11-28-2010, 05:21 AM
#91 | ||
Syndicated
Oddometer: 11,286
Poolside screwed with this post 11-28-2010 at 05:41 PM Reason: Forgot the smiley |
11-28-2010, 11:57 AM
#92 |
because I can
Oddometer: 6,087
Well, I agree with you to some degree that tweaking the injection mapping could change the performance as much as a GOOD header and silencer combo on an otherwise stock motor. By several times? That all depends on the exhaust system. I think that might be a pretty good comparison. The differences are pretty subtle.
I also agree with you that some people call putting a louder can on their bike hot rodding their bike but then a lot of us don't. But hey! If you can get the surging to go away on surgers without running the things overly rich and get a tad more performance out of them, GREAT! If I buy the stuff to put on peoples bikes, I am going to call it fine tuning their GS. That way they won't come back and say that it is running smoother but other than that they can't tell any difference and they want their money back. It's kind of like when I install an exhaust system that costs a fortune. I warn the customer that despite all the HP claims and whatnot, the biggest noticeable difference is going to be the noise level. |
11-28-2010, 05:46 PM
#93 |
Oddometer: 323
Hotrod,
A hotrod is anything that is other than stock, I.E........ CUSTOMIZED!!!!! you guys are spliting hairs here, let him do his thing P.S. I am a long time drag racer & I like what you guys are doing!
09 R1200gs |
11-28-2010, 06:24 PM
#94 |
Oddometer: 165
So where/when do I get it?
This all sounds very interesting. And very timely.
I have taken my 07 1200GS to 2 shops already to try to fix the 'lumpiness', most noticeable when the enging is warm and in the lower end of the rpm range and at idle. Feels as if the motor is being strangled somehow. To date they have tried 3 solutions: swapping out the oxygen sensors for known good ones - didn't work; cleaning the 'gum' out of the throttle bodies - no difference; installing a new version of the ECU 'firmware' - some improvement but still not as smooth and free running as I'd like. My next step was going to be to buy a PC. My local dyno guy says he can do a map for each cylinder, which sounds like what is needed if the hex head motor is, in fact, fuelled and sparked like 2 engines. Poolside, you mention that the CAN BUS version of your 'solutions' are further down the track. Like how far? More power to you and keep up the good work.
Cheers Rich 07 R12GS/A Hybrid 03 CBR954RR |
11-28-2010, 07:06 PM
#95 | |
Mod-U-Later
Oddometer: 13,516
When you adjust the throttle cable barrel adjusters make sure that the cable itself doesn't rotate, at all. Then run the bike for at least one thermal cycle. Then re-check the setting. As you repeat this, the amount of adjustment will diminish each time you make an adjustment. And yes this technique almost seems like you need 3 arms, or at least 3 hands, but it is possible with just 2 You're sorta using a iterative loop approach to finding the sweet spot each time an adjustment is made. Now what is happening is the outer jacket of the cable is re-orienting itself to it's neutral position, which in turn changes its effective length and thus the setting you're seeking. AND as the cable barrel adjuster lock nut is tightened, the barrel adjuster changes it's effective length. This can be partially compensated by keeping the lock nut partially tight during checking of the setting, BUT NOT WHEN THE CABLE BARREL IS ADJUSTED. If you adjust the barrel adjuster with the lock nut tightened down to tight it will add additional wear and add even more change to its length between the loose and tightened conditions. And if this doesn't work then your cables are WAY worn out, and most probably the inner teflon jacket has shifted position. The labor intensive but low $$ solution is to check both ends of each cable in the whole cable assembly to see if the teflon jacket has shifted and is poking out at one end. If so then carefully cutting off the excess jacket is a quick solution. The other solution is to replace the entire throttle cable assembly with an all new assembly. Which BMW suggests because the throttle cable is a wear item and should be serviced (replaced) regularly. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. johnjen screwed with this post 11-28-2010 at 07:19 PM |
11-28-2010, 07:24 PM
#96 |
because I can
Oddometer: 6,087
I use all those tricks except that I don't adjust the barrels with the lock nuts snug, I just don't check the sync until they are tight. Not right? I loosen them, move the barrel, and tighten them down again and THEN check the sync again. Another trick I use is to occasionally shut the engine off and snap the throttle wide open six or seven times. That helps the cables settle into where they want to be.
11-29-2010, 06:48 AM
#97 | ||
Syndicated
Oddometer: 11,286
Poolside screwed with this post 11-29-2010 at 08:32 AM |
11-29-2010, 08:07 AM
#98 | |
Syndicated
Oddometer: 11,286
Poolside screwed with this post 12-04-2010 at 09:36 PM Reason: Clarify 'empty boxes' |
11-29-2010, 08:33 AM
#99 |
I have little to say
Hmmmmm.....couldn't we just bolt on a couple of these things
http://www.dellorto.co.uk/ or a couple of these http://www.amalcarb.co.uk/buildCarb_Monobloc.aspx (these worked very well on my TR6C Triumph), along with some of these http://www.motorcycleinfo.co.uk/inde...&pageId=326734 and call it a day?
11-29-2010, 08:52 AM
#100 | |
Syndicated
Oddometer: 11,286
But, a well-tuned EFI system always works better than a carburetor. The significant difference between the carb and the stock EFI is how they meter transient fuel. That is, the additional fuel that's added while the throttle is opening. The second product we're working on performs that function, and then some. Remember on a carburetted car, you could blip the throttle enough times while at idle that you could stall the motor? This device can be adjusted to manipulate the Motronic's transient fuel function to such an extent. The production model isn't gonna go that far of course, but the prototype I have here can. Poolside screwed with this post 11-29-2010 at 09:33 PM |
11-29-2010, 09:58 AM
#101 | |
The savvy rider or racer (car or auto) knows that throttle bliping does nothing but make noise and wash down cylinder walls. I was musing about camshafts recently...I miss those old 413 CI max wedge engines with their killer torque, able to slowly spin the rear slicks through their auto transmissions at the drags strip....with the air cleaner off, their carbs sprayed fuel all over at idle...cam overlap was to blame...my TR6C with T&M #6/#9 grind cam combo would wet my legs with gasoline at an idle...same culprit...cam overlap...both valves open at the same time. Those who fit pipes/mufflers to boxers in the hope of getting some exciting sounds are barking up the wrong pipe...install cams with some overlap and you'll get that nasty sound you seek.... ....and, now back to your regularly scheduled boxer FI map.. I await yours and JJ's latest details regarding the boxer EFI changes. |
11-29-2010, 10:28 AM
#102 | |
Pepperfool
Oddometer: 2,570
Old enough to know better.... Young enough to try it again |
11-29-2010, 12:45 PM
#103 | |
Mod-U-Later
Oddometer: 13,516
In one sense it's a trade off of time spent fussing and the $$ spent on hardware vs fussing with the FI map, either directly or indirectly. And then there is the added factors of carbs don't automatically adjust for altitude nor the change of seasons really all that well. And having spent the time and effort to retrofit a set of round slide carbs on my R65 and then live with them, I know that dialing in the EFI using the targeted modifications we are working on will be WAY easier on every level, and will be less costly and easy enough that anyone who can perform routine maintenance can make it happen. And did you notice that those cams are horsepower cams, not mid range torque cams? So while this may provide a top end speed boost you will loose low end and some mid range power. Which some may desire but it wouldn't be the best choice for going slow in the dirt. At one point I did consider yanking the EFI on my 1150 and installing some decent slide carbs, even though it is a PIA to get them dialed in and then have to fuss with them as the seasons change. But with these mods I don't have to deal with all of that fussing. Its much more of a set and forget and enjoy the ride instead of noticing engine responses that shouldn't be there in the first place. Like Poolside sez, a properly dialed in EFI is invisible, you don't even know it's there. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. |
11-29-2010, 12:57 PM
#104 | |
Mod-U-Later
Oddometer: 13,516
And if I were to push this even further, whether any aftermarket aparatai would even be wanted. JJ
QUOTE from vermin I lie to myself because I am the only one who continues to believe me. johnjen screwed with this post 11-29-2010 at 01:34 PM |
11-29-2010, 03:28 PM
#105 |
Mod-U-Later
Oddometer: 13,516
Fuel injection engineers and s/w guys need a specific set of terms that match up with the functions (sub-routines) that they code. So some of the terms are not in common usage.
Tip in and tip out are 2 such terms. They refer to increasing the throttle angle (tip in) and decreasing the throttle angle (tip out) or makes the butterfly more open (tip in) and makes the butterfly less open (tip out) We will go into more of the inner functioning of our EFI systems in due course. So forgive us for not answering your question straight away. The answer is involved and in order to answer it fully we need to setup some baseline terms and functionality first. And we'd rather do it correctly once rather than piecemeal a bunch of times. JJ
