Old 12-20-2011, 06:37 AM   #1531
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,544
Is anybody having any stalling issues on a 2010 fx450 ?
We started up my friends bike last night for the first time and riding it around the yard and up and down the street in 40-50 degree temps, and the bike would continually stall out on decel.Sometimes after restarting as soon as you move the throttle it will stall, even after warmed up.
We just received this bike, its a brand new left over 2010.
ST1300 - IRON BUTT # 23,716
GAS GUY is offline   Reply With Quote
Old 12-20-2011, 06:59 AM   #1532
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,647
Turn the idle knob to increase the idle speed of the Berg. Most people turn the idle knob (left side under shroud) down to idle like a carb'd bike, but they need to idle faster than you think.
See if that helps, and ride hard.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 12-20-2011, 07:13 AM   #1533
goatdog
PTO
goatdog's Avatar
Oddometer: 138
FMF question
Question, I have two FMF mufflers a Q4 and a Powercore 4 (both used). I have not mounted either on the bike and I would like to repack one and put a new end cap on before installing on the bike. Problem is I only have a kit to do one. For those with experence with them which one would you run?
Be the person your dog thinks you are.
goatdog is offline   Reply With Quote
Old 12-20-2011, 08:06 AM   #1534
Tarheel Wheeler
Around
Oddometer: 3,647
Depends on your type of riding. I've got a Berg with a Q4 and a Berg with the Factory 4.1 Ti. Both have screens in them. Considerable difference in the sound levels. 4.1 is loud. I run the 4.1 on closed course and where noise isn't an issue. I run the Q4 when DSing and want to operate in stealth mode.
Thing I don't like about the Q4 is that there is no exhaust spring holder on the can. I like that extra little bit of security that comes with a spring compression fit and PermaGasket at the junction. I know it's belts and suspenders, but still like to run the spring so much that I'm getting a spring holder welded on the Q4 this week.
Know that didn't answer your question directly. 4.1 is the best FMF pipe for performance imho ( short, compact and free flowing). Q4 is larger, quieter and a better all round DS pipe.
Old 12-20-2011, 08:26 AM   #1535
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,544
Okay,thanks for the info,we will try that.
I pull that knob out for the cold start but I did not know it turned for the Idle speed.We just recieved the bike from New York and the dealer did not send the manuals yet .
Old 12-21-2011, 03:21 AM   #1536
LukasM
Oddometer: 5,426
Hey guys,
Is anybody using the Hard Parts triples below (8120109902268) in combination with a Scotts damper? All the submounts I have here for billet and cast KTM clamps won't work, due to the different offset as well as the handlebar mounting.
Since the steering damper arm axis is supposed to sit as close as possible over the center of the stem, I am assuming the mount would ideally place it in the center of both both adjustments, so 20.5mm. Is 1.5mm offset from centerline ok for the Scotts?
I know Husaberg sells a mounting kit (77012005544) for their own damper (81212005000), but I have no idea if this will also work for the Scotts. Any advice?
Thanks,
Lukas
Old 12-21-2011, 07:40 AM   #1537
McLeod
Oddometer: 429
WOW, Lukas Santa must really like you!
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 12-21-2011, 09:33 AM   #1538
GAS GUY
MILE EATER
GAS GUY's Avatar
Oddometer: 3,544
We turned the idle adjuster screw up, but it didn't change the idle speed much and still has issues. It gets worse as it warms up. Part throttle (1/4 or less) the bike runs ok part throttle to wide open it bogs terrible. The bike is new 2010 and had a varnish smell in the tank was complete drained and 100 octane aviation fuel added.
Old 12-21-2011, 09:50 AM   #1539
LukasM
Oddometer: 5,426
Nah, bought them used on Ebay, after selling my stock black triples to the KTM guys who like the 22mm offset it should be a $50 upgrade.
LukasM screwed with this post 12-21-2011 at 09:56 AM
Old 12-21-2011, 09:51 AM   #1540
Tarheel Wheeler
Around
Oddometer: 3,647
There's a ton of guys on this thread who know more than me on this subject, but I'd check the fuel pump and then move onto cleaning the injectors in that order.
Read back in the thread and you'll see where some are running the CanAm external fuel filter, a fuel filler filter and Phaser or StarBrite Ethanol and Additives neutralizer. Highly recommend all 3.
Old 12-21-2011, 09:54 AM   #1541
Tarheel Wheeler
Around
Oddometer: 3,647
Originally Posted by LukasM View Post
Nah, bought them used on Ebay, after selling my stock black ones to the KTM guys who like the 22mm offset it should be a $50 upgrade.
Hey Lukas, If you have any Scotts submounts and posts for the 22mm that you want to sell let me know. I need 1. Good luck with the search.
Oh, sweeeeet blue Berg parts ya got there.
Old 12-21-2011, 01:18 PM   #1542
nobrakes
nobrakes's Avatar
Oddometer: 3,369
As TW suggested, I would start disassembling the fuel delivery path and see if anything is clogged, i.e., it may flow enough at idle to keep it running, but the flow is too restricted at more open throttle positions. First thing I would do there is remove the tank and take out the fuel pump and inspect everything. In particular, the fuel filter - it's possible it is clogged, see #2 on the diagram below:
“It’s habits that make us, and habits that break us.”
'12 KTM 350 EXC-F
'12 Beta EVO 2
nobrakes is offline   Reply With Quote
Old 12-21-2011, 04:21 PM   #1543
McLeod
Oddometer: 429
Dose anyone know if you run a bike with out the 70 degree axillary tank attached and the fuel adapter installed?
Old 12-21-2011, 05:07 PM   #1544
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,239
If you mean the aluminum fuel adapter on the main tank, then both sides of the quick disconnect for the 70 degree tank 'curly' hose connection have check valves and won't leak. You should protect the quick disconnect valve left on the bike to keep dirt out of it. Do you want to put the stock plastic subframe back on (leaving the 70 degree adapter) and ride it, or just run it on a test stand?
cyborg is offline   Reply With Quote
Old 12-21-2011, 05:14 PM   #1545
McLeod
Oddometer: 429
Yes I want to leave the fuel adapter on the main tank.
Yes I want to run the plastic subframe back on.
Do you have any suggestions for covering the fuel hose connector?
Thanks for the fast response.
Times are GMT -7.   It's 11:05 PM.
