Old 10-29-2012, 10:36 AM   #2911
BogeyMan
BogeyMan's Avatar
Oddometer: 455
Question
On the subject of oil changes... the manual says 1.35l (that's 1.43 qt) - does anyone know how much additional to add if I have a Rekluse fitted (with the extra clearance clutch cover)? I can't see through the dark glass of the oil level sight glass. Whose idea was it to use dark glass?
Next question...
Couple of weeks ago I took a little "dirt nap" (actually more of a "rock nap") - and the bike impacted on the lower section of the right-side radiator. Of course, I had no guards fitted . I suffered minor damage to the radiator - bent, but not broken or cracked. I carried on riding for the remainder of that day's ride and all seemed well.
So, fast forward the this past weekend... I was checking things over before loading up for a ride on Sunday. As soon as I turned on the ignition (bike is totally cold, just wheeled out of the garage), the fan started up. Apart from that all was well. So, for the meantime, I just took the fuse out of the fan and once again all was well for the day of riding.
Any thoughts/suggestions? Broken temp sensor? Wasn't there some earlier discussion on temp sensors that fit the 570's? I'l go have a search, but if anyone can provide a direct pointer, that'd help.
Does anyone have any recommendations for radiator repair/straightening (preferably in SF Bay Area)?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 10-29-2012, 11:22 AM   #2912
rensho
Oddometer: 186
I wonder if your temp sensor wires got bent together and are now touching. It is the thing at the bottommost outside corner of the right rad.
I installed a sensor from a 89 bmw325, which turns on the fan 10F sooner.
If you want to buy another rad, check the cross ref on the part number. it has to be a ktm rad, which should be no problem to get on flebay.
rensho is offline   Reply With Quote
Old 10-31-2012, 03:36 PM   #2913
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,274
It seems a common consensus that the cam chain tensioner on the bergs is not up to doing its job that well. There are at least two 'better' aftermarket ones out there. One that is a manual tensioner with a ratchet, and one that uses hydraulic pressure (similar to the stock one) but also has a ratchet.
Is there any strong evidence which one out there I should buy for my FE450? It's up to a 1000kms now and I probably should think about getting a better CCT for it.
FE450.
XT660R
Blakduk is offline   Reply With Quote
Old 10-31-2012, 03:43 PM   #2914
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
I'm not saying which one you should get (Dirt Tricks or the manual DJH unit), but I installed a DT CCT on my friend's bike. Here is the before and after. Dramatic to say the least. Her FE450 has 100 hours on it at the time the CCT was swapped out. My other frien's 530 is due, but it doesn't sound anything as bad as this one. His usually smartens up after a minute or two.
Before
After
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 11-01-2012, 05:56 AM   #2915
frostyuk
frostyuk's Avatar
Oddometer: 275
i spoke to my berg dealer about the cct apparently there were two versions of the automatic cct on the early ones the adjustment increments were too large hence the rattles, the later ones were much smaller and less of an issue. the one on my 09 fe450 had been replaced with the newer version and sounds fine to me ymmv
frostyuk is offline   Reply With Quote
Old 11-01-2012, 06:55 AM   #2916
SRG
SRG
SRG's Avatar
Oddometer: 1,326
So, if I have a 2010 FX450, do I have the updated CCT?
SRG is offline   Reply With Quote
Old 11-01-2012, 03:00 PM   #2917
Blakduk
Blakduk's Avatar
Oddometer: 1,274
This is extraordinary. Obviously the original tensioner was not working AT ALL. The chick is pretty nice too.
I dunno about the dealer saying that post 2010 bikes had a better tensioner. My local dealer is still recommending putting in an aftermarket tensioner.
Before
After
FE450.
XT660R
Old 11-02-2012, 12:44 AM   #2918
Zombie025
Oddometer: 109
Time to say Goodby, the replacement is younger, weighs less... . I spent a quite nice time with youplease sign the divorce papers
Zombie025 is offline   Reply With Quote
Old 11-02-2012, 01:53 AM   #2919
frostyuk
frostyuk's Avatar
Oddometer: 275
comparing the parts fiche for my 09 fe450 and the 10fx450 the part numbers are different so i would "guess" so. On the 10 fe450 fiche there is also an * next to the part number so maybe it changed during that model year ???
well thats what they told me when i asked about putting a manual cct on, seeing as they race them, am sure would be happy to take money off me and seeing as mine sounds fine i havent touched mine
Old 11-02-2012, 03:03 AM   #2920
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
I have read that the automatic tensioners can ratchet to tight when the oil is cold. I had a manual DJH tensioner and was happy with it. http://www.djhcyclesport.com/husaberg-parts.html
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 11-02-2012, 03:27 AM   #2921
frostyuk
frostyuk's Avatar
Oddometer: 275
wolfman carry all
Any one used one on the berg ? thoughts ? opinions ?
thanks
Old 11-02-2012, 06:12 AM   #2922
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,775
thanks
Yes....I have it and use it on longer outings.
You can see it in action here: Bergs Over the Rainbow
Mounted above the headlight. Works great!
The smallest Wolfman tankbag fits nicely on my Berg too.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive screwed with this post 11-02-2012 at 06:27 AM
HighFive is offline   Reply With Quote
Old 11-02-2012, 08:40 AM   #2923
frostyuk
frostyuk's Avatar
Oddometer: 275
thanks HF i noticed that it was there some days but not others and i thought that cyborg mentioned that you had used a bag on the front but that it had upset the handling and you had taken it off again, wasnt sure if that was the carry all, glad to hear it worked well as i have plans for one in the near future
bw
Ian
Old 11-02-2012, 08:40 AM   #2924
Baja Dad
Baja Dad's Avatar
Oddometer: 2,042
my Berg ready for a little fun!!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 11-02-2012, 09:22 AM   #2925
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,329
Nice!
The prep of my Berg for the Mexican 1000 will begin soon. I'll post up pics along the way...
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is online now   Reply With Quote
Times are GMT -7.   It's 03:59 PM.
