Old 09-09-2012, 04:01 PM   #2716
jtskir222
jtskir222's Avatar
Oddometer: 94
use dyna beads to balance.
check it out on utube. fixed my bike.
use them on all of my rides now. great stuff
jtskir222 is offline   Reply With Quote
Old 09-09-2012, 04:56 PM   #2717
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
You have to up your tire psi if you are on the road to keep the rim lock from making the tire bounce.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 09-09-2012, 05:14 PM   #2718
Sproat Sport
Oddometer: 64
I used dynabeads...didn't address my problem.
Sproat Sport is offline   Reply With Quote
Old 09-09-2012, 05:37 PM   #2719
Navin
Navin's Avatar
Oddometer: 8,366
Originally Posted by frostyuk View Post
Hi all
i have an issue that from about 38mph upwards i have a periodic vibration that builds up and then drops off, repeat etc. i've had the wheels trued up as much as can be done without replacing the rims, am running golden tyre 216Ns at about 15psi front and rear though changing to 22/29 respectively as per the manual doesnt noticeably improve things, i took the wheels to get them balanced and the chap said they were too far out for rim weights 150grm front and 210grm rear, am thinking a) try and balance the wheels with some spoke weights b) get lighter rim locks and c) change the tyres. am i on the right track or should i be looking elsewhere?
many thanks
If you can live with the higher pressures, delete the rim locks. I run none on a 950SE with full knobbies at 21-24 PSI and do not slip a tire on street or dirt, aggressive riding too. Been as low as 18 PSI too, but trust the 21 PSI more.
Navin is online now   Reply With Quote
Old 09-09-2012, 05:55 PM   #2720
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,963
AFTER you balance your tires
Brown Dog is offline   Reply With Quote
Old 09-09-2012, 07:07 PM   #2721
Pundy
Oddometer: 339
Originally Posted by Baja Dad View Post
imo: 140/80/18
I'd like to, since I have some from my 690, but I'm already getting some rub on my exhaust with the 110/100. Is anyone else rubbing with the smaller tire?
Pundy is offline   Reply With Quote
Old 09-09-2012, 07:32 PM   #2722
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,311
I shimmed out the exhaust on mine by about 1/2 inch with a bunch of flat washers (and longer bolt). No more exhaust rub...
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 09-09-2012, 11:36 PM   #2723
Pundy
Oddometer: 339
Are you running the 140/80?
Old 09-10-2012, 01:10 AM   #2724
Hoots
Hoots's Avatar
Oddometer: 1,584
Hi all
many thanks
Get lighter rim locks ...
Need a reasonable amount of counter-balance for any rim lock, but they shouldn't be so heavy as to rule out the use of rim weights ...
Hoots is offline   Reply With Quote
Old 09-10-2012, 10:14 AM   #2725
rensho
Oddometer: 182
Motion Pro makes nice light rim locks. Make sure you only buy the size needed for your rim width.
I've seen many people run 20psi without rim locks, and I'm headed that way.
rensho is offline   Reply With Quote
Old 09-10-2012, 11:14 AM   #2726
frostyuk
frostyuk's Avatar
Oddometer: 274
thanks for the feedback guys, i run full nobblies on my xchallenge at 15 psi with rim locks and no issues at all and no balancing needed, different tyres tho. first thing i'll try is removing the rim locks and road ride and see if that is the issue, if i still have the problem am guessing its the tyres so i'll move to some others.
frostyuk is offline   Reply With Quote
Old 09-10-2012, 04:31 PM   #2727
rensho
Oddometer: 182
Secret compartment key
From FE570S
From FE570S
From FE570S
From FE570S
From FE570S
Old 09-13-2012, 06:23 PM   #2728
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,212
Baja Designs Squadron LED light..KTM kit.. goes right in with very little effort. Hardest part was getting the freaking rubber straps off to put the extenders on. 3600 lumens, high and low beam... super bright, aluminum.. made in the USA. A little pricey, but makes night riding a real possibility. Please excuse the dirty bike and the dead bug.. or bird poop..whichever it is
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 09-13-2012, 07:37 PM   #2729
BogeyMan
BogeyMan's Avatar
Oddometer: 454
Extenders? Got a pic? Tell me more.
When I read that, I assumed that you mean some doodad or thingumyjig that allows the headlight mask to sit an inch or two further forward? Am I correct? Does it only move the top or does it move the mounting pins at the bottom too?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 09-13-2012, 08:32 PM   #2730
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,212
Yeah.. you just pull the rubber straps from the original holes, mount the hard plastic extenders that come with the kit and that keeps the light away from the wire bundle.. also gives room for the needed dimmer switch if you want to keep high/low beam capability. The extender only pushes out the top of the headlight mask, you keep the bottom tabs in the same place. This thing is SUPER bright, 3600 lumens advertised, and I dont doubt it.. it lit up my entire block.
sorry no pic but it is really simple.
Times are GMT -7.   It's 08:02 AM.
