Old 06-18-2012, 02:26 PM   #2401
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,314
Originally Posted by UngaWunga View Post
Does the FE390 use the same front/rear sprockets as recent KTM models? I have a couple of KTM sprockets, haven't picked up my Husa yet. Just wondering. I've heard the wheels swap.
Also, what are the stock sizes and "recommended" sizes?
Same as KTM
Knobbiethrower is offline   Reply With Quote
Old 06-18-2012, 06:34 PM   #2402
sect8dr
ride them all
Oddometer: 232
Fs 570
How would the supermoto version do as a daily rider, no highway, just two lane? How reliable is the engine? How are the maintenance intervals? Any info would be great.
sect8dr is offline   Reply With Quote
Old 06-19-2012, 02:19 AM   #2403
LukasM
Oddometer: 5,425
What's your daily mileage?
The engine is very reliable, but it's obviously a light weight high performance machine and not some understressed KLR lump, so it requires more maintenance. I'd say 1000-1500 km oil changes are ok if you don't overheat the oil, maybe even 2000 kms in a pinch but by then it will not lubricate as well. Engine rebuilds... nobody has enough kms to know yet, but Inmate Beta is riding his 570 from Chile to Montana, currently at 15,000 kms and no issues so far. I'd guess between 20,000 and 30,000 kms you will at least want to change your piston and rings.
If you can live with that, there won't be many bikes that are more fun in the city and country roads than a FS570.
Old 06-19-2012, 04:35 AM   #2404
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,087
Hey Lukas, are you or Walter still going to do anything with your 570's to make them a light adv bike or are you happy with how you had them set up in South America?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-19-2012, 05:14 AM   #2405
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Started having fuel boiling issue all of a sudden. I replaced the injector but I'm wondering if the pump is on the way out. It's the black cap style that supposedly is the bad one? After I ride it for a bit, the idle gets high and it feels hot, if you know what I mean. I'm going to check the fuel pressure tonight and see what I'm getting. Any words of wisdom? I've got a brand new CA Cycle works pump sitting on the shelf.
Just say'IN
crankshaft is offline   Reply With Quote
Old 06-19-2012, 07:43 AM   #2406
LukasM
Oddometer: 5,425
All 3 of us are going to add some fuel capacity, that is definitely too little stock. How we are going to get is not sure yet, we would love to have a rally style fairing with split front tanks and an underseat tank like the Berglund Dakar bike when that becomes available. If staying with the simple stock front then the 70 Degree Racing subframe tank is a no brainer - also subject to availability, and if needed a Safari front. Personally if I do a long trip like Barton I would also like to add an oil cooler for some additional capacity and lower temps/longer life.
What happens when you let it cool off Aaron, does it work again normally then? That would point towards the fuel pump, the older ones were built with the clearances too tight so they can seize up when hot.
Checking the fuel pressure when hot should give you a clear answer if that is the case here.
Old 06-19-2012, 07:58 AM   #2407
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
I sent the guys at HT Racing, they make the billet oil coolers for the KTM's, an email, suggesting they make one for the 570 as well.. their only reply was "LOL" I shit you not
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 06-19-2012, 08:41 AM   #2408
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 211
Originally Posted by OhioPT View Post
Nice work! Really liking the tool tube. Is it out far enough to avoid contact with a knobby rear tire?
Just an FYI, the tool tube will not fit as Cyborg has shown with a stock rear subframe. He has a 70* rear subframe/tank.
Well, maybe I shouldn't say "will not" because I guess with some creative "trimming" of the stock rear subframe it might fit but.......
R1
Husqvarna FE250...Street Legal
Rider1 is offline   Reply With Quote
Old 06-19-2012, 09:15 AM   #2409
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 211
I've put about 800 miles on an MT43 (FE570S) with a 13/50 combo. Reversed the chain adjusters and have about 3/4" (19mm) of clearance as shown here:
IMG_1121
IMG_1123
R1
Old 06-19-2012, 12:35 PM   #2410
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
Reversed the chain adjusters? Is that common practice? I have a brand new MT43 mounted on a rim with a Cush hub that I was going to try and istall this evening.. I have 13/48 currently but could put the 50 on if needed.
Old 06-19-2012, 12:46 PM   #2411
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 211
I don't know if it's "common practice" but it allows the axle to move further back in the slot giving room for the taller MT43.
I use the 50 tooth to compensate for the taller tire. Works good.
R1
Old 06-19-2012, 02:02 PM   #2412
nobrakes
nobrakes's Avatar
Oddometer: 3,368
Absolutely.
“It’s habits that make us, and habits that break us.”
'12 KTM 350 EXC-F
'12 Beta EVO 2
nobrakes is offline   Reply With Quote
Old 06-21-2012, 01:01 PM   #2413
frostyuk
frostyuk's Avatar
Oddometer: 274
Kriega Rack Loops
Just added these to my berg, i think it looks good will know better after a run :
(hope these pics come out they're on flickr)
http://www.flickr.com/photos/frostyuk/7415860764/
http://www.flickr.com/photos/frostyuk/7415860486/
http://www.flickr.com/photos/frostyuk/7415860648/
frostyuk is offline   Reply With Quote
Old 06-21-2012, 01:12 PM   #2414
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,209
Flikr is a PITA to post photos from IMHO.. you have to grab the HTML/BBC code from the "share" link..then in adv window here you have to click on the A/A button in the top right corner of your "new reply" window, to switch editor modes and then direclty paste the copied HTML/BBC code from Flikr.. did that make sense? It is the same way you direclty embed a YouTube video.
Old 06-21-2012, 01:51 PM   #2415
frostyuk
frostyuk's Avatar
Oddometer: 274
cool thanks for the tip
IMG00116-20120621-1545
IMG00117-20120621-1633
IMG00118-20120621-2021
IMG00119-20120621-2023
Times are GMT -7.   It's 09:34 PM.
