Old 04-04-2013, 11:34 AM   #3646
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 403
Ok, thanks!
RememberTheFallen is offline   Reply With Quote
Old 04-04-2013, 11:58 AM   #3647
BogeyMan
BogeyMan's Avatar
Oddometer: 455
Originally Posted by rensho View Post
Cool stuff Cyborg. I really want to get a rear hand brake. Please let us know how you like it.
Yea, me too. I have pretty much the same setup and have been thinking about the rear brake setup.
If you didn't have the smaller switch cluster, would you have been able to fit it in?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 04-04-2013, 12:42 PM   #3648
Chilipepper
Baja wannabe
Chilipepper's Avatar
Oddometer: 835
With some shipping issues I just ended up with the exp 2 kit. It comes with the adjustable slave cylinder. The new clutch cover, new inner clutch, pressure plate the exp plate of course with 6 red and 6 blue springs and the red main springs. The clutch pull now is just a bit heavier than stock. Being able to adjust the clutch at the slave is great. It's a great set up. Really prefer it to my buddies z-start without clutch lever. Just have to email rekluse and they will send you a template to drill a hole in your stock chain guard to access the bolt on the slave
Yes, this is my camera. No I won't shoot your freakin' wedding.
Chilipepper is offline   Reply With Quote
Old 04-04-2013, 10:29 PM   #3649
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,265
It's a pretty tight fit to keep both levers but I managed it. Had to modify the switch cluster parts and break them apart and mount them to the Rekluse master cyl clamp and body.
On the top left module:
Light toggle: High/Low/Off
Horn
Kill switch
Below Rekluse master cyl clamp:
Blinkers
Mounted to the mirror base/clutch lever perch is what looks like a KTM Kill or Start switch that I am using for a headlight "Alert" High flash and also for programming the Skene Designs dimmer for my Baja Designs Squadron headlight.
On the far right, the usual KTM tripmeter switches.
cyborg is offline   Reply With Quote
Old 04-04-2013, 10:37 PM   #3650
cyborg
cyborg's Avatar
Oddometer: 5,265
The OEM guard drill template came with my Rekluse adjustable slave cylinder kit, on the last page of the paper install instructions.
Old 04-05-2013, 03:48 AM   #3651
milzispete
Conquistador
milzispete's Avatar
Oddometer: 350
Horn
Kill switch
Blinkers
Thats a lot of stuff on there matey. I can only assume you have a hook for a right hand
they don't make 'em like they used to. which is a good thing really
milzispete is online now   Reply With Quote
Old 04-05-2013, 04:52 AM   #3652
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,774
mercy sakes, Cyborg!
Hey...add "gasoline" to your list of things you buy for that bike.
Just sayin.
And, I'm starting to get worried about what you've got planned for us this year.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 04-05-2013, 08:08 AM   #3653
cyborg
cyborg's Avatar
Oddometer: 5,265
Looks like a lot in the zoom-in photo, but the actual parts are small and the cluster is still smaller overall than a typical "Street" switch cluster and everything is quick at hand. It doesn't get in my way. Other side is start button and 3-map switch. I do dual-sport this bike a lot and need the goodies.
And HF, I HAVE been riding it. Plans? What Plans?
Old 04-06-2013, 05:49 AM   #3654
milzispete
Conquistador
milzispete's Avatar
Oddometer: 350
buy new or used? what to do?
I'm looking at buying an FE570 and I've found a new 2012 and a used 2011 with 50 hours pretty close to home. The used bike is only 60% of the price of a new one.
Where the bikes are located is all big dunes and I would guess it's been flogged from birth and traded in for a 500exc.
what to do? I'm no pro so I'm not sure I will notice the improvements in suspension unless they are pretty dramatic. Any problems with abused bikes?
Old 04-06-2013, 04:18 PM   #3655
rensho
Oddometer: 184
I think the only changes from 11-12 were a yellow frame and most likely the 12 doesn't have the 'bad' fuel pump.
At 60% of price, it is hard to pass up if the bike runs well and doesn't look beat to heck. The 570s seem to run at least 200hrs before a top end service is needed.
rensho is offline   Reply With Quote
Old 04-06-2013, 04:21 PM   #3656
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Originally Posted by RememberTheFallen View Post
Ready for some moto camping!
moto camping huh?
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 04-06-2013, 04:29 PM   #3657
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,326
To answer your question, no, no issues that I've experienced with 15,000 miles or 400 hours on mine that wasn't operator error caused. @ 12,000 I replaced the rings since we were in there fixing the countershaft I wore out after not running a cush drive, and riding lots of pavement, but only because we were already there, not because it had to be replaced. Valves STILL in spec from the 300 mile service.
There's folks with more miles than me that have not rebuilt a thing. Jimmy Lewis has more hours on his and it hasn't needed any major service. As long as the owner changed the oil now and then and kept a clean air filter I wouldn't be afraid to buy the bike for the right price.
These aren't Orange bikes that need to get rebuilt often.
Lost Rider is offline   Reply With Quote
Old 04-06-2013, 04:33 PM   #3658
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
so you're saying I bought the wrong bike...
Ben
My Photo's
Old 04-06-2013, 04:45 PM   #3659
Lost Rider
Roadie
Lost Rider's Avatar
Oddometer: 3,326
We'll talk about that when we go down to Baja next month, if you finish the race.
You better hope you don't break down!
Heading out tomorrow for some Lost moto-fishing-riding-camping alone time on my favorite bike, the crappies are hitting, the trout are hungry and the mountain single tracks are finally opening up!..
Nice riding with you last week in DV reshno, we had 4 Husa's that glorious day - good times!
reshno in front, me second, reshno's friend 3rd and pinevalley's sweet Rally setup Husa towards the end.
Old 04-06-2013, 04:59 PM   #3660
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,274
I've just seen a brand new in-crate 2012, 70 degree FE390 at MPE Caloundra....must be last on planet!
(no affiliation with MPE, bought my last bike from him, seems a good dealer)
FE450.
XT660R
Blakduk is offline   Reply With Quote
Times are GMT -7.   It's 11:09 PM.
