Old 11-20-2010, 05:29 AM   #1
wannabe1 OP
Oddometer: 558
cb350 four or twin, you choose
Questions for the early 70's Honda CB guys. Kinda got the vintage bug and there have been a couple of early 70's CB350 bikes for sale, some twins, some fours. As far as reliability and wrenching which bikes are better? Logic would point me in the simpler is better path which points to the twins. One question is assuming I get a bike that is already running properly and is not a "project" as long as it is properly maintained could I assume a 4 would be just as reliable as the twin? Can I assume the 4 is a better performer than the twins?
wannabe1 is offline   Reply With Quote
Old 11-20-2010, 06:04 AM   #2
klp
Oddometer: 254
Well I am not a twin guy but I own a four. I am sure others will chime in on twins.
Either bike would be dead reliable as they are Hondas. You know how that goes - pick a good starting place. I bought mine with 20k and it has run great after doing the usual - carb clean/sync, air filter, plugs, valve check, brakes. Just don't expect modern reliability and you will be very happy.
As you are thinking the fours have twice as many carbs, valves, etc so they are a little more complex.
Regarding the bikes I am partial to the fours. They are in fact a bit slower than the twins but super smooth and you cannot deny the sound track of a little four. I think the 360T's have a six speed but for some reason I think the 350Ts are more desireable. The twins also have a diaphram carb which can be a PITA. I think the fours are also heavier.
Good luck and you cannot miss with either - post up some pics when you decide.
Lots of old Hondas, 2 Yamahas, 2 Kawi's.
klp is offline   Reply With Quote
Old 11-20-2010, 06:14 AM   #3
anotherguy
anotherguy's Avatar
Oddometer: 6,617
The four for me. Jewel like quality and a wonderful exhaust note as well as a smooth ride make the small fours a nice ride. The four will take more time and money to maintain but will be as reliable as the twin. The four was aimed at a higher profile market and the component choice shows it. The twin was meant for basic transport and the inverse is true there.
The first generation Honda fours (size notwithstanding) are the benchmark for Japanese bike reputation in dependability. High cool factor as well. You won't be pulling up to a light next to a 350 four often. I'd like a CB-1 someday. Not easy to find in good shape.
you don't see luggage racks on a hearse..........act accordingly
Old 11-20-2010, 07:30 AM   #4
wannabe1 OP
Oddometer: 558
After I briefly googled the CB350, I did learn that the twin was the better performer and lighter and the reason the 4 was only produced a couple of years before the 400 was introduced.
Old 11-20-2010, 08:02 AM   #5
hoodellyhoo
Dummy
hoodellyhoo's Avatar
Oddometer: 220
Let's be honest. You already know which one you want....
1972 Honda CB350F
1972 Honda CB750 K2
1976 Honda CB750 K6
hoodellyhoo is offline   Reply With Quote
Old 11-20-2010, 09:57 AM   #6
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,120
I had a 500/4 with 4 open megs many years ago.
It was one of the sweetest sounds I've heard.....
But I kept the 350twin.
Who the hell would drag race a Ducati?!?!?!?!
http://www.dragtimes.com/Ducati-Mons...lip-10329.html
MODNROD is offline   Reply With Quote
Old 11-20-2010, 10:11 AM   #7
welder
welder's Avatar
Oddometer: 1,524
If you go with the four, I personally would get a 400 and not the 350 four. The 350F is less desireable and lower performance than the 350 twin and the 400 four. Stay away from the 360 twin as they are not as desirable and I have heard from a friend that restores 350's that the 360 is a bit of a turd. Be aware that the 350 and 400 four's are a pricey bike to fix up and/or restore. Might want to consider a 550 four too. They are a wonderfule bike with the lightness and charm of a smaller bike but enough power to take longer hwy. rides. Best of luck, Fergie. One of my rides
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 11-20-2010, 10:40 AM   #8
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,597
the 350 twin is the most common bike ever made (behind the Cub of course) so parts are dirt cheap. It's lighter and has better performance than the 360. I wouldn't waste my time on a 360.
I talked to a guy that loved his 350f but he said it was kinda like working on a watch with all the moving parts. He loved that he could keep all that complication rolling. It's smooth and the sound is nice. Again, I wouldn't waste my time on a 350f. If I was going to get a 4-cylinder I'd at least want to be rewarded for the extra effort of dealing with the added complication with more power. A CB750 is the only 4-cylinder I'd add to the garage.
I agree with klp that I don't like the diaphragm carb on the twin though not because it's a PITA. The diaphragms are attached to the slide so you'll need to buy the whole assembly since the rubber will almost certainly be bad. $45 each at Sirius. $90 for two. Heck, I've seen whole bikes go for less than that.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is online now   Reply With Quote
Old 11-20-2010, 10:43 AM   #9
Twistyblackmetal
wrenchslinger
Oddometer: 62
I've restofu**ed a number of CB 350-360 twins.
and would pass over them to get into a 350-400 4. They will be a bit more difficult to set up correctly but the reward from that exhaust note is certainly worth it, IMHO.
Twistyblackmetal is offline   Reply With Quote
Old 11-20-2010, 11:02 AM   #10
wannabe1 OP
Oddometer: 558
Hoodellyhoo, the local 350F looks like yours. Thanks for a better pic of one than the craigslist add.
Old 11-20-2010, 12:22 PM   #11
Pezz_gs
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,797
I have just rebuilt a CB400/4 from bare cases. They are mighty impressive
I have a build thread in my sig line. Parts are readily available. Plenty of info at the SOHC forum. I know where you could get a cheap Yoshi 460 kit
I have made a few mods to mine to turn it into an XR460 Four
However its is all reversible except the swingarm extension, 100mm.
Four over a 350 twin, really there is no contect in my opinion. . go the FOUR
David Silver Spares in the UK has lots of repro parts too
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 11-20-2010, 12:56 PM   #12
Mr. Magoo
n/a
Oddometer: 4,978
Cool bike!!!!
Mr. Magoo is offline   Reply With Quote
Old 11-20-2010, 02:56 PM   #13
bfd70
Oddometer: 792
the 350 twin was the first bike I ever loved. yesterday, after 18 years and 8 bikes, I finally got one. 9k on the clock, runs like a top. Basically stole it for $700. Will post pics soon.
bfd70 is offline   Reply With Quote
Old 11-20-2010, 04:03 PM   #14
650sf
Oddometer: 112
I would go for the twin, and if you go for the 4 I would get at least a cb550.
Matt
'79 xs650 Special
'80 kz440 B1
650sf is offline   Reply With Quote
Old 11-20-2010, 04:12 PM   #15
fishkens
Further...
Oddometer: 5,149
It's pretty clear there ain't going to be a consensus here. I think that's because both bikes are pretty darn good, each in their own way.
My dad had a 350 four and loved it. It was the first road bike that I drove. That alone makes it very special for me.
I had two friends who had a 2 cylinder 350. They both toured on it for a few weeks throughout the Midwest and NE. They didn't even complain!
Since you have a few options how about basing your decision on the best, most reasonably priced bike that you come across?
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Times are GMT -7.   It's 08:18 AM.
