Old 06-10-2013, 01:55 PM   #3946
BogeyMan
BogeyMan's Avatar
Oddometer: 446
Originally Posted by rensho View Post
So far, I do like the MT43, but don't have enough time on it yet. 2 rides, 350 miles.
I'm running tubliss as well (new to me), so lot's has changed.
As far as I can tell, I'm not going to get any more life out of the MT43 than any previous tyre, but I like the way it works.
How'r you liking the Tubliss? I've been thinking about going that route. Does it complicate tire changes?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 06-10-2013, 02:15 PM   #3947
rensho
Oddometer: 173
New to tubliss as well. I went to it because I thought tire changes suck with tubes! ;)
Too new to me to comment really. I'm a believer in tubeless tires for bikes, so I've always wanted to try for moto.
The install is very easy, and way easier to spoon tires on now. I haven't changed tires with the tubliss on, so I can't comment, but I don't see how it would be more difficult than when I installed.
The tubliss innertube will lose air through days/weeks, so you should air that up when you ride. I pump mine up with a floor pump for my bike and check the tire pressure as well. I run a small amount of slime/stans fluid in the tire for thorn/nail sealing and carry a tire plug kit in case I get a larger hole.
If you have to remove the tubliss on trail and run a tube, you'll also need to carry a spare rimlock, or go without and run higher pressure.
We just came back from riding out in Bodie, CA and the tire setup worked well. I ran 15F/15R cold. I've had them down to 11 and the front is pretty squirmy, as the carcass is too soft. 15 seems to work well front with my MX tire.
I have 400 mi on the MT43, with some fast pavement thrown in. It seems hot street riding will dull them considerably. I think the tire will go 1000 miles or so for me at this rate, which may be a little more than my 606.
rensho is offline   Reply With Quote
Old 06-10-2013, 03:18 PM   #3948
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,218
Originally Posted by frostyuk View Post
i was running 13/52 which is what came with the bike when i got it, i've been doing some long distance trials comps recently against 200cc pamperas and gas gas etc so slow tight nadgery stuff, and as i'm not the best of riders the lower gearing helped me considerably this time round. i liked it a lot tbh so will keep it on for a few weeks and see how it fairs on my normal rides
Same here, my 390 came with either 13/51 or 13/52 when I bought it used in Sep't 2011 and that's what I've stuck with, seems to work okay on all of the trails I've ridden so far.
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 06-10-2013, 03:30 PM   #3949
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
Originally Posted by RememberTheFallen View Post
Do all years have the same gear box? I am amazed by some of the gearing that y'all are running. I am currently running 14/47 and happy all around with it. Have a 13 front that I tried for single track here but felt like I barely used it. Either I am slipping the clutch too much or y'all ride some hard core stuff!
I run a 14-45 or 14 48
WHY would anyone run a 50 or 52??? the is MX track gearing
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 06-10-2013, 05:39 PM   #3950
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,205
Honestly I am a noob to dirt.. but everyone back here runs 50, 51, 52??
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 06-10-2013, 05:49 PM   #3951
rensho
Oddometer: 173
I get along with a 14/45 just fine. I wanted to run a 15T to have less chain wrap, so I bought a 50 for the rear.
Old 06-10-2013, 06:34 PM   #3952
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,020
In the tight and hilly tracks and rocks and creeks those rear sprockets with # 40s on them won't cut it and just abuses your clutch for no reason. I am on a 390 though.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-10-2013, 08:47 PM   #3953
TLtrials
TLtrials's Avatar
Oddometer: 273
For racing enduros and hare scrambles on my previous 2009 FE450, I was 13/53 gearing. Worked great for 2nd and 3rd gear single track.
For me, the higher gearing ends up with 1st to low and 2nd to high, ending up with being in between gears in some cases to carry momentum, maximize traction, and minimizing wheel spin over roots, rocks, and mud. So the lower gearing helps bridge the gap allowing the full use of 2,3,4 in the woods, then 5th and 6th for fields and transfers. 1st is pretty much useless, unless you are crawling. Not the gearing for everyone in various regions, just worked for me.
My FE570, I am running 13/45 right now. Working good as dual sport duty. The 570 has plenty of grunt to pull the higher gearing in the single track woods, and OK on the highway for short stints on back roads and dirt roads.
TLtrials is offline   Reply With Quote
Old 06-10-2013, 11:43 PM   #3954
thebackcountry
BackCountry
thebackcountry's Avatar
Oddometer: 10
this is funny about gearing. When I got my 570 I made the dealer take off the seemingly silly "Street Use" 45, and put on a 50. The bike would only go 70 tops. Now I have the stock 45 on there, and this thing just as so much power, that I can ride any difficulty trail or climb no problem with that tall gear. And the bike will do 85 comfortably.
It's my 300 that has the gearing issues. All my tinkering with gearing, and the only solution I can seem to think of to give it the pull I want is to stuff a 570 motor in the thing.
Mike Schwartz - Tahoe City, CA
www.thebackcountry.net
mike@thebackcountry.net
thebackcountry is offline   Reply With Quote
Old 06-11-2013, 02:32 AM   #3955
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 391
Hell, mine came with a 42 tooth rear! Got it up 99mph indicated going down a slight hill before it leveled out and just wouldn't pull anymore. Useless gear if you ask me.
TLTrials, didn't think about using the lower gearing to get in the meat of 2,3, and 4. I just knew it made 1st useless. Did notice that I am constantly between 1st and 2nd with my current gearing. Gonna put the 13 back up front and try it out longer.
RememberTheFallen is offline   Reply With Quote
Old 06-11-2013, 06:27 AM   #3956
chief_lee_visceral
chief_lee_visceral's Avatar
Oddometer: 385
I have Tubliss so I can run low pressures. I think that is point of Tubliss IMHO. With an MT43 I run as low as 5 psi in rear on trail. NW rock and root trails mind you. I am getting a set of cush hubs built to swap on 606 with tubes for adv rides.
-= Never put your finger where you wouldn't put your face =-.
chief_lee_visceral is offline   Reply With Quote
Old 06-11-2013, 08:19 AM   #3957
frostyuk
frostyuk's Avatar
Oddometer: 272
Does anyone know if there are any short brake & clutch levers out there for our bikes? i'm looking for 2 finger levers rather than the 3 finger ones that come as standard
cheers
Ian
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 06-11-2013, 10:41 AM   #3958
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,205
cheers
Ian
http://midwestme.com/pages/productspage.html
Old 06-11-2013, 10:58 AM   #3959
milzispete
Conquistador
milzispete's Avatar
Oddometer: 297
Originally Posted by mrt10x View Post
Cool lever
Cool lever
Cool lever
Whoo...a f*cking chainsaw mount.
I live in the desert. We don't even have trees but I've never wanted anything more in my entire life
they don't make 'em like they used to. which is a good thing really
milzispete is offline   Reply With Quote
Old 06-11-2013, 11:01 AM   #3960
frostyuk
frostyuk's Avatar
Oddometer: 272
great thanks for the link, never heard of them before
away"
Times are GMT -7.   It's 02:53 PM.
