02-11-2013, 06:42 PM
#3511 | |
Oddometer: 44
Somehow (can't remember) I found it from a BMW... A link for the cross search of the above part number is here: http://www.dmauto.com/web/dmauto/Cat...s/ATM/1435033/ BMW, 1989 325i, 2.5l Found a bunch at RockAuto: http://www.rockauto.com/catalog/x,ca...,parttype,4312 Hope this helps...pinevalley |
02-11-2013, 07:18 PM
#3512 |
Oddometer: 32
Thanks guys!
02-12-2013, 04:38 AM
#3513 |
Oddometer: 4,909
I'm currently going over my bike in preparation for the Tuareg Rally, doing some maintenance and a few upgrades. Almost ready to race...
![]() One of the things I wanted to fix are two oil leaks that I have had for a while, one at the valve cover and the other at the cylinder base: ![]() ![]() I was a bit frustrated that these came up on a low mile bike, but maybe that was unfounded... Now that I have the tank off I noticed a puddle of engine oil in my airbox, the underside of my seat was covered with a film, and there was some on the frame on the back side of the airbox. So I think it's engine oil that ran down the fuel line, and then dripped onto the cylinder. And on the front, it looks like the crankcase vent hose was not seated all the way, and oil had been seeping from there and not the valve cover gasket: ![]() Has anybody else had this problem? I have been running the oil level at the higher end of the recommended range, maybe this coupled with some hard riding and sustained high speed runs while in supermoto trim led to foaming/misting and getting all this oil through the vent hose? I'm going to try to solve this by fixing the lower part of the breather hose to the valve cover with a clamp, and by putting a Thumper Racing case vent somewhere inline, have had good luck with them on my EXCs that had the same misting problem, plus gaskets live longer and you make more power.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
02-12-2013, 05:57 AM
#3514 |
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,968
Lukas.....
02-12-2013, 06:51 AM
#3515 |
Oddometer: 93
[QUOTE=LukasM;
Has anybody else had this problem? I have been running the oil level at the higher end of the recommended range, maybe this coupled with some hard riding and sustained high speed runs while in supermoto trim led to foaming/misting and getting all this oil through the vent hose? [/QUOTE] I seem to only have CC blowby into the intake when I run oil levels above 1/2 way on the glass(my glass is round, and not the oval cylinder glass). |
02-12-2013, 02:35 PM
#3516 |
Just trying to get by.
Location: Gympie-bike heaven.Where banjos duel with glocks.
Oddometer: 1,146
What do you mean the high end of the recommended range. It says to put in 1.4 litres. Not 1.5, not 1.3. But 1.4.
FE450. |
02-12-2013, 02:45 PM
#3517 |
Lost but laughing.
Oddometer: 4,576
I would say he means the higher level on the sight glass.
When I filled the exact amount by the manual and turned the motor over for a short time and then let it sit, the oil level in the sight glass was at the lower level so I topped it up a little bit at a time until it reached a level half way in between high and low. See page 71 of the manual.
The very existence of flamethrowers proves that sometime, somewhere, someone said to themselves, “You know, I want to set those people over there on fire, but I’m just not close enough to get the job done.” George Carlin |
02-12-2013, 06:38 PM
#3518 |
Oddometer: 1,120
Got to love LukasM's work!
![]() Someday I hope to win the Lottery and just try and keep up with his projects and riding!
Current Stable: 2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS 2007 Husqvarna TE610 , 2003 KTM 525 MXC |
02-12-2013, 10:24 PM
#3519 |
BackCountry
Oddometer: 8
sweet Nevada riding conditions lately
02-13-2013, 09:28 PM
#3520 |
High Roller
Oddometer: 5,127
34 hours on the 390, all valves in spec.
![]() ![]() ![]() I haven't seen a need to remove the gas tank for the check. Does it have to be removed for a shim, change? loving this bike so far. |
02-15-2013, 02:36 PM
#3521 |
1200 GS Rider
Oddometer: 1,651
I've got a great race prep mechanic (Les Martin) converting my '09 Berg to a full rally bike for the '13 Mexican 1000.
It started as this: ![]() I bought it used last year from an inmate in Arizona. It now looks like this as it's getting ready for the rally build: ![]() ![]() ![]() Full rally fairing and nav tower, with roadbook and ico. Safari tanks front and rear (should have about a 250 mile range). Tanks will be switchable to control which tanks to drain first. Dual FI pumps for redundancy. Full Ackropovic exhaust. M-Power Suspension by Martin Racing (Les). Will be dynoed and remapped for great power while running cool at high speeds. Seat Concepts seat. Complete rewiring of all electricals to ensure its waterproof (and idiot proof - every connector will be slightly different so you can't make any mistakes in making conncections). Rigid LED lights. I'm sure there's more I'm forgetting to mention. Hopefully will be basically complete in about 2 weeks, and ready for testing and dialing in suspension. Muchas Gracias to Les (and his son Chris) for putting their passion into this effort!
Larry 2006 R1200GS; 2009 Husaberg FE570; 2011 Husaberg FE570 www.galacticgs.com "Speak to me of summer, long winters longer than time can remember; Setting up of other roads, travel on in old accustomed ways." |
02-15-2013, 03:02 PM
#3522 |
Broken Roadie
Oddometer: 2,787
That's just awesome Larry!
Looking forward to seeing your progress and results. Dual fuel pumps? Love to hear more info on that. You going to be riding that beast at the n00b Rally? I saw the Long Ride you're leading, did exactly that ride during DV Daze but starting in FC, good times. A little training for your upcoming race. ![]() Might be temped to do it with you on the Husa's as I was on the 250 at the time. Thanks for sharing! |
02-15-2013, 05:41 PM
#3523 |
throwing a leg over
Oddometer: 111
chinese radiators
Hi all,
Anyone on here tried the Chinese radiators on their 09-12 FE. Specifically the Winner Racing ones that say there 2 row 40mm thick core, cooling capacity doubled. I was wondering if they fit ok with the thermo fan which is tight on the fuel tank with the std rads. The std ones are 2 row and just under 40mm thick anyway so are they just pulling our legs on the double capacity... cheers, Bill..
![]() 2012 Husaberg FE 570.....................2004 KTM Adventure 950
........................2007 Suzuki Boulevard C50........................... |
02-15-2013, 06:43 PM
#3524 |
Stinky Pinky
Oddometer: 305
2010 fe 450
Hey guys,
I thought maybe I'd give it a shot. My berg is for sale on ebay. Anyone interested in getting a super set up bike for a great deal is welcome to check it out. I'm crazy for selling it as it has been perfect and I have invested so much in it. The item # is: 261169128316 thanks! Kris |
02-15-2013, 07:04 PM
#3525 | |
1200 GS Rider
Oddometer: 1,651
The plan is to mount two fuel pumps external from the tank. May have a switch to choose between them, or more likely just the opportunity to switch quick disonnects to change from one to the other. May have it at the n00b rally - not sure yet, but definitely planning on a long training ride. See you in DV!
