Old 02-08-2013, 02:42 AM   #3466
frostyuk
frostyuk's Avatar
Oddometer: 274
Headlight Relocation
You may remember a few months ago i was looking at moving my headlight/mask forward to give a bit more room for my hdb computer protector and fuzeblock. At the time LukasM showed us a prototype relocation kit from Paul at HDB, and since then i have been in communication with Paul about this.
IMG_1842
However Paul has abandoned the version that Lukas showed us in favour of a more generic solution that he can use for his rally lite fairing and the more common KTM headlight/mask ( i wont steal LukasM thunder about the rally lite fairing ;) )
Anyway whilst discussing with Paul i realised that the kit Paul had made up wouldnt work with most of the bergs as it was based on moving the locating pins forward for the headlight/mask to mount on, this is for the later 570s which have the ktm mask/light combination that doesnt use a fender brace. For the fender brace version the headlight doesnt use the fender locator pins but a tab on the fender brace which also acts as the point for the headlight adjuster.
Now it may be that the only thing i need to do is to tilt the top of the mask forward but i think i will need to move the whole fender brace forward as well to get the space i want. Anyway i think this can be done with a "simple" plate that bolts to the top of the triple clamp (where the brace fits currently) rather than under the triple clamp and fancy bending, and provide some holes to mount the fender brace further forward (plus some locator pegs and a new hole in the fender for the front of the brace (but thats another story). Paul is kindly donating to me some bits from the abandoned kit he was making, to help me start on this and a local friend Gabe from Zen Overland who preps RTW bikes has said he can help me out with the metalwork. The question is is anyone else interested in a kit if i can get something made up? we're looking at a couple of months plus by the time the bits get to me from Paul and Gabe and i work something out. If you are can you pm me rather than filling up the thread and then Gabe can work out a rough cost based on numbers, i cant see that many being interested but i thought i'd ask
Cheers.
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 02-08-2013, 05:15 AM   #3467
frostyuk
frostyuk's Avatar
Oddometer: 274
clutch slave cover
Hi Lukas
this is the EE one but i've checked and it wont fit the sigutech without some machining, do you think the sig unit needs it ?
IMG00202-20130208-1258
for those who liked lostriders' light mounting position but have the older headlight unit you can get this ktm flasher bracket part that bolts to the front of the top triple clamp to provide the mounting points:
IMG00203-20130208-1301
IMG00204-20130208-1301
away"
Old 02-08-2013, 06:56 AM   #3468
rensho
Oddometer: 178
Originally Posted by LukasM View Post
Secondly, who is using a case guard and which one? The Husaberg Hard Parts 81232975044 one would be easiest to get here, but I am wondering if it will fit with a 15t countersprocket and the Sigutech clutch slave cylinder.
My friend installed an EE guard. It wont fit a 15T, but a small amount of grinding on the aluminum arm allowed the 15T to clear just fine.
rensho is offline   Reply With Quote
Old 02-08-2013, 07:00 AM   #3469
rensho
Oddometer: 178
Originally Posted by Blakduk View Post
Now that is a very fucking clever idea. And simple. The best kind.
It is a great idea. It changes how we'll need to get fuel in and out of the bladder, esp needing to drain fuel from bottom to use, but it does eliminate many other issues.
Old 02-08-2013, 07:17 AM   #3470
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,207
what kind of bladder are you planning on using? Most dedicated fuel bladders I have used, while in the military, are very thick. By the time you stuffed it all in there.. and lost all the space to the wild corners and nooks and crannies I wouldnt think there would be much room left for fuel. I like the idea of using POR15 to coat and seal the inside of the OEM subframe.. but I am not sure that POR 15 or other normal gas tank coatings will stick to plastic tanks?? I know Red-Kote wont.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 02-08-2013, 08:38 AM   #3471
BogeyMan
BogeyMan's Avatar
Oddometer: 449
I have that guard.
'cept I have the Rekluse adjustable slave on my 570, which is considerably cheaper than the Sigutech. However, you do have to drill a hole through the assembly pictured in order to have access to the adjustment bolt on the clutch slave.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 02-08-2013, 08:43 AM   #3472
Baja Dad
Baja Dad's Avatar
Oddometer: 2,012
If any one wants a Froce Bash gaurd with Tool box and 2 liter tank I will be putting mine in the flea market this weekend. I have about 300 miles on it and it is still like new
What slave gaurd works the best?? I am in need of one.
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-08-2013, 08:50 AM   #3473
BogeyMan
BogeyMan's Avatar
Oddometer: 449
I got the Rekluse one because I have the Rekluse Core EXP on my 570. Together they work a charm. Mounting it up was easy and it is super easy to adjust. Now, if/when I need to adjust the Rekluse clutch, all I need is a 4mm Allen wrench and I can do it trail side. Easy-peasy.
Old 02-08-2013, 09:15 AM   #3474
frostyuk
frostyuk's Avatar
Oddometer: 274
i like the ee one i have above, less blingy and nowhere for the crud to trap behind the front sprocket, but wont fit if you have the sigutech. i thought mine had broken but looking at it properly it was how it was made. The one downside of it is that there is a little spacer between the metal blade and the clutch slave which is easy to lose when you take the cover/clutch slave off
away"
Old 02-08-2013, 11:47 AM   #3475
bayarearider
Oddometer: 138
Low fuel light warning light on 11' FE 390
I have a 2011 FE 390 and lately the low fuel warning light is now showing up. Can anyone explain where to check the connection for this ?
bayarearider is offline   Reply With Quote
Old 02-08-2013, 02:07 PM   #3476
BogeyMan
BogeyMan's Avatar
Oddometer: 449
The sensor is in the main fuel tank, pretty close to the fuel pump, right at the back. The wires come out of the back of the tank. There's a diamond-shaped "plate" at the back of the tank that can be mounted one of two ways (depending on how much of a warning you want the reserve light to give you).
Part number: 58207080100 (compatible with several other KTM models).
Part #14 in this image:
Old 02-08-2013, 02:51 PM   #3477
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
Or check the lamp in the warning indicator is fully seated and working.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 02-08-2013, 06:10 PM   #3478
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Frostyuk - Can you provide specific info on the KTM flasher bracket? Got any pics of how you used it? Thanks.
Lazy Traveler
SRG is offline   Reply With Quote
Old 02-08-2013, 07:07 PM   #3479
hillwalker
hillwalker's Avatar
Oddometer: 34
Apparently, no NAPA's in Texas have the thermal fan switch mentioned in this thread in stock. And, I was told the manufacturer is backordered. Are there any good alternatives?
hillwalker is offline   Reply With Quote
Old 02-08-2013, 07:39 PM   #3480
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
I'm not frosty, but here's how I used mine after removing the turn signals using HDB LED signals instead, and a few other photos of the freshly repaired Mighty Husaberg and me doing our thing getting LOST.
Nice have her back running strong.
LostRider.com
Times are GMT -7.   It's 04:23 PM.
