Closed Thread
Old 12-07-2011, 07:15 AM   #1981
fahrtleiter
Volunteer Staph
fahrtleiter's Avatar
Oddometer: 342
Originally Posted by ausfahrt View Post
Got mine too. But I don't see where to connect it. This thread has become too big to navigate effectively.
Could someone please point my dumb ass to a post that describes the connection point with PICTURES?
The sensor connection on top of the air box. Disconnect, and insert the Motofab connectors inline.
No, not a fart lighter.
fahrtleiter is offline
Old 12-07-2011, 07:24 AM   #1982
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,958
Here's a post from Marketing, listed on the first page of this thread: http://www.advrider.com/forums/showpost.php?p=15457461
It was pretty easy, even for over-thinkers like me, as the connections only go together one way.
Splitting lanes, and splitting hairs.
Andrew screwed with this post 12-07-2011 at 07:35 AM
Andrew is offline
Old 12-07-2011, 09:08 AM   #1983
Minnesota
Conform or be cast out
Minnesota's Avatar
Oddometer: 4,040
The good news: I got mine!
The bad news: There is about 5 inches of snow on my 1/2 mile long driveway and the temps are highs in the 20's, lows in the single digits or teens.
I'm thinking this thing won't get tested until March or April.
To learn who rules over you, simply find out who you are not allowed to criticize. -Voltaire
Minnesota is offline
Old 12-07-2011, 09:16 AM   #1984
Ridestrong
Oddometer: 157
Due to extreme weather patterns a new marketing decision should ship all new production to the southern states, i.e. Texas, etc. since those with orders in the north will not be able to use their IICE until mid to late spring.
Ridestrong is offline
Old 12-07-2011, 09:18 AM   #1985
Minnesota
Minnesota's Avatar
Oddometer: 4,040
Now that I have mine, I'm okay with that.
Old 12-07-2011, 12:47 PM   #1986
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Installation Info
I agree! Below are some new installation links
Many informative links are located in the first post of this thread, and in the Vendors thread.
Originally Posted by Poolside View Post
How easy are they to install?
http://www.advrider.com/forums/showpost.php?p=14696928
Installation of IICE Air on R1100/R1150 (Thanks to our Marketing dept)
Installation of IICE Air on R1200 (Thanks to Geoffster)
http://www.advrider.com/forums/showt...4#post16317774
Installation of IICE Air on F650/F800 Twins (Thanks to DidYouSeeThat)
http://www.advrider.com/forums/showt...1#post17433341
http://www.advrider.com/forums/showt...2#post17433382
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 12-07-2011, 01:56 PM   #1987
frogy
frogy's Avatar
Oddometer: 873
When I get mine it will be installed right away.Unless there is snow or salt I ride thru winter.
frogy is offline
Old 12-07-2011, 02:01 PM   #1988
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thank you for your recent orders everyone!
Poolside is offline
Old 12-08-2011, 01:20 AM   #1989
ausfahrt
mach schnell
ausfahrt's Avatar
Oddometer: 1,849
Originally Posted by bracky72 View Post
Got it! Thanks guys.
You can always count on the Americans to do the right thing, after they have tried everything else.
-Winston Churchill
ausfahrt is offline
Old 12-08-2011, 05:04 AM   #1990
Plane Dr
Plane Dr's Avatar
Oddometer: 888
Post ride report...
So not many miles but it definitely feels crisper on acceleration. Maybe just because I waited so long and spent my money. Internal justification?
However in traffic I can run the rpm waaay lower and it is still smooth and then pulls smoother from that rpm. I commute on mine and without the lower adventure first gear traffic is a PITA. Lot's of shifting lots of time on the clutch. (for those unfamiliar TX traffic is 0-80-0 in 100 yards...) I have found that it just allows the engine to run down and then accelerate smoothly. I am assuming the engine never gets to a true steady state and given the low rpm the EFI is basically flipping around through the various maps. The extra fuel compensates for this.
1 happy camper here. So when is the cool coming? shall I preorder for 2013?
01/09 DRZ470SSW more bits than necesary
2005 R1200 GS AKA The Mothership
2003 Z1000 Nuclear Pumpkin (gone)
86 RG500WW (gone)
Bikes are like women. What you think you want, and what you want, change after the first ride.
Plane Dr is offline
Old 12-08-2011, 05:07 AM   #1991
frogy
frogy's Avatar
Oddometer: 873
Originally Posted by Plane Dr View Post
Post ride report...
That early?
frogy is offline
Old 12-08-2011, 06:17 AM   #1992
jduke
Oddometer: 20
Mines on and noticeable improvement in idle of off throttle response, well worth the money.
Now the B I G question...when can we expect the IICE Cool?
jduke is offline
Old 12-08-2011, 01:49 PM   #1993
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
All in due course. Now is the era of the IICE Air.
For a few more days at any rate, until the FINAL SALE ends.
Poolside is offline
Old 12-08-2011, 04:02 PM   #1994
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
A Primer about ECU Throttle Control
Originally Posted by opposedcyljunkie View Post
I currently use a BoosterPlug which supposedly reduces the temp read by the AIT by 20c. It seems to work but there is still that snatchiness when in the off-idle and lower rpm throttle positions. I'm guessing that it's a sign of a lean condition which could be further improved.
Thanks for any advise.
Lurch-followed-by-lunge. You all know what I'm talking about. You crack the throttle and there's a moment's hesitation, followed by a burst of power. At times the hesitation is severe enough that it feels like the motor may stall.
The 'lurch-followed-by-lunge' or 'snatchy throttle' condition that many bikes have is primarily due to the way that Transient Fueling (aka: throttle tip-in) is managed. Not that throttle tip-in is managed poorly per se, but that in order to produce smooth, uninterrupted power, a good shot of fuel is needed at throttle tip-in.
That's fine and all, but the thing about that is the additional fueling needed during throttle tip-in is also the primary source of motor emissions. And because of emissions, there isn't much choice but to operate the motor very lean during throttle tip-in movements, and drivability be damned. The IICE Cool is designed to correct the lean mixture at throttle tip-in.
Just how lean is throttle tip-in? Well, a general rule of thumb for developing a transient throttle control algorithm for the ECU is, "Just make sure the motor doesn't stall." This spartan objective is due primarily to the need to pass emissions within the constraints of both the EPA and the Accounting department, than any abdication of duty from Design or Engineering.
The designer or engineer works within practical constraints. The emissions rules are what they are, and the motor will have the equipment that the manufacturer gives it. And that means, the designer must figure a way to pass emissions using only the ECU and motor control equipment slated for that motor, and do it within the scheduled timeframe and allotted budget for development and testing. Sometimes it's a wonder anything works well at all.
For most BMW bikes, the designer's job to produce a refined drivability from a motorcycle motor is made far more difficult due to the lack of drive-by-wire throttle control. Electronic throttle control is very relevant to drivability because giving control of the throttle to the ECU means that the throttle never does anything unpredictable.
When the ECU controls the throttle butterfly, the ECU can predict the future. What that means is the ECU always knows what the throttle is going to do next, because the ECU is following a script. Here's an example. In one moment the rider twists the throttle, quickly, slowly, any way they happen to do it. And in the next imperceptible moment the ECU executes a slightly different throttle butterfly motion from a pre-programmed routine or script. These throttle-opening routines are crafted to produce good drivability while passing emissions regulations.
Riders open and close the throttle any random way they like. This randomness is an issue because without throttle-by-wire those unpredictable rider-controlled throttle movements are nearly impossible for the ECU to fuel smoothly while also controlling emissions. But with a throttle-by-wire system the random throttle movements never make it directly to the throttle butterfly. Instead the ECU is in control. It opens the throttle, and controls fueling, by following one of its collection of programmed throttle opening curves.
Using a drive-by-wire throttle, the small number of throttle curves pre-programmed into the ECU is a cinch to fuel correctly. The designer can easily make the throttle powerfully responsive and smooth, while at the same time, not cause an emissions spike at throttle tip-in. With the ECU always knowing what the throttle is about to do, drivability does not suffer for the sake of emissions, no matter what the rider does with the throttle.
The reason that throttle-by-wire works so well is the designer isn't forced to pass emissions and have good drivability for all possible random sequences of large and small throttle movements. Instead, the ECU watches the twist-grip throttle as a user-input, and evaluates what the rider wants. Then it opens the throttle by following only pre-configured throttle-opening ramps and curves that were programmed into the ECU. In that way the random, and difficult-to-fuel throttle inputs from the rider are reduced to a small, finite group of pre-determined throttle opening curves.
This is all very wonderful, except for the fact that for the most part BMW bikes do not have throttle-by-wire. And because of that, drivability suffers. Especially at throttle tip-in.
The IICE Cool is designed to compensate for the lean mixture at throttle tip-in.
Poolside screwed with this post 12-08-2011 at 07:35 PM
Poolside is offline
Old 12-08-2011, 07:06 PM   #1995
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Very nice explanation, thanks!
The stumbling is not only felt during tip-in on acceleration but also on deceleration. As the throttle is released or closed, there comes a point on an rpm almost at idle speed that the stumbling also occurs. That is my experience. I hope the IICE COOL will also solve that.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline
Closed Thread
Times are GMT -7.   It's 10:36 PM.
