Old 02-05-2012, 05:15 AM   #1756
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,653
Originally Posted by Bluetonguejak View Post
New to this thread.
Made universal mounts for TT HID assembly and double to mount my Rallye roadbook/fairing assembly.
Bars are raised about 60mm due to under bar damper and risers, so raised speedo and moved forward a bit so can be easily read.
Made ABS extenders for the rubber straps and now cable-tie the bottom of the light assembly as it came off the pins last weekend on the mx track.
Plenty of room behind headlight for additional wiring and auxillary gadgets.
Very nice work Bluetonguejak. Would like to see it all mounted up with your roadbook and/fairing. You interested in mass producing that setup for some Bergers?
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 02-05-2012, 09:36 PM   #1757
BogeyMan
BogeyMan's Avatar
Oddometer: 451
Boiling fuel...
I thought I'd solved this issue... Header wrapped & ceramic coated, underside of take coated with heat tape.
Today after riding about 2 - 3 hours of woods trails, we got back to the staging area.
Time for some gas thought I. So, I popped the fuel cap... only to get doused by about 1/2 gallon of fuel spray exploding in my face. It was only the lightning quick reaction of my eyes that saved me from possible serious injury. Plus, fortunately, one of my riding group, a nurse, had some saline/eye wash.
I'm not sure if it was/is a faulty vent on the fuel cap (couldn't find anything wrong when I disassembled it) or a blocked breather (again - couldn't find anything wrong when I checked it).
Anything else I should check?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 02-06-2012, 02:17 AM   #1758
Bluetonguejak
Adventure Seeker
Oddometer: 85
Rallyelite
These are the only photos I have from when I was setting-up the TT Roadbook, IMO and fairing.
Will take some more when I put the gear back on with the TT remote buttons and tripmaster remote(and headlight)
Using the KTM/TT mount just because I had one and it seems to work.
Mounted high because I am tallish and found this position about right to read standing up and sitting down.
One knurled screw removal of fairing. Screwed into nutsert in IMO bracket.
Was going to mount off head-stem (as per my SXC) but chose to keep it simple and quick to swap between rallye and the TT HID mask.
It's a whole lot of shit hanging off the triple clamps, but it doesn't feel that heavy on the steering.
Have left room for second IMO/ICO if speedo/tripmaster set-up doesn't cut it.
If all turns to shit, I'll throw my MD/ICO set-up on it, which is already proven to be tough and reliable.
Bluetonguejak is offline   Reply With Quote
Old 02-06-2012, 02:25 AM   #1759
Bluetonguejak
Adventure Seeker
Oddometer: 85
Motard gearing
Originally Posted by lc8john View Post
I'm running 15/48, at the moment.
Tried 14/38 (to high) and 14/48 (a bit low) before.. but 15/48 seems to be spot on for my kind of ride.
With 13/50 you will power wheelie in 6th gear
J.
Thanks J.
Yesterday had a Wild ride in the hills @ 13/50 on wild map setting, which should be good for the track - wheelie monster!
Will try 15/50 next as don't need to commute faster than 110/120kmh, but nice to know can go 160kmph+ comfortably.
Old 02-06-2012, 05:39 AM   #1760
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Originally Posted by Tarheel Wheeler View Post
Oil....running Rotella T Synthetic in my Bergs. Rotella is the brand Rekluse recommends, and is also what the guys at Genuine Dirt Racer (Berg dealer, racers and Nick Fahringer wrench) are running and recommended. No issues at all. Another good thing about it is that you can find it almost anywhere.
Cyborg, Regarding ceramic coating, the GDR gurus recommended ceramic coating only the mid pipe which is in close proximity to the tank. They found that ceramic coating the entire exhaust tended to push too much heat into the exhaust can casing packing to burn up quicker and a hotter surface temp. Also said they saw a slight decrease in engine power...not sure why.
Nice fuseblock find, but the cost.
Are you using the Rotella T6 or T5.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 02-07-2012, 07:50 PM   #1761
Tarheel Wheeler
Around
Oddometer: 3,653
T5 as recommended by GDR.
Thanks for the pics with Rally setup Blue. Is that the KTM fairing?
Old 02-07-2012, 10:31 PM   #1762
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,223
T5 is a blend, T6 is full synthetic. Both are good oils for motorcycles. I prefer the full syn myself for a little more longevity. InterwebsWord is, don't use the Rotella in Grey bottles. Blue and white bottles OK.
cyborg is offline   Reply With Quote
Old 02-08-2012, 08:04 AM   #1763
McLeod
Oddometer: 429
Why? Did they give any reason?
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450
McLeod is offline   Reply With Quote
Old 02-08-2012, 08:24 AM   #1764
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
To advertise as a full synthetic there was a large amount of synthetic stocks required. Synthetic blends do(or at least were) not require a given amount. Kinda like pre mix antifreeze. You pay near the same price for only half the antifreeze.
tahoeacr is offline   Reply With Quote
Old 02-08-2012, 09:12 AM   #1765
cyborg
cyborg's Avatar
Oddometer: 5,223
If you mean Grey bottle, I'm not sure. I read on some racing forum it's a different blend with friction modifier additives that are not good for wet clutches. My local auto parts stores carries the Blue "T6" and White "T" gallon jugs.
I looked at the Shell site
http://www.shell.com/home/content/rotella/products/
An see that the blue is T6 (syn)
Grey is T5 (dino/syn)
White is T (dino)
So I don't know, since T5 is supposed to be OK? Read the labels.
Old 02-09-2012, 09:54 AM   #1766
McLeod
Oddometer: 429
Thanks guys.
Old 02-09-2012, 11:59 AM   #1767
McLeod
Oddometer: 429
Dose anyone have good replacement for the stock headlight switch? I am not real happy with mine, it seems to be dysfunctional as the Clintons marriage!
Old 02-09-2012, 01:51 PM   #1768
guns_equal_freedom
Oddometer: 5,573
If you believe the manufacturers (like Engine Ice) the water they use is ACS de-ionized water, that stuff in ACS grade is about $15 for a one gallon jug.
So if you believe the manufacturer you are paying for the water and the solution, and then it's not a bad deal.
guns_equal_freedom is offline   Reply With Quote
Old 02-09-2012, 02:08 PM   #1769
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
No, referring to the cheap stuff. However, you can school me on ACS grade deionized water? I've always used distilled water with a little Water Wetter. Just old school. That was the way I was taught decades ago.
Old 02-09-2012, 02:47 PM   #1770
TrailTrauma
Oddometer: 23
I get it...you mean you're drawn, like a siren, to someone else's high beams when the trail gets rough?
TT
TrailTrauma is offline   Reply With Quote
Times are GMT -7.   It's 11:54 PM.
