Old 02-01-2013, 09:36 AM   #3406
LukasM
Oddometer: 5,415
Yes please on info for the stock subframe tank conversion!! I was hoping to get a 70° tank but that won't happen in time for the Tuareg Rally if at all, and I would prefer not to carry an 8 liter fuel bladder with me....
Old 02-01-2013, 10:16 AM   #3407
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
[QUOTE=cyborg;20625669]but let's not start a battery thread here.
QUOTE]
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 02-01-2013, 05:10 PM   #3408
Åmme
Oddometer: 255
Conversion original subframe to fueltank, it's a old description in Garrys Husaberg rally bike thread.
I did not follow that description I will try to make a description with photos in PDF format tonight (can't upload photos here for the moment) and if you PM me your e-mail I will send it to all of you.
Åmme is offline   Reply With Quote
Old 02-01-2013, 06:27 PM   #3409
hillwalker
hillwalker's Avatar
Oddometer: 34
hillwalker is offline   Reply With Quote
Old 02-02-2013, 03:20 AM   #3410
Rossb
Oddometer: 15
RAD cush hub spokes
Hi, I received my cush hub from RAD and took it to my bike shop to have it laced to the original DID rim.
They are not sure what spokes to use. As it is the same hub as the KTM 450/525/530, will the KTM spokes fit?
Rossb is offline   Reply With Quote
Old 02-02-2013, 04:28 AM   #3411
waldecker
Oddometer: 146
Hi,
I ended up buying Gary's bike about a year ago (about 3 years after the tank modification was made)- and within weeks the the plumbing of said subframe tank conversion came apart leaking badly. Wasn't too big a deal but had to abandon the rear subtank and repair the main fuel tank...So if you do it there is a good chance it won't last for many years.
I guess there is a reason why the Husaberg rally team used the 70 degree tank on subsequent rally builds.
Cheers
Waldecker
waldecker is offline   Reply With Quote
Old 02-02-2013, 04:59 AM   #3412
Åmme
Oddometer: 255
Mail sent
Old 02-02-2013, 06:46 AM   #3413
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,016
Originally Posted by waldecker View Post
Hi,
Cheers
Waldecker
Could you elaborate on this please? That bike was 'well used', multiple rallies I believe. The plumbing was what came apart? Was the subframe itself in such a condition so that with new plumbing it could have been continued to be safely used as a gas tank?
Some plumbing repairs seem a small cost compared to $500 for an additional ~40 miles range.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 02-02-2013, 07:47 AM   #3414
SRG
SRG
SRG's Avatar
Oddometer: 1,258
^^ Yes please, what exactly went wrong w/ it? ^^
Amme - Thanks for the plumbing info and pics. It doesn't look like you had the subframe (internally) lined or coated in any way - correct?
If someone was going to try this again - seems to me a coating/lining would be a good idea. Anyone know what would be best?
Lazy Traveler
SRG is offline   Reply With Quote
Old 02-02-2013, 07:50 AM   #3415
Åmme
Oddometer: 255
Nothing else then plumbing
Old 02-02-2013, 07:53 AM   #3416
LukasM
Oddometer: 5,415
What for do you want to coat it? That stuff is made for metal tanks that rust.
Nobody coats their plastic tanks...
Old 02-02-2013, 11:46 AM   #3417
SRG
SRG
SRG's Avatar
Oddometer: 1,258
Just a little worried that since the subframe doesn't hold fuel from the factory is the plastic OK for that use?
Anyone know for sure?
Lazy Traveler
Old 02-02-2013, 12:44 PM   #3418
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,493
Ducati owners use the Coswell stuff to prevent their tanks for expanding and sometimes splitting. The modern plastic tanks can't deal with the ethanol or some other additive. The coatings are made for plastic tanks. Might be hard to make sure every inch if its coated, though.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 02-02-2013, 02:55 PM   #3419
SRG
SRG
SRG's Avatar
Oddometer: 1,258
UW - you mean this one?
http://www.caswellplating.com/restor...nk-sealer.html
The fine print says "Bonds to almost anything except polyethylene (gas tanks are not made of polyethylene)."
So who knows the plastic type of the stock subframe material?
Lazy Traveler
Old 02-02-2013, 03:15 PM   #3420
SmileyRider
With lots of Teeth
SmileyRider's Avatar
Oddometer: 37
On the 70 degree racing website Dale says it is Cross linked Polyethylene
SmileyRider is offline   Reply With Quote
Times are GMT -7.   It's 05:24 AM.
