Old 11-23-2012, 08:05 AM   #3061
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Originally Posted by BogeyMan View Post
Finn - any particular reason you went with the 140 over the 130?
Because the MEFO Super Explorer only comes in a 140 and 150 size. Just like the 908RR only comes in 140.
The MEFO Explorer does come in a 130, but is a completely different tire and should not be confused with the SE.
Lost Rider is offline   Reply With Quote
Old 11-23-2012, 09:10 AM   #3062
Baja Dad
Baja Dad's Avatar
Oddometer: 2,035
I also run a 140/80/18 Mich Desert Tire on my bikes!
I have been since back in 1986 I like the way it feels and tracks
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 11-23-2012, 06:01 PM   #3063
ribmtrider
Oddometer: 131
2011 fe390
I am looking at a 11 FE390. Just out of curiosity, how come there are so few options for a O/S fuel tank? Does it have to do with the FI? I like the subframe tank option, it looks sweet.
ribmtrider is offline   Reply With Quote
Old 11-23-2012, 06:15 PM   #3064
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,213
How many options do you want? There is a subframe tank, the Safari front tank and the Safari rear tank.. that is more than most other bikes have?? They are all just super expensive.. and that has to do with the limited number of 70 degree bikes sold, the complex molding needed to make the tanks fit, and the fuel injection.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 11-23-2012, 06:33 PM   #3065
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,014
Well let's see...
The sub frame tank is unavailable and the Gen 1 versions leak
The rear Safari tank sits too high...prevents the use of luggage...and looks like crap....
The front Safari is the best option...but is too big and heavy for many.......although I liked mine...
I see ribmt's point....
KTM 1190R...Adventure Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 950SE......Desert Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 11-23-2012, 06:49 PM   #3066
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,213
Originally Posted by Nowwhat View Post
Well let's see...
yeah but what else is available for other bikes? The front safari tank is essentially the same front tank that every other bike uses??? the only thing missing is low cost options.
Old 11-23-2012, 07:15 PM   #3067
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,212
Not really. The front Safari tank is an over top tank, a fair bit different to what is available for say, the KTM EXC bikes which use a standard type of fuel tank and a number of manufacturers makes a number of different size tanks to suit nearly every occasion. The oem tank is taken off and replaced with a larger aftermarket tank.
The 2013 Bergs/KTMs will have a bigger and better range of tanks available than the 70 degree Bergs ever did.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is online now   Reply With Quote
Old 11-24-2012, 08:57 AM   #3068
Baja Dad
Baja Dad's Avatar
Oddometer: 2,035
The 2013 Berg is just a Yellow /Blue KTM !!!!!!!!!!!!!!!!!!!!!!!!!
the 70% is a HUSABERG not a painted over KTM.
I love my Safari front tank,
Old 11-24-2012, 09:00 AM   #3069
frostyuk
frostyuk's Avatar
Oddometer: 274
ok did some more work on my setup today
first added the computer protector:
IMG00177-20121124-1107
fits just over the mask:
IMG00175-20121124-1107
fuzeblock will fit here ...just (with 17mm bar risers):
IMG00179-20121124-1113
but its tight
IMG00180-20121124-1113
and a little exposed through here:
IMG00181-20121124-1117
wire up the switches and leds
IMG00183-20121124-1345
and it looks like this with the std cable lengths: btw it weighs 350g like this:
IMG00182-20121124-1345
back on the bike:
IMG00184-20121124-1406
with the connectors on the std length cables the fuzeblock doesnt fit nicely anymore, it would be ok if i raised the bars higher but that wont be good for me ergonomically, attached to the back of the mask fits but it is tighter than i would like so i think i may have to move the mask forward, i've emailed paul at hdb to ask about the kit lukas has but no reply as yet. The brake hose has had to come out of its guide by the bottom triple clamp, moving the mask forward might make that worse so i may have to get a longer brake hose as i was planning on using a wolfman carry all on the mask, i'll wait and see about both of those though
frostyuk is offline   Reply With Quote
Old 11-24-2012, 02:32 PM   #3070
TLtrials
TLtrials's Avatar
Oddometer: 274
Well let's see...
I have a first generation 70 degree subframe tank, on the bike for roughly 1 year and 10 months. I had to replace the standard teflon tape (white) at the vent with gas resistant teflon tape (yellow, and available pretty much at any hardware store). No leaks so far. I am sure it is like any small niche market product, there will be a few flaws and to work through.
Yep, the 70 degee 'bergs are not as easy as most bikes to buy an IMS/Acerbis/Clark and slap on for extended fuel range.... but they are way cooler.
It has been kind of funny because I was worried about the fuel range when I sold my big tanked DRZ for the 570 Husaberg. Then I have found with having the 70 degree tank, is that every time a group get's together for a ride, we end up being at a station or a planned fuel stop before I am ever close to needing extra fuel because someone else has a stock tank and needs gas.
TLtrials is offline   Reply With Quote
Old 11-24-2012, 04:13 PM   #3071
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Looking real nice frosty, tidy work you did there!
Thanks for posting, it feeds my imagination to help get mine setup just right for me.
I have some shiny HDB bits and some supplemental Photon Cannon LED lights on order to add, will post up when I get it all sorted.
As for the Safari front tank, personally I don't find it too big by any means, it doesn't interfere with riding in any position for me. I was actually pleasantly surprised at how light it is empty when it arrived too, even with the hardware. When it's full I don't find the extra weight distracting at all, but that's just me. It just works, you get past the thoughts of it's cost every time you pass a gas station without stopping.
I hate to hike in riding boots so maybe I'm a little partial to carrying the extra fuel at any cost.
A bulletproof lightweight high performance ADV bike that's under 300 pounds when fully loaded with camping gear and fuel with a solid range of 200 DS miles = priceless.
And it's not ORANGE.
Old 11-24-2012, 05:01 PM   #3072
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,014
A bulletproof lightweight high performance ADV bike that's under 300 pounds when fully loaded with camping gear and fuel with a solid range of 200 DS miles = priceless. ?????/
What bike is that?.......
I wish....
With the front Safari...you have added 20lbs in fuel and Tank........and with my front safari tank...I have been bone dry at 150 miles....
Old 11-24-2012, 05:28 PM   #3073
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
You ride harder than me.
What's are our bikes weight? says 256 pounds in service manual, has anyone ever confirmed that?
25 pounds of fuel/tank, 20 pounds of camping gear/tools for me, 5 pounds of HDB guards, GPS, etc.
Shaved 7 pounds off with a Shorai.
I guess I should have said around 300 pounds.
Still a lightweight ADV bike, for me it feel like a mountain bike with a big engine.
10,000+ miles and going strong, valves still in spec from when I bought it.
Old 11-24-2012, 05:41 PM   #3074
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,014
bwahahahaha,,,I probably ride dumber than you...
The 570 is 271lbs naked with the stock 2.25 gallons on board...add the extra of the Safari and you are into the 290's...
Unless your Berg had 2 batteries you saved just under 3lbs with the Shorai...(stock battery 4.5ish pounds)...
Old 11-24-2012, 07:07 PM   #3075
TLtrials
TLtrials's Avatar
Oddometer: 274
fuel mileage
You both may be correct on the fuel mileage... I have seen both extremes with my two, depending on how they are run.
I have been practically on fumes at the end of a 45 mile hare scramble on my FE450 with the stock tank. I think I put right at 2 gallons back in it after the race.
Then on my 570 with the stock+sub frame tanks, I have gone 80-85 miles in dual sport duty (but still more trial than road), filled up around 2 gallons.
Times are GMT -7.   It's 12:51 AM.
