Old 10-08-2013, 01:03 PM   #4366
BogeyMan
BogeyMan's Avatar
Oddometer: 451
Originally Posted by vintagespeed View Post
looks to be a seeping at the back of the airbox seal, i'm guessing this is caused by blow-by from the crankcase vent? there is no evident oil in the airbox, just this goopy deposit on the top of the shock and bottom of the fuel tank.
Most likely. Is there any evidence of an oil leak from anywhere else under the airbox area? What about the underside of the seat-pan?
Give the whole engine and under-tank area a thorough clean. Use a good de-greaser. That way if there is any sort of gasket leak or oil leak from anywhere you'll be able to spot it.
could this residue be from over-oiling of the air filter??
I don't think so. The only time I've ever over-oiled a filter, it just collected as a goopy mess in the bottom of the airbox "tray".
spun the middle tank insert while removing the plastic "subframe" piece, but figured that out pretty quick with a 12mm wrench. gave me a bit of a heart attack tho. :)
I know that feeling. I got a warranty replacement based on that issue. That was some time ago though - I don't know if they are still warranty'ing the subframe tanks for that issue. You might want to try.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 10-08-2013, 02:39 PM   #4367
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,761
the rest of the airbox, tank and top of the engine are clean (at least of oil...) no evident leaks.
will be killing the grass tonight and hopefully getting this thing a little less N A S T Y.
yeah, what was weird is the inside of the airbox is clean, no oil, no puddle, no nada. which i thought was a very good thing.
will check on that right away, thanks for the tip!
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 10-09-2013, 11:35 AM   #4368
vintagespeed
fNg
Oddometer: 1,761
minor update & questions, questions...
spent the better part of 2 hours cleaning, de-gunking and generally scrubbing, toothbrushing, scotchbrite-ing this bike until i have most of the ugly off. gonna spend the next few days cleaning up the scratches on the covers, re-routing the wire harness up the framerail and doing some painting. i have ordered a bunch of wiring & replacement stuff.
questions:
1. i'm going to pull the TB to thoroughly clean it and the injector, any "gotchas" to removing it? boots look good, everything is connected and working.
2. what spark plug is recommended? i'm away from the manual so i'm not sure what to order?
thanks!
Old 10-09-2013, 12:33 PM   #4369
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,393
Finshing up the mods..
Put on some Unabiker rad guards and an auxiliary light... 7 XML-T6 Cree LED's crammed into one aux light... driven very hard. Stupid bright, probably ~3,000lm. I will post some night shots tonight.
uses a lit up push button on the rear. HI-LO-Strobe. Rubber strap keeps it snug on the bars, and a plug makes it a 1min job to take off.
CRG style bar end mirrors from Ebay. very nice and tight, no more flopping around in the wind. Can see fairly well underneath my arms
Found a score on front tires... Michelin Starcross HP4... 3 tires for $100 shipped. Can't beat $33 for a great tire.
http://www.ebay.com/itm/Michelin-Sta...#ht_725wt_1124
n16ht5 screwed with this post 10-10-2013 at 07:50 PM
n16ht5 is offline   Reply With Quote
Old 10-09-2013, 01:08 PM   #4370
rensho
Oddometer: 178
n16ht5, thanks for the tip on the tires.
I think that light is 1800lms. Are you running that on battery, or wired in somehow?
rensho is offline   Reply With Quote
Old 10-09-2013, 03:30 PM   #4371
mrdirtbikerider
Husaberg rider
mrdirtbikerider's Avatar
Oddometer: 271
Water pump cover gasket
I know it's a long shot but is there a Ktm water pump cover - gasket that will work on a 390 Berg?
To order one is going to take a week and I'm ready to ride.
06 KTM 950 Sm
10 Husaberg FE 390
mrdirtbikerider is offline   Reply With Quote
Old 10-09-2013, 05:14 PM   #4372
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,604
Buy some gasket material and make your own....its not hard.
Seth S
Seth S is online now   Reply With Quote
Old 10-09-2013, 06:17 PM   #4373
jlpred
Oddometer: 80
in..
Tired of reading all the "ooohhhh's" and "aaahhhh's" of these things so I'm now a member. So... where on earth do you buy the mythical CV turn signal piece? Or is the sicass multiswitch the way to go?
And no, the WR is not going anywhere. And yes, the Aprilia is for sale but there was no interest :(
jlpred is offline   Reply With Quote
Old 10-09-2013, 10:46 PM   #4374
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,224
I got my CEV turn signal piece from the dealer as part of a dual-sport kit when I converted my 'dirt only' '11 FE390. They knew all the parts I needed, extra wiring harnesses etc., and no it was not a pre-packaged kit. The dealer put the parts list together and I bought the ones I wanted and installed them myself.
Try looking here http://www.ktm-parts.com/OEMFINDER.html
cyborg screwed with this post 10-09-2013 at 10:54 PM
cyborg is offline   Reply With Quote
Old 10-10-2013, 04:43 AM   #4375
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,393
The CEV is a quality unit.
Hah, 1800lm.. good one.
n16ht5 screwed with this post 10-10-2013 at 07:23 AM
Old 10-10-2013, 07:52 AM   #4376
rensho
Oddometer: 178
Is this the one?
http://dx.com/p/letterfire-lf-70-7-x...FWOCQgodaFoAkg
Using a T6 bin and driving it at the reco'd current, 700ma(yields 280lms per element), I think that's how they're getting 1800lms. This site doesn't measure anything, so they're numbers are all over the place.
In theory, you could drive these at the theoretical max and get a theoretical number of 1000lms each measured right off the emitter before it goes out the lens and then your light will likely die of heat in minutes.
You running it off the bike, or a battery pack?
Old 10-10-2013, 08:56 AM   #4377
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,393
Wierd that looks almost the same. I know mine was claimed 9800lm which is absurd, but it is pretty bright. Might have diff drivers. I hooked it to the bike 12v running power. Here is comp shots vs my HID... In person the HID appears a bit brighter. You can see a bit more grain on the LED shot. I have a SkyRay King 4x XM-L2 light that is not quite as bright and it is pushing the emitters hard enough to burn your hand after a few minutes.
Here is the one I got .. $72 on Ebay
http://www.ebay.com/itm/171123796808...84.m1439.l2649
HID on HI
LED Aux
Combined
My little helper likes the green button
n16ht5 screwed with this post 10-10-2013 at 07:48 PM
Old 10-10-2013, 05:08 PM   #4378
mrdirtbikerider
Husaberg rider
Oddometer: 271
Water pump seal
After finding antifreeze in my oil, I pulled the cover and decided to try to flip the seal around. Looking at some seal pics from past post, I think the seal might be in backwards. I have never removed any pump seals before and I am a little worried about damaging seal. How do you remove the seal without damage?
06 KTM 950 Sm
10 Husaberg FE 390
Old 10-11-2013, 07:26 AM   #4379
woods wizard
woods wizard's Avatar
Oddometer: 849
I personally would not reuse any engine seal. They are too easy to damage / cut lip seal , & also cheap.
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is offline   Reply With Quote
Old 10-11-2013, 09:15 AM   #4380
vintagespeed
fNg
Oddometer: 1,761
...where on earth do you buy the mythical CV turn signal piece?..
bought mine brand new off eBay a couple days back, sorry. $50 aint too bad i think?
CEV '98
edit: also picked up a Low Fuel Indicator kit for $42
vintagespeed screwed with this post 10-11-2013 at 09:15 AM Reason: woot!
Times are GMT -7.   It's 03:34 PM.
