Old 06-08-2012, 10:53 PM   #2371
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,263
Originally Posted by Cruz View Post
Couldn't use the MT 43 on my 390, clearance was far too close for me and the tyre fitter.
Using a Maxxis Dualmaxx instead and so far it has been excellent compared to a 606 and the oem Six Days tyre.
http://www.maxxis.com/MotorcycleATV/...maxx-Rear.aspx
Can somebody measure and see if the FE570 swingarm is a little longer than the FE390? Maybe in the specs hmmm... Since the MT43 seems to fit on the 570's but not the 390's.
Those Maxxis look pretty good. May try those next.
cyborg is offline   Reply With Quote
Old 06-09-2012, 01:14 AM   #2372
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,268
You would think they would be the same.
There was room with the MT 43 but not for mud, picked up rocks or crap in the tyres or possible shape change of the tyre. I didn't try a longer chain though, just what was standard on the bike.
There is heaps of room with the Dualmaxx fitted.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-09-2012, 03:57 AM   #2373
LukasM
Oddometer: 5,427
Finn,
The guys and I all used the CV4 blankets, and we had no problems with them at all. They seemed to work great, even idling the bike at higher RPMs (to create enough electricity for winch and fan) with no air flow through the rads for longer periods it did not overheat or boil the fuel once.
Clif,
390/450/570 all use the same swingarm, in fact it's the same basic casting as all non-linkage 125-530 KTMs have been using since 2008 (only the inner width gets machined differently, the XC4 engines are wider than 2 strokes etc). One of my other bikes has a Berg 570 swingarm in an 08 505 XC-F frame with a 06 450 RFS engine and it bolted right in and is the right length, with the right rear shock pickup point... gotta love the KTM parts bin system!
I don't think there is anything special about the MT43 in the 390/450/570 application that would prevent it from fitting properly as long as you go with the right chain length and sprocket combination.
LukasM screwed with this post 06-09-2012 at 04:04 AM
Old 06-09-2012, 04:05 AM   #2374
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,268
Lukas, did you have your header pipes ceramic coated?
xronly
Old 06-09-2012, 04:10 AM   #2375
LukasM
Oddometer: 5,427
Nope, didn't get around to it. Walter's and my headers were stock, Barton wrapped his with DEI tape. I am sure it can only be an improvement but so far it has not been necessary.
Old 06-09-2012, 08:22 AM   #2376
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,302
Here you go:
Thanks for the reply Lukas, I thought it was you but was obviously mistaken.
Lost Rider is offline   Reply With Quote
Old 06-09-2012, 01:16 PM   #2377
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,326
Got the 570 out for a solo ride for a few hours this morning west of Las Vegas before the heat got too bad.
Here's a few pics...
Love my Berg!
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 06-09-2012, 02:38 PM   #2378
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,339
Originally Posted by loph917 View Post
- radiator fan.
- engine ice instead of stock coolant (these two solved my overheat issues to date).
- bigger rear sprocket (the stock 42 sucks for the hills at enduro camp).
- make sure the fuel pump is the "new" version or it will fail (eventually).
- optionally replace the bash plate (the stock one is actually pretty good).
- barkbusters/hand guards.
- optional map switch (i haven't found a need).
- pull the rear tail pipe screen (this will open it up enough so that it's better all around).
- optionally remove the smog gear (mine is still there) but everyone else seems to have done pulled theirs.
- plug the crankcase vent thingy (that stupid contraption will snap off, damhik). goes with the above item.
- ride the shit out of it. it is possibly the most fun bike ever.
Thanks for the tips...
When you state "REMOVE THE SMOG GEAR" does that mean all of it, including the junk behind the left side rear side panel?
Knobbiethrower is offline   Reply With Quote
Old 06-09-2012, 03:36 PM   #2379
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,302
Very nice photos Larry!
Old 06-09-2012, 08:25 PM   #2380
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,268
Probably worded that incorrectly. 'Wouldn't' instead of couldn't as the clearances were too close and it is always muddy and clay where I ride.
xronly
Old 06-10-2012, 12:35 AM   #2381
Knobbiethrower
ADV in ADK
Oddometer: 1,339
Seek and you shall find...answers on pg 42......
Old 06-10-2012, 01:36 PM   #2382
YamahaTN
Oddometer: 30
Got a fan kit install question and trying to search for anything on this site is hopeless......always get error messages. I am not readily seeing the connectors for the fan or the sensor. Can anyone who has installed one point me in the right direction?
YamahaTN is offline   Reply With Quote
Old 06-10-2012, 02:06 PM   #2383
YamahaTN
Oddometer: 30
Nevermind..........I found it. Good thing there is not a rattlesnake lose in this bike.
Old 06-10-2012, 02:25 PM   #2384
Knobbiethrower
ADV in ADK
Oddometer: 1,339
Where was it hiding ?
Old 06-10-2012, 06:35 PM   #2385
YamahaTN
Oddometer: 30
We at one point it was hiding in my hand. I had hold of the dumb thing and thought it was the wrong cable.
Times are GMT -7.   It's 06:42 AM.
