Old 06-30-2013, 07:57 AM   #4006
frostyuk
frostyuk's Avatar
Oddometer: 275
My new toolbox
Hi all, a friend made this up for me:
IMG00293-20130628-1620
wide enough for my tyre levers and stand, i filled it with the contents of my us5 plus spare tube and a few other bits, will need to get a liner made up to make best use of the space. Should be able to carry a 2 litre fuel can in here if i wanted to.
IMG00294-20130628-1626IMG00295-20130630-1524
IMG00297-20130630-1529IMG00296-20130630-1529IMG00298-20130630-1529IMG00299-20130630-1529IMG00300-20130630-1529
just higher than the frame
IMG00304-20130630-1534
Clearance looks good
IMG00305-20130630-1536
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 06-30-2013, 01:49 PM   #4007
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,277
I fitted a plastic barbed right angle piece used for car windscreen washers and sourced from any good auto store. Over two years with no problems, just use a short piece of joining tube between it and the tank.
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 06-30-2013, 03:29 PM   #4008
RememberTheFallen
RememberTheFallen's Avatar
Oddometer: 403
Can you elaborate on the "joining tube"? My parts store didn't have anything in brass but I found a plastic fitting. Figured it would work since it is a vent line and shouldn't see liquid fuel very often. Just confused why you need a joining tube.
RememberTheFallen is offline   Reply With Quote
Old 07-01-2013, 06:29 AM   #4009
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,277
I used a small piece of the vent line supplied originally and then replaced all of the line about six months later with higher quality clear tubing that doesn't react to fuel, also bought from a car parts store. I did have to cut up to the first barb off of the right angle piece as it faces vertically towards the fuel tank just to ensure better clearance with the seat base.
xronly
Old 07-01-2013, 07:25 AM   #4010
RememberTheFallen
Oddometer: 403
Ok, thanks Cruz!
Old 07-05-2013, 12:19 AM   #4011
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,477
what do you love about your 70 degree berg?
i put this up on unofficial husaberg but duplicated here on advrider....
i've got a pile of unused video footage of a few FE570 and FE450s. just thought i'd do something different and stick in everyone's comments about their FE390, 450 or 570.
obviously can't fit too much on the screen but if everyone's okay with it i'll just take bits of comments and use forum names as acknowledgment.
let us sing our praises of the blue and yellow beast....
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 07-05-2013, 02:25 AM   #4012
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,277
Probably worth putting in a thread of its own Barry, it will get lost in here!
Plus the 70 Degree bikes are all shit, you know that.
xronly
Old 07-06-2013, 07:29 AM   #4013
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 272
Question Berg fan kits
I just got my first Husaberg and I love it! It's a 2010 FE 390. First ride out was in some tight woods and she got hot and boiled the gas. Now I'm looking for a fan kit and some heat wrap for the mid pipe. What brand fan kit should I get? I'm also going to get the heat shielding for btm of tank and wrap midpipe with heat wrap tape. Anything else I am leaving out to help with the heat?
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 07-06-2013, 08:54 AM   #4014
RememberTheFallen
Oddometer: 403
I used the KTM had parts fan. Make sure to use the lower temp thermostat switch that Pinevally linked to a couple of pages back. Triggers the fan to come on at a lower temp.
For not much more money you can get the mid pip ceramic coated. More durable than wrap and have always heard that the wrap holds moisture against the pipe and accelerates rust. Make sure to just do the mid pipe, not the header.
Take the gas cap off and remove the screws from the bottom. A half inch or so ball bearing will fall out. Throw that sucker in the parts bin. When the fuel boils it pushes the ball up and can cause vapor lock. When you drop your bike at an angle pick it up quickly as fuel will come out he vent hose now. I went ahead and removed the little locking mechanism with tabs from the cap. Mine was next to impossible to remove before hand. Don't have to push the button now to open the cap. Never had it loosen on me.
That factory silencer is pretty restrictive. 2 inch header going down to a half inch exit in the silencer. That causes quite a bit of heat build up. Have a scar on my wrist from the 2nd degree burn it gave me when new. Search for some of the exhaust mods or buy a new silencer.
Hope you enjoy the bike! Welcome to the thread!
Joe
Old 07-06-2013, 04:45 PM   #4015
RememberTheFallen
Oddometer: 403
Finally got the subframe tank installed. Kinda a pain getting everything lined up right. Thanks Lukas for the 90* elbow idea. Made everything more tidy.
Also installed the fender kit from Paul Garfield that can be found here.
http://www.ebay.com/itm/200798672735...84.m1555.l2649
He gave me a ADVrider discount. Just intact him for discount. I had broke my massive tail light and was tired of catching my tag on the tire. The bulb also kept coming loose and not working. His designing is much sleeker. Used the LED turn signal I already had.
Went from this;
To this;
Brake light is also very bright! Great product if you have the clunky rear assembly like I had.
Old 07-06-2013, 05:31 PM   #4016
mrdirtbikerider
Husaberg rider
Oddometer: 272
Question Ceramic coating
Do you ceramic coat the midpipe inside also?
I remember reading a old post that suggested
You should coat the inside also.
Thanks for your help.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider screwed with this post 07-06-2013 at 06:02 PM
Old 07-06-2013, 05:49 PM   #4017
RememberTheFallen
Oddometer: 403
You should coat the inside also. Thx for your help
Yes. The coating shop I went to did the inside and out. They recommended it also.
Old 07-06-2013, 05:53 PM   #4018
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,217
remeberthefallen..the bike is looking good.. when I get to CO I am going to put the HDB stuff on...pretty much just like yours.... you are my hero I'm such a copycat. I will also finally get around to mounting the Safari front tank.. i don't think I am going to buy the 70 degree rear tank until I am out there a bit and see if the Safari plus OEM tank will be enough.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 07-06-2013, 07:55 PM   #4019
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,277
This is interesting.
I have previously had another bike header ceramic coated inside and out and the results were excellent.
I have been to the same ceramic coaters, who mainly do racing and drag racing motors etc for a quote on the Berg pipe.
I asked about the comment about only coating the mid pipe and he looked at me a bit strange and said where did that come from and couldn't understand why you would do that.
Can anyone give a 100% accurate reply why you would not coat the entire header pipe inside and out and not just the mid pipe?
xronly
Old 07-06-2013, 08:00 PM   #4020
RememberTheFallen
Oddometer: 403
Thanks! Pretty excited about it!
Times are GMT -7.   It's 02:24 AM.
