Old 05-31-2013, 06:09 AM   #3901
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,205
Originally Posted by BogeyMan View Post
Anyone with any wiring suggestions? Bueller? Bueller?
Anyway - another question. Rear suspension. The time is approaching to have mine checked. Any recommendations for suspension servicing (out here on the West Coast preferably)? I'll get around to the front later, so if you have different suggestions I'd love to hear them.
wiring scares the crap out of me.. I would love to clean up the mess behind the headlight as well.. but anytime I touch anything to do with electricity I run the risk of letting out all the magic blue smoke that makes it all run
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is online now   Reply With Quote
Old 05-31-2013, 09:57 AM   #3902
frostyuk
frostyuk's Avatar
Oddometer: 272
Ok, so this is the mess that's usually hidden away behind the headlight mask...
It needs cleaning up. I have a switch setup to turn the headlights on/off (I turn them off if I'm trail riding) and I have an auxiliary LED light that is switched also. I plan on adding heated grips. I also have my GPS wired to switched power and I have a powerlet socket...
What easy to add (and small) connectors do you recommend (that are also weather/water proof)? I have a weatherpak connector in the bottom of the pic, but it's way big. I would like something smaller, that is easy wire in, but is resilient.
Suggestions?
thats postively tidy compared to mine :
why bother with waterproof connectors? they are all big as far as i've seen. Most of the harness is molex connectors so thats what i used with my fuzeblock set up
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 05-31-2013, 02:31 PM   #3903
PowerT
PowerT's Avatar
Oddometer: 1,065
Suggestions?
I would hit up the guy that runs Eastern Beaver.
That’s the thing about traveling. If you’re looking for something, you can almost never find it. But if you are just open to what is there, it’s almost always awesome - Neduro
In spite of illness, In spite even of the archenemy sorrow, One can remain alive long past usual date of disintegration if one is unafraid of change, insatiable in intellectual curiosity, interested in big things and happy in small ways. - Edith Wharton
Need a smugmug coupon? Well here you go z0g48s072w1kE
PowerT is offline   Reply With Quote
Old 05-31-2013, 03:24 PM   #3904
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Boggy Man - not on the left coast, but Genuine Dirt Racer in North Carolina does great suspension work and are Husaberg specialists.
Lazy Traveler
SRG is offline   Reply With Quote
Old 05-31-2013, 04:31 PM   #3905
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,242
I ride my bike pretty hard, but spend a lot of time trying to keep it looking special.
It's now 8 months old and I'm getting all these little brown flecks across the side of the engine, the hubs, the swingarm, etc. They look like dirt, but they aren't.
I've tried truck wash, CRC, Lanolin, Degreaser, petrol, brake & clutch cleaner, rubbing.
Is it tiny rust bits? Some metal chemical reaction?
The don't come off and there's hundreds of these tiny discolorations everywhere.
Anyone got any ideas?
FE450.
XT660R
Blakduk is offline   Reply With Quote
Old 05-31-2013, 05:23 PM   #3906
dave186
Oddometer: 182
Could someone offer me some insight on wiring up the brake light on my 09 FE? I thought the 2 pin connector below the battery was for the rear brake light switch but I must be wrong, one wire is brown (ground) the other is blue/yellow (hot). obviously completing that circuit results in a blown fuse. I found the front switch connector and it works fine but I was hoping to just use a switch on the rear, no front.
TIA
Dave
dave186 is offline   Reply With Quote
Old 05-31-2013, 08:35 PM   #3907
Shawnee Bill
Shawnee Bill's Avatar
Oddometer: 2,066
TIA
Dave
The rear brake light plug is hidden well. It is underneath the wiring harness going toward the front of the bike on the left side under the seat. Completely out of sight unless you dig under there looking for it. At least that's where mine was.
Pic shows it after I dug it out, it was under that other connector, I had to pull those up and out to even see there was anything under there.
Plug your switch wire into there and voila! Brake lights.
1200 GSAW
FE 390
KLR 650 (not new)
GL1800
FZ-1 For sale
Shawnee Bill is offline   Reply With Quote
Old 05-31-2013, 09:34 PM   #3908
dave186
Oddometer: 182
I found it! All bundled up with the main wire harness in front of the shock reservoir. Man they stuffed a lot of wires on these bikes.
Old 06-01-2013, 04:37 AM   #3909
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,289
Originally Posted by Baja Dad View Post
Everything but the spare wheel set.
I have a few sets of wheels so I let the dealer keep them.
Mark - Are you converting this to a race bike, or will this be a backup?
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 06-01-2013, 05:45 AM   #3910
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,283
Love my 570 ! Just saying
Knobbiethrower is offline   Reply With Quote
Old 06-01-2013, 11:25 AM   #3911
dp63130
none.
dp63130's Avatar
Oddometer: 305
Looking for a fuel pump for a 2010 fe570
The usual suspects are out of stock until June 30th.
http://www.ktm-parts.com/
http://ca-cycleworks.com/fp-hus
Anyone else have a resource for these pumps?
dp63130 is offline   Reply With Quote
Old 06-01-2013, 07:18 PM   #3912
mikecarpenter
Oddometer: 50
I hope I don't regret this! I have a new CACycleworks that I took to Baja as a spare. So far with about 3500 miles, mine has never shown any sign of failure and I've had it hot on single track some.
If someone needs one immediately, I'll take what I paid for it ($129) and you pay shipping.
mikecarpenter is offline   Reply With Quote
Old 06-01-2013, 07:31 PM   #3913
dp63130
none.
dp63130's Avatar
Oddometer: 305
Pm!
Originally Posted by mikecarpenter View Post
i hope i don't regret this! I have a new cacycleworks that i took to baja as a spare. So far with about 3500 miles, mine has never shown any sign of failure and i've had it hot on single track some.
If someone needs one immediately, i'll take what i paid for it ($129) and you pay shipping.
Old 06-01-2013, 08:00 PM   #3914
mikecarpenter
Oddometer: 50
Pm replied to. In case anyone is in need, Cyclebuy is showing to have the ca cycle works in stock. http://www.cyclebuy.com/shopping/ca_...orks/index.htm
Old 06-02-2013, 07:43 PM   #3915
mtbjeff
Mayhem
mtbjeff's Avatar
Oddometer: 25
A Safari white gas tank with the Husaberg factory graphics kit trimmed down to fit on my FS570
[IMG] IMG_2584 by main jet, on Flickr[/IMG][IMG] IMG_2582 by main jet, on Flickr[/I[IMG] IMG_2587 by main jet, on Flickr[/IMG]MG]
mtbjeff is offline   Reply With Quote
Times are GMT -7.   It's 08:26 PM.
