Old 05-17-2013, 10:21 AM   #3856
BogeyMan
BogeyMan's Avatar
Oddometer: 449
Originally Posted by LukasM View Post
Since they attach to the front of the rads I can't see why not, but I haven't tried it personally.
Finn, I'm sure, will have the last word. BUT, since I now have his BPD rad guards on my Husa, I'm not sure they do fit without some gentle encouragement
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 05-17-2013, 11:49 AM   #3857
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 391
Talking about aftermarket choices... I can confirm that Dynaflow upgrades do not fit and cannot really be made to fit :(
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is offline   Reply With Quote
Old 05-17-2013, 12:40 PM   #3858
Baja Dad
Baja Dad's Avatar
Oddometer: 2,006
need some help
What brand of side stand works best????
The OEM side stand SUCKS!!!!!!!
I need a new side stand ASAP
Where can I find one???
What about Fastway/moto bilite
what part Number??????
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 05-17-2013, 12:41 PM   #3859
Baja Dad
Baja Dad's Avatar
Oddometer: 2,006
Originally Posted by woods wizard View Post
Lukas, do those guards fit with the Safari front tank ?. I assume they do , just wanted to confirm first. Thanks
Yes they do
I have them on my bike.
I cut 3/4in off the bottom to clear the bottom tank brace
Old 05-17-2013, 01:31 PM   #3860
chief_lee_visceral
Oddometer: 391
Fastaway will not work when I checked. Unless you make your own adapter or weld on the frame its oem. You cannot mount using the kickstand or it is going to give out.
Old 05-17-2013, 02:46 PM   #3861
LukasM
Oddometer: 5,424
Nobody makes an alternative to OEM, neither PMB nor Trailtech.
Old 05-17-2013, 10:58 PM   #3862
Scooter29
Oddometer: 20
2011 Tank Shrouds.....
Hello......I wanna get rid of my blue plastics on my '11 FE570. Really like the look of the FS white plastics. Will the '11 FS shrouds fit my '11 FE...????
Thanks Scooter.....
Scooter29 is offline   Reply With Quote
Old 05-20-2013, 07:03 AM   #3863
woods wizard
woods wizard's Avatar
Oddometer: 845
Thanks Scooter.....
I think the shrouds are the same. I will take those blue ones off your hands .
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is online now   Reply With Quote
Old 05-20-2013, 07:05 AM   #3864
LukasM
Oddometer: 5,424
All 09-12 390/450/570 shrouds will interchange no problem.
Old 05-21-2013, 08:42 PM   #3865
Humanbeingexpert
Oddometer: 51
Well had the FS 570 for about a month now...and made these mods:
ECU now has comp map
Exhaust...cut out the washer/pipe on OEM, opened it up
De-smogified
Shorai battery..worthwhile for sure
Filter sock added
Regeared to 14/45...thx Finn for the 13T up until now!
Kickstand, no longer retracts...easy spacer delete
Few bling items too
Still need to put on the Golan filter...but not sure how?
Which hand guards are the best?
Also trying to decide between finding an FE with mods (expensive, but easy) or just getting 21 front end with forks/rear wheels, etc to be able to convert to dual sport...which I regret/miss. Any thoughts?
Humanbeingexpert is offline   Reply With Quote
Old 05-22-2013, 01:13 AM   #3866
LukasM
Oddometer: 5,424
Is your FS plated? If you will be riding it as a supermoto sometimes, keep it and get a set of dirt parts. This will be way cheaper than buying a FE and buying SM parts for it.
Highwaydirtbikes makes the strongest and most functional hand guards, you can get them with blinkers, mirrors and a top clamp with room for LED indicators, switches, power plug, etc.
Old 05-22-2013, 06:52 AM   #3867
Humanbeingexpert
Oddometer: 51
Yep plated. Best source for dirt parts? Thx.
Old 05-22-2013, 08:57 AM   #3868
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
What he said, the whole system just works, giving a bunch of solutions all in one. I know mine have taken a beating, including my recent high speed, high side crash where the bike basically landed on the HDB guard after flipping in the air, taking a chunk of tarmac out of the road while saving my bike from any damage, allowing me to ride it to the hospital.
You can only buy it online direct from HDB and you'll need the 90x38/40 size top clamp and then pick out what options you want. You can get new bars with the bar end mounts pre installed but every HDB kit comes with a tap and inserts to do yourself, it's easy to do.
http://www.highwaydirtbikes.com
As for a DS/SM setup, we live close by, I have DS you have SM, no reason we couldn't trade off parts now and then too... talk you next time you come by.
Oh, as for Safari tanks and Bulletproof rad guards, as discussed you can get them to mount with a little mods, but if you look at where the tank when it flexes it will still hit the radiators in a fall, the guards probably won't help since they are in front of the radiator and the tank cutout is behind them. That's just speculation, but when I looked at mine before I sold them that's what I came up with, so not wanting to cut the guards I sold them instead and put that cash into other things for the bike.
I know mine took a big hit on some single track when I almost looped it and it came down on a big rock where it bent the radiator and cracked the fan mount. the other thing I learned is when you do the fan install like in the instructions with the wire running up and over the fan, you can't get to the fuse with the Safari on the bike so I moved mine so the wire goes under the fan putting the fuse where I can get to it on the trail.
A little JB Weld and my fan is good to go, though I'm interested in finding a rad guard/brace that covers the side that is still exposed, has anyone used the Enduro Engineering Radiator Braces? Will it fit with the Safari?...
https://www.ktm-parts.com/11120.html#.UZznBJWcOoU
Another thing about the safari is the fuel petcocks are very exposed, on the same fall that bend the radiator i also broke the screw-on part of the petcock, I now carry a spare in my tool kit, you can get them from www.justgastanks.com
Been looking at a solution to protect the petcocks, maybe some kind of L channel piece of metal that connects (weld it maybe?) to the OEM Safari under tank cross brace to help protect them and that lower corner of the tank where it takes hits. Would hate to drop the bike on just the right rock and rip the petcock out of the tank making the tank worthless...
Any other ideas besides not falling?
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 05-22-2013, 09:07 AM   #3869
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 392
Finn,
From what I have read the enduro engineering guards do not fit with the fan or tank. Just bought the BPD guards because of that.
RememberTheFallen is offline   Reply With Quote
Old 05-22-2013, 02:35 PM   #3870
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,418
Got my rad fixed locally, Chester @ Reno KTM did a cracking job
I'm amazed that this could even be done.
before:
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Times are GMT -7.   It's 05:11 AM.
