Old 11-20-2010, 12:37 PM   #1
x3300 OP
geoff
Oddometer: 169
BMW Frame Gussets
Hi All,
As part of my project I made up a set of gussets to reinforce the frame of my BMW R100GS.
http://stuff.gotdns.org/bike/orgs-build-up/01-orgs-build-up/gussets-and-patterns.jpg
I started to make some scalable vector graphic (svg) artwork based on these so others could make their own gussets. What I have ready for release can be found here:
http://stuff.gotdns.org/bike/orgs-bu...gusset-design/
Most browsers and some paint programs can display svg files, so you may be able to print from one of those. The svg files have dimension info so with a good printer accurate templates can be printed, and these templates pasted to sheet metal stock and cut out with a band saw, cut-off tool, etc.
I stopped by the Rustworks Fabrication Shop (http://www.rustworks.com/) in San Carlos, CA this week and talked with Jesse about having some gussets cut using their CNC controlled water jet cutter. The cut quality of the steel sheet samples I saw was really good.
He said the cost is made up of some one time CNC programming fees, essentially to convert the artwork into code for their CNC controller, some per-job setup fees, some per-piece cutting fees, and material fees if you want them to supply the metal stock. He said that he could do volume orders and that the resulting set cost would be significantly less. A conservative estimate would be less than $200 per set, but most likely closer to $100.
Based on the contacts I have received it seems a number of people are interested in reinforcing their BMW frames, so, if anyone is interested in joining a group order for BMW frame gussets, or interested in helping with preparing the artwork please let me know either in this thread or in an e-mail if you prefer. We can also do optional shock absorber mounts and HPN front tank mounts.
The main things to do for the order include:
  1. create the remaining artwork
  2. make prototypes in paper and check the fit
  3. make pre-production parts in steel and check the fit
  4. make final parts and ship orders
Note that these gussets will just be pieces cut out of sheet steel. Some grinding and forming will be required to fit these to the frame during installation.
Also, this is not a money making enterprise. I'm thinking gusset costs will be shared fairly, and shipping will be world-wide and that paid for by the individual.
-x3300
x3300 is offline   Reply With Quote
Old 11-20-2010, 11:57 PM   #2
igormortis
igormortis's Avatar
Oddometer: 1,082
Just what I've been looking for. Thanks for sharing!
I'd be keen for the vector graphics at the very least, but would most probably take advantage of a group order if you were to have the gussets water-jet cut.
Be interested in an HPN tank mount also. What about the rear mount as well?
Awesome work - thanks again.
igormortis screwed with this post 11-21-2010 at 04:02 PM
igormortis is offline   Reply With Quote
Old 11-21-2010, 12:52 PM   #3
x3300 OP
geoff
Oddometer: 169
In the rear the HPN tank attaches to the two top main tube gussets, which will be in the set. Some way to secure the bolts is needed though.
-x3300
x3300 screwed with this post 12-15-2010 at 09:17 AM Reason: Remove laser comment
Old 11-21-2010, 04:02 PM   #4
igormortis
igormortis's Avatar
Oddometer: 1,082
Originally Posted by x3300
I guess laser cut sounds more impressive...
Whoops - reading and comprehension fail on my part! I actually thought water and wrote laser.
Old 11-27-2010, 11:01 AM   #5
x3300 OP
geoff
Oddometer: 169
Just an update, I uploaded a few more vector graphic files today.
http://stuff.gotdns.org/bike/orgs-bu.../gusset-design
-x3300
Old 11-28-2010, 09:31 AM   #6
rediRrakaD
Whoopdie do
rediRrakaD's Avatar
Oddometer: 440
Geoff,
I'm in for the group buy and any help I can provide.
Let me know what I can do.
Cheers,
S.
RIFF RAFF
Industrial Tiki Purveyor
rediRrakaD is online now   Reply With Quote
Old 12-07-2010, 02:02 PM   #7
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,980
In.
Old 12-08-2010, 06:08 PM   #8
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 635
How many orders do you need to get this started...I need 2 sets
Greg in Foster City
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 12-08-2010, 09:07 PM   #9
igormortis
igormortis's Avatar
Oddometer: 1,082
I'll take one set for sure.
Old 12-13-2010, 09:10 PM   #10
GESII
Gerry with a G
GESII's Avatar
Oddometer: 96
I'm in for one set...
GESII is online now   Reply With Quote
Old 12-14-2010, 05:55 AM   #11
SlackerSteve
Homely Adventurer
SlackerSteve's Avatar
Oddometer: 452
Me too!
In.
When you create with your brain, it is work
When you create with your heart, it is craft
When you create with your soul, it is art
SlackerSteve is online now   Reply With Quote
Old 12-14-2010, 09:14 AM   #12
airheadpilot
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 282
Oh what the hell...
Put me down for a set.
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 12-16-2010, 10:09 AM   #13
timdog
a.k.a. Josh
timdog's Avatar
Oddometer: 553
I am interested in a set.
timdog is offline   Reply With Quote
Old 12-17-2010, 10:28 PM   #14
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 3,793
I'll take a set.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is online now   Reply With Quote
Old 12-18-2010, 07:45 PM   #15
walkingbear
walkingbear's Avatar
Oddometer: 2,853
I'm in
I'm in for a set
BMWMOA 82741 75 R90S ,83 R100RT (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS w/hack,05 K1200S (Gandalf)
walkingbear is offline   Reply With Quote
Times are GMT -7.   It's 07:12 PM.
