Old 12-31-2012, 04:37 PM   #3151
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,239
Originally Posted by Rossb View Post
Looking for a cush hub. The RAD site is not clear if there is one available for our bikes. FE 570.
Any info will be appreciated
As RTF says, they are the same as KTM hubs. Woody's Wheel Works just installed a RAD cush hub with heavy duty SS superlaced spokes on to my OEM blue rim for my FE390. I went with the 'silver/natural' RAD hub because it is a milled hub compared to the cast KTM hub, and the milled matches the front Husaberg silver milled hub and fashion queen made me do it.
I have enough blue bling on the bike so kept the hubs silver.
Shipped back to me today. I'll take pix when I get it.
Woody's charges $100 more for the RAD cush hub compared to if they lace on a cast KTM cush hub from the 640's.
cyborg is offline   Reply With Quote
Old 12-31-2012, 04:42 PM   #3152
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 400
Do you mine giving the price for that? Do they give you credit for keeping your factory hub?
RememberTheFallen is offline   Reply With Quote
Old 12-31-2012, 04:46 PM   #3153
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,212
Yes please...inquiring minds would like to know :)
Sent from my DROID RAZR using Tapatalk 2
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 12-31-2012, 05:04 PM   #3154
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,190
I had Woody's build me one using the silver Rad hub and super lacing onto a silver Excel rim last year for my 390. Cost including freight to Oz was $890aud.
Excellent work by Woody's.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 12-31-2012, 09:54 PM   #3155
cyborg
cyborg's Avatar
Oddometer: 5,239
Sure, per Zach at Woody's
Build breakdown:
Rear Rad cuh hub with sprocket carrier $549
Stainless steel spokes/nipples $135
Superlace/true $111
-$50 for the OEM hub if still good.
If adding a new Excel rim, you would have to get a quote from Woody's. I kept my blue DirtStar rim because it's been a very good rim for even brutal rocks and Woody's doesn't have a standard blue offering. Gotta keep my blue bling!
Old 01-01-2013, 01:00 AM   #3156
Rossb
Oddometer: 16
Same hub as the newer KTM 450/525/530's. Just get one for one of them. Also a LC4 wheels from 640 fits with a spacer. It has a Cush hub already in it. That is the route I am going. Stocks wheel with d606 tire and 48 tooth sprocket and lc4 wheel with a k60 and 45 tooth sprocket. That way I have a street legal dirt focused wheel and tire and then a true dual sport wheel set up. If you can find a used lc4 wheel then you can probably buy it, a tire, and a new sprocket for the cost of that rad hub!
thanks for the reply
Rossb is offline   Reply With Quote
Old 01-01-2013, 06:56 PM   #3157
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,726
Originally Posted by UngaWunga View Post
These are the connectors Husaberg uses for the turn signal connectors:
http://www.digikey.com/product-detai...991-ND/1634732
http://www.digikey.com/scripts/DkSea...2R-JWPF-VSLE-S
Still looking for the connector used for the radiator fan kit so I can piggy back into that for the heated grips.
Originally Posted by FamilyRider View Post
The fan connector is generally folded back and sitting right underneath the frame, a few inches behind the radiators. I had to take the tank off to find it.
This is what I was looking for.
http://www.digikey.com/product-detai...291-ND/2405847
They're all Molex connectors.
UngaWunga is offline   Reply With Quote
Old 01-02-2013, 05:21 AM   #3158
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,747
Build breakdown:
Superlace/true $111
Hurry up with the photo.....already! You should have paid for Overnight shipping. It would have been the least expensive part of the project. Geeez....
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 01-02-2013, 08:28 AM   #3159
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
A little help from the experts in here is needed.... I've been getting some coolant leakage out of this hole.... what does that mean and how can I stop it?
-Finn
Lost Rider is offline   Reply With Quote
Old 01-02-2013, 08:37 AM   #3160
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 540
might indicate a good time to replace waterpump?
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 01-02-2013, 08:45 AM   #3161
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
It's been leaking out what looks like a weep hole in the part that bolts to the engine where the hose is attached for a little while now, many miles on with it and I've just been adding a little coolant as needed.... if my water pump was bad I would think I would have had more problems by now, but I'm not sure.
I've been slacking on looking into this.... but getting the bike ready for another long haul and would like to chase this down before I go.
Old 01-02-2013, 08:48 AM   #3162
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
-Finn
Water pump seal is gone....cheap and easy fix...some of the Bergs had the seal put in backward at the facotry...if that is the case you may get the fix for free...some say that sand enters into the weep hole that you are pointing to (sand riding)...a small diameter hose (2" or so in length) glued into place there makes it much harder for sand to enter...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-02-2013, 08:52 AM   #3163
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,263
Cool, thanks for the info. I haven't taken it off yet, getting ready to... the hole looks like its pretty far from the gasket and there's no leak around the gasket itself, are you saying that the gasket can let coolant leak through the hole?
Then, with hat said, does anyone know if this gasket has a KTM equivalent? My local Husa dealer doesn't stock shit for parts, but my local KTM dealer does...
Old 01-02-2013, 09:42 AM   #3164
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
Not the gasket for the pump cover....the green seal around the pump shaft....
Old 01-02-2013, 10:07 AM   #3165
rensho
Oddometer: 182
Finn, this is what Nowwhat is referring to.
http://husaberg.org/forum/viewtopic....116647#p116647
rensho is offline   Reply With Quote
Times are GMT -7.   It's 06:09 PM.
