Old 01-02-2013, 10:23 AM   #3166
woods wizard
woods wizard's Avatar
Oddometer: 849
Here is a full desc. of the weep hole mod. http://www.husaberg.org/forum/viewto...p?f=25&t=14199
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is offline   Reply With Quote
Old 01-02-2013, 11:17 AM   #3167
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
Thanks fellows, here's the part numbers for the gaskets, local Ktm shop had them for me. Guess ill do that mod too while I'm in there
0760102455
0760102440
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 01-02-2013, 11:51 AM   #3168
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,985
0760102455
0760102440
great "how to"
http://ridedualsport.com/forum/index.php?topic=2658.0
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-02-2013, 01:43 PM   #3169
woods wizard
Oddometer: 849
Bear eats Husaberg !!!!
Check this out http://www.dirtbikemagazine.com/ME2/...2A68AFB168BC1F
Old 01-02-2013, 01:51 PM   #3170
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,226
Cool, thanks for the info. I haven't taken it off yet, getting ready to... the hole looks like its pretty far from the gasket and there's no leak around the gasket itself, are you saying that the gasket can let coolant leak through the hole?
Then, with hat said, does anyone know if this gasket has a KTM equivalent? My local Husa dealer doesn't stock shit for parts, but my local KTM dealer does...
Lost,
Lukas, HighFive and I did the weep hole mod documented earlier in this thread. Recommend you do that after you replace your water pump seals, to keep dirt out of the seal compartment:
http://www.advrider.com/forums/showp...postcount=2085
Be thankful Husaberg put a air-break weep hole zone between the water and oil seals in the water pump, otherwise you could get water directly in the oil. My KTM LC8 engine dos not have that feature and I paid dearly for that failure.
cyborg is offline   Reply With Quote
Old 01-02-2013, 02:09 PM   #3171
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
Trouble in paradise!!!!
So recently besides the coolant leaking out the weep hole I've been leaking oil from the countershaft sprocket, bought a new o-ring at the ktm dealer and a hardened dome washer from dirt tricks, thinking that would solve the leak..... boy was I wrong!
After getting the parts to do what work I planned on doing in preparation for another Baja adventure, I found this.
Look like I'll be doing some major engine work as my countershaft is not looking good.
The bike currently has about 12,000 miles on it, 50% pavement. I've kept a close eye on the countershaft, looking for wear and didn't see ANY at all before I went to a hardened Dirt Tricks countershaft sprocket.... really regretting that now as it only has about 3000 miles on it and now it's screwed. I should have known better, something has to give...
Moral of the story is don't use sprockets harder than the countershaft and get a cush-hub if you DS your Husa.
Which leads me to the next question, how hard is it to split the case and do all the work myself? I'm not afraid to get in there, but never done it and don't have any specialized tools. I guess it would be wise to replace the rings while I'm in there and anything else I find....
Around $500 in parts is what i was told for just the countershaft, gaskets, and other bits I'll need to replace.
I have one labor estimate from a local independent mechanic of 10 hrs @ $70 an hour, with the engine already removed from chassis, waiting to hear back from local Husa dealer with theirs. Money is tight right now and I'd rather do the work myself, but I don't want to get in over my head and end up paying in the long run...
What will I need to do the work besides the service manual, basic tools, and plenty of beer?....
LostRider.com
Lost Rider screwed with this post 01-02-2013 at 04:14 PM
Old 01-02-2013, 04:02 PM   #3172
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,985
Ouch....
$70 an hour is pretty reasonable though.....
Perhaps post up in Regionals for an inmate that could help for less or maybe a photoshoot trade?
Old 01-02-2013, 04:27 PM   #3173
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
Yeah, Ouch is right....
I just got a quote from a great Husa dealer that's further away but I trust much more than my local one for around $1100 total parts + labor, they do all the work...
Dropping it off tomorrow I think, I just want it done and done right. Look for a nice Leica camera for sale in FM soon.
Just sent Woody a PM about getting a cush hub, something I knew I should do long ago but kept putting it off...
I still can't help but feel the real culprit is the Dirt Tricks "hardened" sprocket. 80% of all my miles with no wear at all on the countershaft with standard sprockets, then install the DT, go for one little ride down Baja and here I am.
Live and learn, I'll be remembering this one for quite some time.
Of course Nancy with her new CRF and I were to be leaving this coming tuesday for 11 days riding back in Baja, I'll either have to ride her G650GS or try to change the whole trip plans. The dealer said best case scenario would be end of next week, but no promises.
Shit.
LostRider.com
Old 01-02-2013, 04:52 PM   #3174
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,985
The other factor is when you switched from a knobby to a DS tire like the Mefo SE....you lose the "Cush" of the knobs and voila....
Old 01-02-2013, 05:01 PM   #3175
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
There's logic in that statement, but what about all the miles (half of them) I have on worn out knobbies, they wouldn't provide any cush either.
It sucks, but I am pushing the intended purpose of this bike's design by riding it how I do, I hoped this wouldn't happen... either way I won't be using the DT front sprocket ever again.
I'm just glad I caught this now, would have been very pricy to get my bike home from LaPaz next week.... It could have been much worse. Plus I'll know exactly how this motor is actually doing now with all these DS miles.
Trying to stay positive.
LostRider.com
Old 01-02-2013, 05:15 PM   #3176
cyborg
cyborg's Avatar
Oddometer: 5,226
Based on your experiences Lost, I'm sticking to standard countershaft sprockets. They are cheap and easy to replace on the trail if it came to that. I'm still running the stock type sprockets but don't have anywhere near the miles on it that you do and it's been all on knobbies. Thought I'd invest in the cush hub sooner than pay more later.
Old 01-02-2013, 05:29 PM   #3177
rensho
Oddometer: 179
Sorry to see the bad news Lost.
I would also consider the cause being a very tight chain. I've seen quite a few refereneces to that on ktm/husa forums. Also, that counter sprocket is quite worn for its age/miles (tight chain). I know we've gone over this chain issue already, and I wasn't going to bring it up, but I'd hate to see you go thru this again, if that was the cause.
Stay positive.
rensho is offline   Reply With Quote
Old 01-02-2013, 05:30 PM   #3178
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
You're wiser than me.
I have used the DT rear sprockets before, they do last a long time. I went with the whole kit they sell with chain and sprockets, both to save cash and based on the Husa Adventure teams reviews on the DT gear.
Lots of variables to consider and I'll never know exactly why it happened, but in hindsight if you have a sprocket that's harder or equal to the countershaft than something has got to give. Maybe it was a bad sprocket, maybe I just pounded it too hard on pavement, maybe tires, whatever it is it shouldn't ever happen again once I get it sorted, get a cush hub and run standard sprockets.
Live and learn...and share here so it goes into the pool of info for folks to base their own decisions on.
LostRider.com
Lost Rider screwed with this post 01-03-2013 at 06:29 PM
Old 01-02-2013, 05:43 PM   #3179
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,239
Stay positive.
Yup, add it to the list of possible causes, and something for me to keep an eye on in the future, though I never ran my chain tighter than measured spec and let it get looser on my last Baja then short Death Valley ride. Mostly because I had no issues with the Regina chain hitting the tire and was too busy staying moving. If it aint broke don't fix it. It's actually pretty loose right now and has been for a while, probably just outside of spec on the loose side. Was on the list of things I was to be doing today to prep the bike. That photo of the chain that started the chain debate was kind of misleading.
Thanks for the support!
LostRider.com
Old 01-02-2013, 07:50 PM   #3180
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,398
I swear that if you use Moly paste on the countershaft splines and the sprocket every 2000 miles your shaft splines will last 4 times as long. I use Honda Pro Moly 60:
http://compare.ebay.com/like/2008655...Types&var=sbar
I got 40,000 miles on my Husky with has the same reputation as KTM and Husaberg for soft splines that wear. Moly Paste is cheaper than replacing the countershaft.
I agree with others dual sporting with street style tires is harder on the drive train.
I run RADD cush hub on my dual sport wheel and stock hub on the off road wheel.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Times are GMT -7.   It's 12:23 PM.
