Old 02-16-2013, 09:40 AM   #3526
Baja Dad
Baja Dad's Avatar
Oddometer: 2,042
Originally Posted by GalacticGS View Post
Anyone have a source for a low rally pipe for the Bergs?
I had one for my 2010 450 and used a Force bash plate.
I can have one made up for you.
send me a PM.
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 02-16-2013, 02:18 PM   #3527
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,329
send me a PM.
Thanks Mark. I called and left a msg. Will probably have my bike builder (Les) give you a call.
See you down in Mexicali...
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 02-17-2013, 04:30 PM   #3528
pinevalley
pinevalley's Avatar
Oddometer: 101
FrostyUK -
I dont' know if you are still looking for a solution, but below are some photos of the KTM roadbook carrier...
pinevalley
(sorry for the crap cell photo)
Originally Posted by pinevalley View Post
Would one of the KTM roadbook carriers work for you?
http://www.google.com/imgres?imgurl=...QEwAA&dur=2715
pinevalley is offline   Reply With Quote
Old 02-18-2013, 03:18 AM   #3529
frostyuk
frostyuk's Avatar
Oddometer: 275
FrostyUK -
pinevalley
Hi Pinevalley
thanks for the pics that is a huge space there, it certainly would be worth considering if i had the 2008exc mask and light but my mask/light is like this:
IMG00175-20121124-1107
and uses different mountings to your headlight/mask
another pic
IMG00121-20120624-1250
many thanks once again
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 02-18-2013, 03:46 AM   #3530
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
FrostyUK -
pinevalley
Where did you get the blue KTM mask and fender?
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 02-18-2013, 09:32 AM   #3531
LukasM
Oddometer: 5,427
It's a Berg item, came stock on the US 570S Bergs that came street legal from the factory I think?
Old 02-18-2013, 04:24 PM   #3532
pinevalley
pinevalley's Avatar
Oddometer: 101
Correct!
Yes - came stock on the bike.
Old 02-18-2013, 05:45 PM   #3533
salty_scuff
Oddometer: 37
update
Originally Posted by Cyberg View Post
UPDATE
And I quote "It is repairable it will be expensive if your not fixing it yourself. Top end blew. 2 of 4 valves are bad head blew. Piston is still good as is tranny"
So I will dig deeper ask him if he opened it or someone else did. Time to call the parts counter.
I bet the intake rocker locked up on the shaft. This has been an issue on a few bikes.
Tell him you will give him 1500 and bet you can fix the top end for 1000 or less.
New rockers, shafts, valves, and machine work[/QUOTE]
update - I bought that bike, and as expected, there are more problems then meets the eye, when bike owner is a complete monkey... I had that "dont do it" feeling, but it was so cheap...
head was completely mangled, beyond repair..hole in piston let a bunch of metal onto the bottom end, so I split the cases, replaced the mains, etc
new head and cylinder form ebay, motor is going back together
Also of course half the bolts were stripped, including oil drain
replacing most bearings, wheels, swing arm, steering stem
no fluid in suspension, so the pogo sticks are off to factory connection
estimate 5-6 k and a couple months of work.. oh well at least I know everything will be fresh
salty_scuff is offline   Reply With Quote
Old 02-19-2013, 10:59 PM   #3534
reigele
Oddometer: 6
Test
reigele is offline   Reply With Quote
Old 02-20-2013, 01:42 AM   #3535
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
What years were they blue. I could have used one.
Old 02-20-2013, 07:47 AM   #3536
pinevalley
pinevalley's Avatar
Oddometer: 101
Not sure. Mine is a 2011. Here is what I found for a part number - 7800800100068
Old 02-20-2013, 08:20 AM   #3537
Baja Dad
Baja Dad's Avatar
Oddometer: 2,042
talked to Les!!
I am taking my Berg over to have the Low head pipe fitted.
I may have to have him send the rear can to me to finish it off.
Old 02-20-2013, 08:35 AM   #3538
hillwalker
hillwalker's Avatar
Oddometer: 34
Map Help
My bike is at the shop today to get remapped (FE390). Apparently, it had the euro map on it and they are putting on the 390 competition map. Anyone know what the differences are? Is the 390 competition map the recommended map over the euro map?
hillwalker is offline   Reply With Quote
Old 02-20-2013, 08:40 AM   #3539
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,811
one is written in English units the other in Metric.
Seth S
Seth S is offline   Reply With Quote
Old 02-20-2013, 08:43 AM   #3540
hillwalker
hillwalker's Avatar
Oddometer: 34
Thanks. I just hope the 390 competition map is not the stock map. I wasn't sure if the euro map or the 390 comp map was preferred. I asked him about the fx450 comp map based on comments in this thread and he said he selected the 390 comp map. That's not the stock map, right?
Times are GMT -7.   It's 10:39 PM.
