Old 02-02-2013, 11:46 AM   #3421
SRG
SRG
SRG's Avatar
Oddometer: 1,244
Just a little worried that since the subframe doesn't hold fuel from the factory is the plastic OK for that use?
Anyone know for sure?
Lazy Traveler
SRG is online now   Reply With Quote
Old 02-02-2013, 12:44 PM   #3422
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,400
Originally Posted by LukasM View Post
What for do you want to coat it? That stuff is made for metal tanks that rust.
Nobody coats their plastic tanks...
Ducati owners use the Coswell stuff to prevent their tanks for expanding and sometimes splitting. The modern plastic tanks can't deal with the ethanol or some other additive. The coatings are made for plastic tanks. Might be hard to make sure every inch if its coated, though.
"There isn't any secret," he said. "It's all very obvious."
UngaWunga is offline   Reply With Quote
Old 02-02-2013, 02:55 PM   #3423
SRG
SRG
SRG's Avatar
Oddometer: 1,244
UW - you mean this one?
http://www.caswellplating.com/restor...nk-sealer.html
The fine print says "Bonds to almost anything except polyethylene (gas tanks are not made of polyethylene)."
So who knows the plastic type of the stock subframe material?
Lazy Traveler
Old 02-02-2013, 03:15 PM   #3424
SmileyRider
With lots of Teeth
SmileyRider's Avatar
Oddometer: 37
On the 70 degree racing website Dale says it is Cross linked Polyethylene
SmileyRider is offline   Reply With Quote
Old 02-02-2013, 03:45 PM   #3425
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,167
That's correct, both the OEM plastic subframe and the 70-degree tanks are cross-linked polyethylene. Polyethylene is a notoriously difficult material to glue/seal to. That's why you usually have to use mechanical means: molded-in inserts, molded threads, or bulkhead seal plugs to fill smooth edge holes, or rubber sealed bulkhead style fittings to create a fuel tap. Quite a bit of work I would guess.
I still have my OEM subframe which I am keeping as a backup for my 70-degree tank. The EOM subframe looks like it would hold quite a bit less than the 70-degree tank, but it's hard to tell accurately.
Cross-linked polyethylene and polyethylene in general can easily handle any type of fuel (gasoline, ethanol, diesel...), that's why they make gas cans out of it.
cyborg is offline   Reply With Quote
Old 02-02-2013, 03:55 PM   #3426
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 5,935
It looks like it would hold around 3 litres, maybe a little bit more, when you put them side by side. That is without knowing the thicknesses of each tank.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 02-02-2013, 04:17 PM   #3427
UngaWunga
Mosquito bait
UngaWunga's Avatar
Oddometer: 7,400
When you get a chance, fill it with water and find out?
As for the Coswell stuff, I might not be remembering what they used. I'll find out. Should help seal any plugs as well.
Old 02-02-2013, 04:25 PM   #3428
waldecker
Oddometer: 139
OEM subframe conversion
Hi,
When Garry's team built the first 570 rallye bike they had to pioneer the tank solutions;It was described in this thread:
http://www.advrider.com/forums/showthread.php?t=416713.
For the subtank they used brass spigots that were threaded/glued into the base of the subframe as well as the rear of the main tank (they didn't drill through the fuel pump housing as later conversions do).
Both locations don't provide much "meat" in the plastic for thread so when I got the bike they had been repaired with teflon tape and glue, but neither lasted past the first few rides and had to be abandoned.
I still use the subframe (without fuel in it) and a skilled plastic welder sealed the holes in the main tank; to connect the Safari Tanks(front and rear) I then bought the fuel tap block that goes through the fuel pump housing and all is well.
Cheers waldecker
waldecker is offline   Reply With Quote
Old 02-02-2013, 04:48 PM   #3429
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 1,983
Originally Posted by waldecker View Post
Hi,
Cheers waldecker
Thanks for the followup explanation.
Pass throughs and plugs in polyethylene are doable with bulkhead fittings and proper o-rings/gaskets. A little dab of gas resistant lube on the gasket to allow it to stretch and seat. Even saying that those type of fittings must be monitored and resealed from time to time or they will seep some.
Or as waldecker says an expert plastic welder can weld polyethylene.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 02-02-2013, 07:43 PM   #3430
SRG
SRG
SRG's Avatar
Oddometer: 1,244
I was just looking at the fuel tank and subframe of my '10 FX450. The plastics look identical. Same battleship grey color. Reckon they are the same?
Lazy Traveler
Old 02-03-2013, 01:42 AM   #3431
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,228
Funny how this single thread gets more posts than the entire UHE.
FE450.
XT660R
In any human interaction where money is moving from you to another; NEVER trust ANYTHING you are told.
Blakduk is offline   Reply With Quote
Old 02-03-2013, 05:49 AM   #3432
SmileyRider
With lots of Teeth
Oddometer: 37
What is the UHE?
Please bare with me, i'm new
Old 02-03-2013, 06:22 AM   #3433
frostyuk
frostyuk's Avatar
Oddometer: 271
for those with the force rally bash plate or stephans for that matter, how wide are these ? do they impact the bikes manouverability in the tight stuff as a result? do they add more protection re the brake/gear levers ? do you lose any ground clearance? just wondering from the perspective that i had an enduro engineering guard on my clutch slave unit and noticed a chunk taken out of it, don't know where or when it was done
thanks
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 02-03-2013, 07:36 AM   #3434
SRG
SRG
SRG's Avatar
Oddometer: 1,244
UHF = Unofficial Husaberg Forum
http://husaberg.org/forum/
Lazy Traveler
Old 02-03-2013, 09:46 AM   #3435
Baja Dad
Baja Dad's Avatar
Oddometer: 1,940
That is because we are NUTS !!!!!
and we love our BERGS
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
