Old 01-03-2013, 10:09 PM   #3196
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,217
Originally Posted by Cruz View Post
There are a few threads about these things, latest one here.
http://www.advrider.com/forums/showthread.php?t=852975
Looks like unhappiness for the kushsprockets from that thread.
cyborg is offline   Reply With Quote
Old 01-03-2013, 10:10 PM   #3197
cyborg
cyborg's Avatar
Oddometer: 5,217
Originally Posted by Lost Rider View Post
Here's a little something my buddy RAZR posted to help ease the pain... there's a little Husaberg in there.
Looks like fun trails Lost! Nice video.
Old 01-03-2013, 11:53 PM   #3198
ambre_OWNZ
ambre_OWNZ's Avatar
Oddometer: 6
Sorry to hear about all the countershaft issues with hardened sprockets, but does anyone run the Zard exhaust for the 570's? I have a FS and want a new pipe... Any suggestions?
ambre_OWNZ is offline   Reply With Quote
Old 01-04-2013, 05:02 AM   #3199
pRICK
Oddometer: 330
My Safari tank fuel tap solution
Here's a few photo's of how I mounted a fuel tap for my Safari front tank -
Use a perfectly good tap from my 950 Gobi panniers and tap an 8mm thread where the filter fits, grind the mount tabs off so it will mount in any direction
Select an appropriate bolt and drill a 3mm hole through the middle
and screw it all together and when test mounted there is heaps of clearance for the electrical harness
I didn't get a mounting kit with the tank so next is to make up an adaptor for the filler neck and mounts.
I forgot to mention, to get clearance for the head of the tap, I heat the subframe very carefully and pushed an indent into the plastic- near where the harness clamp screw fixing is - large enough to not interfere with the tap. I wouldn't do this with a 70degree tank. In the second last photo I would drill the hole closer to the bottom of the recess to move the tap forward, so as to require a smaller indent in the subframe.
Rick
pRICK screwed with this post 01-04-2013 at 04:04 PM
pRICK is offline   Reply With Quote
Old 01-05-2013, 01:59 PM   #3200
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,207
Well I called KTM-parts.com and cancelled my subframe tank and had them order me a Safari front tank... wanted to keep the original look of the bike, but I just got fed up with the delay... the good news is that this probably means the subframe tanks will be available within days for everyone else who is waiting
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 01-05-2013, 03:07 PM   #3201
BogeyMan
BogeyMan's Avatar
Oddometer: 449
My turn?
So, after Finn's disclosure of the condition of his countershaft & splines, and the desire to go for a ride this weekend, I took a look at my FE... and saw this:
(the white/blue "spooge" is thread-lock from the c/s bolt) and that's the c/s sprocket half off the splines.
so I took the c/s sprocket off and then wiped off the accumulated grime from the seals, and this is what's left:
So, oh wise ones of this group, what next?
Clean it up and keep an eye on it? Have I been running with a too-tight chain? Can I change the seals without splitting the case or removing the engine from the frame?
I take some comfort in that the splines of the c/s seem to be ok...
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 01-05-2013, 03:38 PM   #3202
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,074
Bogeyman, have a look here. Seal is easy to replace without pulling the motor apart.
http://www.husaberg.org/forum/viewto...t+seal#p137234
http://www.dirttricks.com/washer.htm
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 01-05-2013, 03:38 PM   #3203
Navin
Navin's Avatar
Oddometer: 8,051
Without torque on it the o ring seal doesn't work. Replace the bolt and run it. Keep an eye for more oil leaking and it'll probably stop.
On the chain, better loose than tight!
Navin is offline   Reply With Quote
Old 01-05-2013, 04:30 PM   #3204
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
Like others have said replacing the seal isn't that hard, but there's a good chance the leak is being caused by the KTM dome washer wearing out and not providing enough pressure on the o-ring on the spacer the counter shaft. I don't see how a bolt could wear out and cause the leak, when talking to the guys at dirt tricks ordering my washer they said I don't need to bother replacing it for whatever that's worth.
I've been battling with a leak that looks like yours for most of my miles. Always seemed to go away after replacing the dome washer and o-ring, but would come back soon from the miles I've been doing. Changing the seal itself never really helped. YRMV.
I wouldn't let a little leak like your stop me from riding over the weekend, but that's just me and I'm used to it leaking.
To stop having to constantly replace the soft KTM washer I bought one of these:
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 01-05-2013, 05:02 PM   #3205
Navin
Navin's Avatar
Oddometer: 8,051
I think he lost the whole bolt, right?
Old 01-05-2013, 05:56 PM   #3206
BogeyMan
BogeyMan's Avatar
Oddometer: 449
Nope. Didn't lose anything... apart from my mind (but that went a long time ago)
I think the washer I have is the DT one - I'll compare later.
Old 01-05-2013, 06:33 PM   #3207
Navin
Navin's Avatar
Oddometer: 8,051
Oh, I thought u found it hanging off the CS!
Old 01-05-2013, 06:58 PM   #3208
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,074
Has the new washer worked like advertised LostRider?
xronly
Old 01-05-2013, 07:03 PM   #3209
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
I guess I should have been more specific when I said I bought one of these to help with my oil leak, but haven't used it yet. Didn't get that far past the countershaft.
I do know that my leaks went away when I installed a new KTM washer and o-ring and then came back within a few thousand miles, so the marketing hype about a stronger washer that holds it's shape better makes sense.
LostRider.com
Old 01-05-2013, 11:09 PM   #3210
BogeyMan
BogeyMan's Avatar
Oddometer: 449
So, based on responses, I'm gonna clean it up (so that I can more closely monitor it in future), buy a replacement seal (p/n: 0760324571), make sure I have the DirtTricks washer and keep riding
From the schematic, it looks like I can replace that from the outside without too much effort of special tools.
In the meantime, I know it's been stated here what other KTM model [rear] wheel will fit the FE570 - but could someone reiterate for me? I want to see if I can source a used cush wheel, and if I know what other KTM model wheels will fit (both with and without cush as stock), I can hopefully find something used at a reasonable price (new is a hard option to stretch to right now - $$$)
Times are GMT -7.   It's 02:09 AM.
