground lead back. I believe the electrical engineers in the crowd would recommend the dedicated grounds, but the under-seat wire bundle will be bulkier. Throw in a bunch of Posi-Lok taps and splices and you have a plan.
'05 BMW 1200GS '09 Honda CRF230 '10 Yamaha TW200 John Smallberries screwed with this post 12-08-2010 at 01:01 PM |
12-08-2010, 04:25 PM
#57 |
Politicians suck
Oddometer: 711
A question for Mr. Rowe,
Is there a need for a diode on the trigger wire for isolation? ![]() Very cool indeed to have the Inventor's input here, thanks!
2005 BMW F650GS-DAKAR 2008 BMW R1200RT |
12-09-2010, 06:00 PM
#58 | |
Mr. Resistor
Oddometer: 12
PDM Answers
The pigtails can be any length you desire. The original version actually had a complete harness on it, overbraided, with leads for rear, center and steering head. The steering head lead had a connector so that the user could install it once and then make changes at will without disassembling the bike....That variant went the way of the dollar sign, but there are virtually no limits on what you can have for pigtails. An "always on" circuit can be done...It's simply a matter of programming the unit to do so. There are plans for larger units, two of them with more circuits and more AMP capacity. Both will be available some time mid 2011. The PDM60 is at the limit for its size, so you can expect about half again as long as the 60 for half again the capacity and circuits. This is in response to other markets since size definitely does matter on bikes. If you have the room we can accomodate your needs. |
12-09-2010, 06:08 PM
#59 | |
Mr. Resistor
Oddometer: 12
Hook up your Nautilus and blast away! The horn is intermittent and the PDM60 should have plenty of capacity on a 15 AMP circuit. The worst that can happen is the module will shut the circuit down and indicate a fault and I highly doubt it will happen. |
12-09-2010, 06:12 PM
#60 | |
Mr. Resistor
Oddometer: 12
