Old 11-18-2010, 08:00 PM   #1
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Hotrodding the GS
For all Fuel Injection technical questions and conversation, you are in the right place!
To place an order go to: The IICE Air Vendors Thread.
To see the Customer Order List go to: Build and Shipping Schedule.
___________________________________________
What the heck is an IICE Air and IICE Cool?
I've been working on a series of enhancements to make the fuel injected BMW motors run smoother and better. It's the first of a series of hot rod products and mods that I've been developing, for quite some time now.
For the first device, I figured out a mod that will work under all operating conditions, will work for every rider, and it's user adjustable.
For the past 25 years I've worked as a designer of Industrial and Automotive electronics. I know what it takes to make a motor run properly, and I know what must be changed for the motor to pass EPA.
Because of my understanding of combustion, and experience with the firmware algorithms that EFI systems use to operate, I know how to optimize and tailor the various inputs or sensors to the EFI to make the boxer motor run better, to make them run the way they are supposed to.
When I first rode the bike in stock, electronically unmodified form, it was apparent what should be done to make it run correctly. There were 3 choices, remove the Motronic ECU and start from scratch, replace it with an aftermarket EFI system, or achieve 80-90% of the needed changes using only external modifications.
These external improvements to the EFI are designed as a series of individual devices that work together to produce the desired results. They are added one at a time to enable the engine to run smoothly and with authority.
Because of our common desire to make the boxer motor run really well, John (johnjen) and I have worked together to figure out how we can offer these hot rod part enhancements to the rest of the GS community.
This thread is meant to examine the specific features of these devices, and their development.
The IICE Air is available for purchase in the Vendors forum:
http://www.advrider.com/forums/showthread.php?t=667661
- Jim
TABLE OF CONTENTS - Links to informative posts
TESTIMONIALS
http://www.advrider.com/forums/showt...7#post18263447
http://www.advrider.com/forums/showt...9#post18255709
http://www.advrider.com/forums/showt...6#post18256286
http://www.advrider.com/forums/showt...7#post18256797
http://www.advrider.com/forums/showt...0#post16326520
http://www.advrider.com/forums/showt...9#post16327069
http://www.advrider.com/forums/showt...3#post16818263
http://www.advrider.com/forums/showt...0#post16988700
http://www.advrider.com/forums/showt...7#post16960167
http://www.advrider.com/forums/showt...9#post16928799
http://www.advrider.com/forums/showt...9#post17176299
http://www.advrider.com/forums/showt...9#post17193219
http://www.advrider.com/forums/showt...8#post17198538
http://www.advrider.com/forums/showt...2#post17200622
http://www.advrider.com/forums/showt...6#post17200716
http://www.advrider.com/forums/showt...2#post17265572
http://www.advrider.com/forums/showt...8#post17266028
http://www.advrider.com/forums/showt...3#post17267063
http://www.advrider.com/forums/showt...4#post17323524
http://www.advrider.com/forums/showt...7#post17434047
http://www.advrider.com/forums/showt...8#post17436418
http://www.advrider.com/forums/showt...6#post17446156
http://www.advrider.com/forums/showt...3#post17495773
http://www.advrider.com/forums/showt...3#post18050033
http://www.advrider.com/forums/showt...0#post17739830
http://www.advrider.com/forums/showt...9#post18176949
http://www.advrider.com/forums/showt...9#post19227919 10,000 Mile Report
http://www.advrider.com/forums/showt...3#post19138173K Bike Report K1200
http://www.advrider.com/forums/showt...8#post19301158
04-15-2013 http://www.advrider.com/forums/showt...9#post21194469
04-21-2013 http://www.advrider.com/forums/showt...4#post21238924
04-22-2013 http://www.advrider.com/forums/showt...7#post21246827
04-24-2013 http://www.advrider.com/forums/showt...8#post21255528
04-30-2013 http://www.advrider.com/forums/showt...2#post21302332
04-30-2013 http://www.advrider.com/forums/showt...5#post21303575
04-30-2013 http://www.advrider.com/forums/showt...2#post21305322
How does Fuel Injection work? - Recommended reading!
http://www.advrider.com/forums/showt...7#post14632057
How do the IICE Air and IICE Cool products work?
How do they make my motor run better?
http://www.advrider.com/forums/showt...3#post14649263
http://www.advrider.com/forums/showt...4#post17413094
http://www.advrider.com/forums/showt...6#post15425676
Specifically, what the IICE Air does:
http://www.advrider.com/forums/showpost.php?p=15404359
What do the temperature offsets mean?
http://www.advrider.com/forums/showpost.php?p=15436575
How easy are they to install?
http://www.advrider.com/forums/showpost.php?p=14696928
Installation of IICE Air on R1100/R1150 (Thanks to kandersn)
http://www.advrider.com/forums/showt...0#post18272500
Installation of IICE Air on R1200 (Thanks to Geoffster and bracky72 and Wallowa)
http://www.advrider.com/forums/showt...4#post16317774
http://www.advrider.com/forums/showt...6#post18401396
http://www.advrider.com/forums/showt...9#post18483559
Installation of IICE Air on F650/F800 Twins (Thanks to DidYouSeeThat)
http://www.advrider.com/forums/showt...1#post17433341
http://www.advrider.com/forums/showt...2#post17433382
Adjust the IICE Air jumper settings:
http://www.advrider.com/forums/showt...7#post16533527
http://www.advrider.com/forums/showt...6#post15467636
http://www.advrider.com/forums/showt...7#post15467657
http://www.advrider.com/forums/showt...3#post14710763
http://www.advrider.com/forums/showt...9#post17439519
The IICE Air works by itself, and in combination with future products:
http://www.advrider.com/forums/showt...3#post14688703
How do the IICE Air and IICE Cool and future products work together?
http://www.advrider.com/forums/showt...6#post15418006
Do I need to have an IICE Air installed in order use the upcoming IICE Cool?
http://www.advrider.com/forums/showt...0#post17736870
I already have a Booster Plug or similar product, what do I do?
http://www.advrider.com/forums/showpost.php?p=15429156
http://www.advrider.com/forums/showpost.php?p=15462270
Comparison between IICE Air and Booster Plug, Accelerator, etc.:
http://www.advrider.com/forums/showp...postcount=1552
Does the location of the sensor make a difference?
http://www.advrider.com/forums/showpost.php?p=15438749
Here's what BoosterPlug says about sensor location:
http://www.advrider.com/forums/showp...8&postcount=18
More on sensor location:
http://www.advrider.com/forums/showpost.php?p=15452060
http://www.advrider.com/forums/showpost.php?p=15453444
IICE, and the Power Commander:
http://www.advrider.com/forums/showpost.php?p=15425676
Will the IICE products affect my mileage?
http://www.advrider.com/forums/showpost.php?p=16864890
Links to additional informative and technical posts:
http://www.advrider.com/forums/showpost.php?p=14561021
http://www.advrider.com/forums/showpost.php?p=14561510
http://www.advrider.com/forums/showpost.php?p=14576564
http://www.advrider.com/forums/showpost.php?p=14592649
http://www.advrider.com/forums/showpost.php?p=14595811
http://www.advrider.com/forums/showpost.php?p=14614961
http://www.advrider.com/forums/showpost.php?p=14632057
http://www.advrider.com/forums/showpost.php?p=14649263
http://www.advrider.com/forums/showpost.php?p=14651308
http://www.advrider.com/forums/showpost.php?p=14651773
http://www.advrider.com/forums/showpost.php?p=14660939
http://www.advrider.com/forums/showpost.php?p=14665885
http://www.advrider.com/forums/showpost.php?p=14665999
http://www.advrider.com/forums/showpost.php?p=14763373
http://www.advrider.com/forums/showpost.php?p=14835208
http://www.advrider.com/forums/showpost.php?p=14850861
http://www.advrider.com/forums/showt...3#post17445763 Gear ratio not the issue
http://www.advrider.com/forums/showt...6#post17476406 Throttle-by-wire
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside screwed with this post 05-20-2013 at 01:39 AM
Poolside is offline   Reply With Quote
Old 11-18-2010, 08:23 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,491
Originally Posted by Poolside
I've been working on a series of enhancements to make the boxer motor on the GS run smoother and better. It's the first of a series of hot rod products and mods that I've been developing, for quite some time now.
The first one is in the final stages of development, and we will announce its availability and subsequent details in the Vendors forum when it is ready. For now this thread is meant to examine the specific features of the devices themselves.
- Jim
Jim
PS Can I make a DVD for the install?
Old 11-18-2010, 08:34 PM   #3
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Heh heh. I'd be honored. Cheers.
Old 11-18-2010, 09:31 PM   #4
space
a.k.a. Jake
space's Avatar
Oddometer: 2,466
Looking forward to whatever you bike nerds have come up with. And I mean bike nerds in the most complimentary way possible, of course.
space is offline   Reply With Quote
Old 11-18-2010, 09:47 PM   #5
yellowbirdrs
yellowbirdrs's Avatar
Oddometer: 960
sure I can be on the Beta test (get it for free) team
yellowbirdrs is offline   Reply With Quote
Old 11-18-2010, 10:22 PM   #6
ultane
sqeezin the bag
ultane's Avatar
Location: the dry side of the blood brain barrier in SW Id
Oddometer: 858
RUH ROH!!!
I'm in trouble now...
I might be wrong, just ask my X...
ultane is offline   Reply With Quote
Old 11-18-2010, 10:32 PM   #7
johnjen
Mod-U-Later
johnjen's Avatar
Oddometer: 13,510
Originally Posted by JimVonBaden
Jim
Little does he know what he's in for…
JJ
QUOTE from vermin
I lie to myself because I am the only one who continues to believe me.
johnjen is online now   Reply With Quote
Old 11-18-2010, 10:35 PM   #8
CHANGELING
Oddometer: 301
European Beta test volunteer here too!!
CHANGELING is offline   Reply With Quote
Old 11-18-2010, 10:50 PM   #9
redredred
n00b Extraordinaire
redredred's Avatar
Oddometer: 330
add another name to the list of beta test volunteers. i'm local in orange county as well :-)
redredred is offline   Reply With Quote
Old 11-19-2010, 01:23 AM   #10
Carlos M
www.motoxplorers.com
Carlos M's Avatar
Oddometer: 2,163
That's good news.
Oilhead and Hexhead?
Carlos M.
MotoXplorers.com
Carlos M is offline   Reply With Quote
Old 11-19-2010, 02:16 AM   #11
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,286
Yes, and the Camhead too.
Old 11-19-2010, 02:37 AM   #12
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,434
The Poolside Plug?
Cool, I'll take two.
Mess with me and you mess with the whole trailer park.
ausfahrt is offline   Reply With Quote
Old 11-19-2010, 05:03 AM   #13
Dan Căta
Dan Căta's Avatar
Oddometer: 1,465
Send a message via Yahoo to Dan Căta
Dan Căta is offline   Reply With Quote
Old 11-19-2010, 05:16 AM   #14
FixxiT
Lunitic Fringe
FixxiT's Avatar
Oddometer: 774
Oil, Hex & Cam? I need all three
Survivor
CC04*CC05*CC09*CC10*CC11
EC10 EC12
FixxiT is offline   Reply With Quote
Old 11-19-2010, 05:22 AM   #15
Mr. Magoo
Follow me; I'm lost!
Mr. Magoo's Avatar
Oddometer: 4,288
Cool! At 32,000 miles my '09 GSA runs fantastic but I am very interested in a little enhancement.
Mr. Magoo is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
