Old 06-02-2012, 07:23 PM   #2326
Duken4evr
Duken4evr's Avatar
Oddometer: 360
Originally Posted by Navin View Post
If the fuel is boiling it isn't pumping well to the injector. I'm going to grab a lower temp fan switch and deal with killing the battery I guess. It is like dancing on a tightrope with these bikes. I've had both the pump and a battery die and there is nothing more depressing than a barely audible "click" when you push the button.
I bought into the li-po battery craze big time thru 4 different manufacturers. Now I won't even own one. With the load of the 570 and the heat it builds forget it.
No worries about killing the battery. With a burly 211 watts output, the 'Berg's stator could run the fan all the time with no ill effects. I have the lower temp BMW 90/95C switch on my FE450 and it is perfect. Per my Trail Tech readout, the fan comes on at 203F instead of 223F like the stocker and the bike stays noticibly cooler in the tough stuff as a result. Just do it.
Part number ATM 1435033 at NAPA, cost is about $20 and it is completely plug and play. Leave the rad cap on, undo the old, pop in the new and you will lose very little coolant.
2010 Husaberg FE450 (plated)
2001 Honda CR250 (out of state riding buddy's bike stored in CO for his annual epic ride) fills my need for the occasional 2 stroke hit!
2006 Yamaha FZ1
Duken4evr is offline   Reply With Quote
Old 06-02-2012, 08:22 PM   #2327
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,312
Originally Posted by loph917 View Post
welcome to the club knobbie! won't be long and blue is going to out number orange in the capital region!
Thanks Loph. Can't wait to get her dirty. Do you have any advice on any "must do's" on the bike for setup?
Knobbiethrower is offline   Reply With Quote
Old 06-03-2012, 04:25 PM   #2328
loph917
Beard Bros Racing
loph917's Avatar
Oddometer: 4,703
- radiator fan.
- engine ice instead of stock coolant (these two solved my overheat issues to date).
- bigger rear sprocket (the stock 42 sucks for the hills at enduro camp).
- make sure the fuel pump is the "new" version or it will fail (eventually).
- optionally replace the bash plate (the stock one is actually pretty good).
- barkbusters/hand guards.
- optional map switch (i haven't found a need).
- pull the rear tail pipe screen (this will open it up enough so that it's better all around).
- optionally remove the smog gear (mine is still there) but everyone else seems to have done pulled theirs.
- plug the crankcase vent thingy (that stupid contraption will snap off, damhik). goes with the above item.
- ride the shit out of it. it is possibly the most fun bike ever.
[ this space for rent ]
loph917 is offline   Reply With Quote
Old 06-03-2012, 04:29 PM   #2329
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,190
If you ride on bitumen or hard pack at all then get your wheels balanced otherwise the front end is like a pogo stick.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-03-2012, 05:03 PM   #2330
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,114
I checked my valve clearances today. They have yet to move (.15mm intakes and .16-.17mm on the exhaust). Not too shabby for 174 hours and 3588 miles
Mark
'11 KTM 250 XC (dual sported)
'05 KTM 450 EXC (dual sported)
OhioPT is offline   Reply With Quote
Old 06-04-2012, 10:03 PM   #2331
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,239
I put a bit of time in garage and installed a few more goodies (weight) to the Berg.
First was a blue bit that's been sitting on the workbench a few months, the Bulletproof Designs chain guard swingarm tabs guard.
Next up was to get the tools out of my backpack to a nice low location where there's empty space. I had seen another Berg rider do this and it has proven to be sturdy, so I copied it and installed a Agri Supply $5.00 Tool Tube . Bit of solvent washed the yellow ink right off of it. A bit of trimming and a few low profile bolts later it looks pretty tidy and out of the way IMHO.
I also wanted a higher bar position and a bit more dampening of the bars for my wrists but didn't want to use Flexx bars this time. I spotted a new shock absorber mount from BRP so I got this bundle and installed it, along with the BRP Hand Guard Mounts, which weigh the same as the Cycra clamps and bar clamps they replace, but more rugged.
cyborg is offline   Reply With Quote
Old 06-05-2012, 03:51 AM   #2332
OhioPT
Adventure Wannabe
OhioPT's Avatar
Oddometer: 1,114
Nice work! Really liking the tool tube. Is it out far enough to avoid contact with a knobby rear tire?
Mark
Old 06-05-2012, 05:45 AM   #2333
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
Originally Posted by cyborg View Post
I put a bit of time in garage and installed a few more goodies (weight) to the Berg....
That does look nice. With regard to the sub-mount, is the bar position adjustable forward/rearward? I welcomed the additional height with the BRP sub-mount I installed on one of my other bikes, but the bars were also moved back a bit at the same time.
Chris
ChR1s is offline   Reply With Quote
Old 06-05-2012, 07:16 AM   #2334
cyborg
cyborg's Avatar
Oddometer: 5,239
ChR1s
, the 2011 OEM top triples have 2 bar-clamp positions, forward and rearward. The new BRP submount can only use the rearward, so yes it moves the bars back 1/2" or so. Didn't bother me because I'm 5-10 and still fits well.
OhioPT
, yes the tool tube easily clears the knobby, in fact has more clearance than the exhaust can. No worries there, and nice to be able to use that big open space under there. A soft pack probably wouldn't survive in the same spot.
Old 06-05-2012, 08:01 AM   #2335
Sproat Sport
Oddometer: 64
Nice work Cyborg. I'm still blown away by that headlight mod you did too. Could you tell me where you got your ram ball mount mirrors? Thanks.
Sproat Sport is offline   Reply With Quote
Old 06-05-2012, 08:12 AM   #2336
BaronVonDarrin
BaronVonDarrin's Avatar
Oddometer: 638
can you buy these state side? I thought the only ting you could get from Husaberg here were the two strokes?
"Dammit Bobby"
Husqvarna 2011 te630
BaronVonDarrin is offline   Reply With Quote
Old 06-05-2012, 08:32 AM   #2337
ganshert
not sleeping
ganshert's Avatar
Oddometer: 8,064
Originally Posted by Sproat Sport View Post
...Could you tell me where you got your ram ball mount mirrors? Thanks.
here's a link to the web site for those mirrors
http://www.doubletakemirror.com/
I've been running them for a couple of seasons now and they're great. You can actually see behind you and they are almost impossible to break.
ganshert is online now   Reply With Quote
Old 06-05-2012, 08:39 AM   #2338
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,212
You can get a small discount on the mirrors at http://www.dualsportarmory.com/index.php they are in Vendors and offer an inmate discount.. I think the code is ADVrules. I have them on my DRZ and they are great.. I could use a little more side clearance to see over my shoulders... but overall they are outstanding.. and Neduro is an inmate and Dakar finisher from last year.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 06-05-2012, 08:40 AM   #2339
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,212
There are still lots of 2011 leftovers around and nice discounts.
Old 06-05-2012, 08:43 AM   #2340
ganshert
not sleeping
ganshert's Avatar
Oddometer: 8,064
That's one of the beauties of these mirrors, you can customize by swapping out different length RAM arms. I used the long arms on 990 and the short arms on my 570.
Times are GMT -7.   It's 03:49 PM.
