03-27-2012, 08:04 PM
#1966 | |
Oddometer: 32
If it wouldn't cause any problems, I'll have to test it to see how much louder it gets ... so far like the quiet note. |
03-28-2012, 08:03 AM
#1967 | |
Potius Sero Quam Numquam
Oddometer: 4,398
The OEM map to the US is too lean in a few spots to pass regs and I think runs better with the restrictor plate in with that lame map. If you are happy with the power with the restrictor plate and quiet note, just run with it that way. |
03-28-2012, 06:35 PM
#1968 | |
Oddometer: 32
Regarding the fuel mapping, I saw HF's post on how it affected the performance of his bike and made sure to ask my dealer about it. I'm not 100% on the answer I received...dealer was fantastic overall and I would recommend them but I wasn't able to definitively confirm if the competition map was loaded. Is there a way that I can check the mapping as an end-user?...in other words, can I buy some diagnostic tool to check it? Alternatively, I guess I could take it to another dealer to check it out...but they are fairly spread out in Texas. Sounds like it is worth it, though. Many thanks for your help! |
03-28-2012, 07:11 PM
#1969 |
Rider
Oddometer: 736
Yes there is a fine tune adjustment tool available from Husaberg hard parts.
If your bike is running well it will have the competition map otherwise you will notice the occasional stutter, turning the idle up a bit may help, but otherwise let your dealer know if the bike is not running 100%. |
03-29-2012, 08:54 AM
#1970 | |
Oddometer: 429
What dealership are you using?
03 XR650L, 92 XR250L ,01 DRZ400, 95 KDX200, 03 KTM 640 E, 2010 Husaberg FE450 |
03-29-2012, 01:09 PM
#1971 | |
Oddometer: 4,398
As for your own diagnostics/programmer tool, they are quite expensive and I think I heard Husaberg stopped selling them to end users. Better would be just to get that dealer or another dealer to verify the competition map with their programmer tool, which they should do for no charge. |
03-29-2012, 07:18 PM
#1972 |
Oddometer: 32
OK, that is good advice. I will try to open the dialogue again with my dealer, and if that doesn't work, will talk to another dealer.
Rather not mention the dealer I purchased from...they really were fantastic to me overall. And, I would hate for this to get blown out of proportion. |
03-31-2012, 06:41 AM
#1973 |
Bike-aholic
Oddometer: 2,067
I bought mine from TJ's in Austin. At the time, they were not familiar with this concept, and had not performed the task before on any of their bikes. So, I used a different dealer that does it automatically to every bike right out of the crate.
Don't be surprised if your original Dealer is not familiar with the routine. It probably just means no one has ever asked them to do it before.....and/or they haven't really been riding these bikes much for themselves. It doesn't mean they are a lousy Dealer. Quite the contrary, TJ has been great to work with. I just decided to send my ECU to somebody who has perfected the art. HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com HighFive screwed with this post 03-31-2012 at 06:46 AM |
03-31-2012, 03:00 PM
#1974 |
Where am I?
Oddometer: 77
Help! street wiring my berg...
Hoping some of you with more electrical experience that me can help a clueless bastard like me out. I am trying to fully dual sport my '11 FE390 by adding a brake light and all 4 turn signals. I know you can buy the Husaberg parts that supposedly plug and play but I settled on aftermarket switches and signals from Highway Dirtbikes and Baja Designs. I assumed the wiring would all be there for me to tap into but now that I've started tearing things apart it's not nearly as straight forward as I had hoped.
Questions: -Can anyone identify the 4 open connectors that I show in the photos? 1,2, and 3 are below the gauge cluster(obviously) and 4 is under the seat. -Is the wiring there somewhere for the rear signals or do I need to add the harness or run my own wires? -Where will the rear brake switch plug into the system? -WTF am I supposed to to with this LED flasher that I bought!? Thanks for any help. Also, sorry if any of these questions are already answered in the thread, but I couldn't make it through all 131 pages. [IMG] [/IMG]
04-01-2012, 01:44 PM
#1975 | |
Oddometer: 429
I asked the dealership that is closest to me about at least checking to see what code was in the ECU or just putting the competition code in it. I got the blank stare look. I tried to explain what I wanted but didn't get through. That is why I was asking.
Who did you send your ECU off to HighFive? Quote:
04-01-2012, 04:33 PM
#1976 | |
Around
Oddometer: 3,355
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden "Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE |
04-01-2012, 06:10 PM
#1977 |
Oddometer: 429
Awesome! Thank you.
I will give them a call tomorrow.
04-01-2012, 10:52 PM
#1978 | |
Oddometer: 4,398
04-02-2012, 05:24 AM
#1979 |
Bike-aholic
Oddometer: 2,067
Tasky's Metric Cycle....near Seattle, WA. Jeff Tasky is one superb dealer! With the Cyborg seal of approval, to boot.
![]() HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
04-02-2012, 01:20 PM
#1980 |
Oddometer: 42
OK all you Berg pros, I have a couple of quick questions.
1) Aftermarket sidestand/ kickstand Is there a part intended for the KTM that will bolt on? I would like to run the Pro Moto Billet sidestand just not sure witch one would fit. 2) Nut inserts in fuel tank I have had several incidents where the inserts (that hold the radiator shroud bolts) have been pulled out of the tank. Previously the fix was to simply and carefully pop the inserts back into their cavity in the tank. The problem now is I have lost two of the inserts, and it doesn't seem like this is a part that is available on its own (it is part of the fuel tank). Has anyone else encountered this? Suggestions? Thanks! Kevin |
