Old 11-24-2012, 08:04 PM   #3076
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,324
Absolutely, I think we're all in agreement.
I've seen 25 MPG or less in knarley single track or fast sustained highways runs going into a strong headwind and everything in between up to flat 65 MPH paved/gravel roads where I get over 50MPG on average with the ignition switch on wild.
That's with 14/45 gearing on the top end of good milage when traveling and 13/48 on the low end of MPG of "trail" riding.
I'm an Adventure Rider who for the most part is consciences of getting the most out of my fuel milage, tires and other wear items until I can get back home or into places with resources while still having fun along the way.
More often than not, when needed I can squeeze 50 MPG by controlling my wrist with constraint in most places I find myself when packed up camping and with 14/45 gearing. Like I said, I hate hiking in Sidi boots.
When I plan on riding tight stuff unloaded I gear it accordingly and with the Safari I am looking forward to having at least a 100 mile range no matter how hard the trail, but that's not my specialty or preferred type of riding by any means. If I'm going to beat on the bike, I want a different time zone, or landscape in one day.
That's the beautiful thing about the Husaberg FE, it does a wide range of type of riding very well for various riders depending on the setup and needs of the individual, my overall point is the Safari front tank rocks!
Looking forward to someday getting a 70 tank if they ever get their shit together. The I'll have about a 310 pound loaded ADV bike with a 250 mile range and will find places to utilize it.
Lost Rider is offline   Reply With Quote
Old 11-25-2012, 09:11 AM   #3077
Sproat Sport
Oddometer: 64
LEDs not working
High-beam, Low-fuel and signal LEDs no longer working...can't see why. (FI LED seems to work though...flashes once at startup). Took off the mask and poked around in there...connections seem good....all looks good to my dim, uncomprehending eyes. Fuses (under seat) are all fine. I'm a little handicapped in the electrical dept., so I may just leave it as is....but the biggest thing I've missed so far is the low-fuel indicator...that's an important one for when I'm out in the bush.
Sproat Sport is offline   Reply With Quote
Old 11-25-2012, 10:19 AM   #3078
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,324
Did you check the lamps in the signals? Every once in a while mine stop working and I just need to push the lamp back into its socket, inside the indicators.
Old 11-25-2012, 10:34 AM   #3079
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,217
Anybody have issues with their turn signal switch? Mine has always been funky, and now it doesnt want to switch off the signal at all.. really dont like the push to cancel thing.. I am going to tear it apart and see what I can see, but I am considering just replacing it with a Sicass Racing component and do away with the wanky set up.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 11-25-2012, 11:13 AM   #3080
Sproat Sport
Oddometer: 64
the signals themselves work....just not the green signal indicator (to tell you that your signals are turned on)...along with the high-beam and Low fuel indicators. Just the dash indicators that aren't working.
Old 11-25-2012, 11:59 AM   #3081
WetSideRider
Oddometer: 1,211
I'd guess a grounding issue. If you have the repair manual, take a look to see if these lights share a common ground. I have the Cyborg special wiring job, and I have the turn signals grounded behind the light mask. I'm not sure where the ground is for the high beam indicator. I've had a problem with my ground on the turn signals, so I know it's possible.
WetSideRider is offline   Reply With Quote
Old 11-25-2012, 01:42 PM   #3082
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,324
I guess I should have been more specific of used better terminology, like usual. (:
I am talking about the signal/FI/high beam/fuel dash lights. At least on mine they are not LED and there's a tiny lamp in there that can come loose.
Good luck!
Greetings from the trail on lunch break!
Old 11-25-2012, 01:54 PM   #3083
Sproat Sport
Oddometer: 64
If there's anyone using the wrong terminology, it's me. Thanks for the suggestions.
Old 11-26-2012, 06:08 AM   #3084
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,774
The Dash Indicator Lights have individual bulbs (tiny) that push/slide into the indicator housing from beneath. My blinker indicator bulb has broke or burned-out twice. Either they are poor quality bulbs or maybe I ride too hard....donno. Got tired of replacing it, so I just go without a dash indicator for turn signals.
The other bulbs (hi-beam, low-fuel) have never pooped out....they are still just fine.
KTM & Berg dealers usually have these little bulbs in stock.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 11-26-2012, 01:44 PM   #3085
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,265
HF, the blinker indicator is a filament bulb IIRC and some of the others are LED and will likely never burn out. Easy to check, just pull them out the bottom and look.
cyborg is offline   Reply With Quote
Old 11-27-2012, 01:02 AM   #3086
frostyuk
frostyuk's Avatar
Oddometer: 275
warning lights
I think it depends on the model year, on my 09 they are all bulbs not leds
frostyuk is offline   Reply With Quote
Old 11-28-2012, 01:24 AM   #3087
frostyuk
frostyuk's Avatar
Oddometer: 275
i didnt get much further at the weekend with my electrical setup as i ran out of time and connectors
however i've decided that the fuzeblock will fit ok behind the mask, and in preparation for this i've tidied up the wiring and cable routing behind the mask and now routed all the cables up into the gap created by raising the comp higher. The cables are less stressed and more out of the way so more space to play with. hope to progress more at the weekend. i did email exchange with paul at hdb, he can make more of the headlight relocator brackets that Lukas has but he hasnt had much demand for them so they're not on his site at the moment.
IMG00185-20121125-1746
Old 11-28-2012, 09:41 AM   #3088
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,422
Just did LA Barstow to Vegas on the 390
Seat Concepts came through with the radness
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 11-28-2012, 02:43 PM   #3089
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,280
Originally Posted by scorpion View Post
Did you just use your old cover and their foam on your seat base?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 11-28-2012, 02:46 PM   #3090
rensho
Oddometer: 184
Did you just buy the foam from them and staple on your old cover? Is that a low or regular seat?
The ride looks like a blast!
rensho is offline   Reply With Quote
Times are GMT -7.   It's 02:25 PM.
