Old 01-31-2011, 04:56 AM   #226
Zombie025
Oddometer: 109
Fuel pump failure?
Hi Berg-Fans,
my 09-FE570 developed some problems after passing this minor jump:
THe Engine stalled in the same way like my 990 Adventure did when the fuel pump was faulty, breething sound from the filter and rapidly slowing down revs of the engine (as if no fuel would be delivered)
Surprisingly this bigger jump with harder landing was no issue at all
This repeated on several rounds on the track. I've got the feeling, when jumping from down to up (like a "parabel"), maybe the fuel (tank was half full) goes up and the pump is sucking air? Might this be a reason or is this not possible? I hope i don't have to replace the pump, since the warranty is already expired.
Please help me with good advises for self assistance, as the next dealer is 2 countries away...
Greetings
Zombie025 is offline   Reply With Quote
Old 01-31-2011, 08:13 AM   #227
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,640
Originally Posted by Zombie025 View Post
Hi Berg-Fans,
Greetings
You should go to Husaberg.org - lots of racers there.
Two thoughts though; maybe loose electrical connection to the pump (this has happened to others).
If the fuel pump is momentarily sucking air, I don't think it would affect the EFI as it probably has enough fuel to continue. Many others have jumped their bikes without problems. However, there are foam kits and such that you can put in tanks to keep the fuel from sloshing around so much.
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 01-31-2011, 03:35 PM   #228
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 876
Originally Posted by trailtrick View Post
so the tank fills from the main tank correct??.
how long you have to weight to is full did you no ??
Im thinking on getting a 2011 570 and sale my ktm 2007 rfs 450.
I have a 09 450 for few months went testing suspenson on theme and like it ,Now the 570 is street legal i maybe pick one up and want to no how this subframe tank works ,Thanks
Javier,
The tank fills pretty quickly, off the main tank. 70 degree offers them for a pretty good deal, much better than the safari tank option as it is too wide in the knees. The 70 degree doesnt weigh in that much as I have not noticed the weight before. You will really like the 570, theres a new dealer in Moorpark that has them up for sale...
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 02-01-2011, 10:38 AM   #229
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,314
Originally Posted by tahoeacr View Post
Darn near just as fast as the stocker. I'm going to come down there in two weeks. Let's go ride and you can see.
I will find myself next week i guess , come on down i want to heard the sound o the fmf muffler ,how much louder over stock on this bike ?
Got a 11' demo bike yesterday .
"Vive tus sueños en vida, no la vida en sueños.
Kampale Moto Ranch
Bed and Breakfast
mototours/uruguay south america
trailtrick is offline   Reply With Quote
Old 02-01-2011, 11:30 AM   #230
tahoeacr
tahoeacr's Avatar
Oddometer: 2,212
Stock is real quiet. The 4.1 is kinda loud. Not obnoxiuos, just loud. I also have a Yosh muffler that has a better sound when cruising as it is deeper and a little quiter but louder when on the gas. I have a Sound meter but it needs to be calibrated. Know anyone in the Forestry with a way to calibrate it?
Saturday is dyno for the FMF system with the User Tool map.
I still run stock gearing. Don't want to change to a 51 cause I like hillclimbing too much.
I do have the quiet insert for the 4.1.
tahoeacr is offline   Reply With Quote
Old 02-01-2011, 12:11 PM   #231
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,314
I have a sound meter calibrate for the forest service so we can calibrate yours from that.
The 11 come with 14/42 i want to try a 14/50 or 51 for wath i ride i think 14/50 be ok ,my 450 exc hasa built motor and run 13/48 and works good on the tie stuff.
Rode it this mornign on some single track but the gearing is off with the 42 on the back
Kampale Moto Ranch
Bed and Breakfast
Old 02-01-2011, 03:35 PM   #232
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,054
14/42 is the supermoto set up....
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 02-01-2011, 03:48 PM   #233
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,500
Apparently, it's also the "get through the federal sound test" set up.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Old 02-01-2011, 04:31 PM   #234
trailtrick
goat trail rider
trailtrick's Avatar
Oddometer: 3,314
yes same for the dual sport model ,bike runs good ,hope to have it ready the ride by thursday
Kampale Moto Ranch
Bed and Breakfast
Old 02-01-2011, 05:09 PM   #235
nobrakes
nobrakes's Avatar
Oddometer: 3,369
It took a little head scratching and a call to GDR but I finally got this sucker out.
It's replacement - ceramic coated, supposed to reduce the heat under the seat and tank by a few hundred degrees:
“It’s habits that make us, and habits that break us.”
'12 KTM 350 EXC-F
'12 Beta EVO 2
nobrakes is offline   Reply With Quote
Old 02-01-2011, 09:13 PM   #236
TLtrials
TLtrials's Avatar
Oddometer: 274
Wrenching on 70 degree tank '11 FE 570 S
Here are some photos of the 70 degree tank install, evap can removal, exhaust air valve removal, and fan kit install.
Disassembly:
Side note (jumping ahead a little) - any 'berg owner should check this, zip tie up the wiring to keep it off the shock body.
Stock:
Fixed:
Evap can, unhook hoses, plug vacuum port on engine, remove hoses tie in new vent system with 70 degree tank:
Fresh air pump for exhaust, remove an plug hole with supplied bolt:
Fan install:
70 degree tank install:
remove stock fuel pump cover and install supplied 70 degree unit:
Assembly of tanks, running vent lines, etc:
Yes, it is a little more involved than slapping a IMS/Acerebis 3 or 4 gallon tank on a KTM/Husky/Hon/Suz/etc... but it is not a bad project, the directions were good, and everything fit close for an aftermarket set up.
Planning on getting to the HDB handguards this week too. Also, hopefully it will be nice enough Sunday to get it out and see how the tank works.
TLtrials is offline   Reply With Quote
Old 02-01-2011, 09:28 PM   #237
Florida Lime
Oddometer: 2,500
Thanks for the walk through. Surprised you didn't video it though - I've watched all of yours lately - both the FE450 offroad and KTM 990 on road.
Be a shame to do all that work, and not be able to ride it.
Supposed to be 80 degrees here tomorrow.
How long did it take you to do everything shown ?
'10 Husaberg FE570
Florida Lime screwed with this post 02-01-2011 at 09:34 PM
Old 02-01-2011, 09:52 PM   #238
NCMX1
The Yeti
Oddometer: 75
Javier
Got your tank coming!
NCMX1 is offline   Reply With Quote
Old 02-02-2011, 09:49 AM   #239
Tarheel Wheeler
Around
Tarheel Wheeler's Avatar
Oddometer: 3,648
Nice work TL. I'll get mine yup to you for my install.
Oh, Coco loves the DRZ.
Adversity is the state in which man most easily becomes acquainted with himself, being especially free of admirers then. John Wooden
"Get to riding or get to dying"...http://www.youtube.com/watch?v=K_T41kJm-PE
Tarheel Wheeler is offline   Reply With Quote
Old 02-02-2011, 11:01 AM   #240
KayaKTM OP
Day trippin'
KayaKTM's Avatar
Oddometer: 405
Fan kit?
TL, was the fan kit as easy as it looks? just replace the plug on the back of the radiator, mount the fan and plug it in? is that it?
also does anyone have pics or info on installing a horn? i've got 1 but havn't been able to find any info on line about installing it, or where the wiring is.
thanks!
2004 KTM 950A
2010 Berg 390 (Tagged)
Religions change; beer and wine remain. Harvey Allen
KayaKTM is offline   Reply With Quote
Times are GMT -7.   It's 01:46 AM.
