Old 11-26-2010, 06:16 PM   #31
JKL
Rider
JKL's Avatar
Oddometer: 742
In 2010 the first batch of bikes did not have manuals, contact your dealer.
There are many good things about the new Husabergs, my valves have not moved in 90 hours and that is usual for this engine.
JKL is offline   Reply With Quote
Old 11-26-2010, 09:27 PM   #32
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
mine also included a key to the Playboy mansion
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 11-27-2010, 06:50 AM   #33
PABiker
Anywhere but here
Oddometer: 3,892
Make me a copy please.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 11-27-2010, 11:08 AM   #34
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
I thought I saw you there. I gave you the Adventure salute but you were too busy .
tahoeacr is offline   Reply With Quote
Old 11-28-2010, 12:36 PM   #35
twotyred
Practising Recedivist
twotyred's Avatar
Oddometer: 2,106
I have had my 2010 FE450 for one year now and have clocked up 100 hours. The more I ride the bike, the more I like the bike.
Had the shop fit frame guards, radiator guards, case saver, pipe guard, rear master cylinder guard and Barkbusters. I swapped my Pivot Pegz with my 640 Adventure.
I am a riding gumby and this bike fills me full of confidence. I really like it's low speed balance and manoeuvrability. I am amazed at the way the thing climbs hills. I have never bogged the engine on a climb and I have never even used the clutch to prevent the engine stalling. The EFI is fantastic.
I have purchased a Safari tank and that will be installed soon. I am in the process of cleaning up an smoothing the sharp edges of the brackets. I also purchased a Rekluse clutch earlier this year. Still in two minds weather to install or not.
Love the way the bike cleans up after a ride and the ease of air filter maintenance is brilliant.
I love this bike.
If you succeed at first...don't look surprised!!
More enthusiasm than ability!!
twotyred screwed with this post 12-20-2010 at 03:51 PM
twotyred is offline   Reply With Quote
Old 11-28-2010, 12:41 PM   #36
twotyred
twotyred's Avatar
Oddometer: 2,106
These guys supply quality gear.
www.bboffroad.com.au
The Husaberg stuff is here:-
http://www.bboffroad.com.au/450_570_2009+.htm
Old 11-29-2010, 08:28 AM   #37
toro618
toro618's Avatar
Oddometer: 978
2011 suspension
I am considering one of the two, so by any chance, anyone here know what rider weight the 2011 FE390 or 450 are sprung for from the factory? I weigh 154 lbs without gear and am wondering if the stock F/R suspension would need to be redone.
Thanks in advance
toro618 is offline   Reply With Quote
Old 11-29-2010, 09:52 AM   #38
Fizz
Fizz
Fizz's Avatar
Oddometer: 168
Originally Posted by PABiker
Good question, I haven't looked at mine since I brought the bike home last June.
I went down to the garage and found it, here's what I got:
A couple stickers with the VIN number
A couple pieces of paper with the VIN number
Owners manual (in English)
Owners manual (in Spanish)
Spare parts manual, engine
Spare parts manual, chassis
Toolkit (almost forgot that because it's on the bike)
A copy of my Certificate of Origin
A copy of the diagnostic printout showing the installed MAP
A copy of the Bypack List (everything that was in the box with the bike)
Husaberg pen
That's it.
I also got:
- a larger rear sprocket
- longer chain
- spare clutch perch bracket
- steering lock keys (maybe masterkeyed for the PB mansion)
- husaberg CD with sales video
Fizz
Fizz is offline   Reply With Quote
Old 11-29-2010, 09:57 AM   #39
xcflyn
xcflyn's Avatar
Oddometer: 1,158
390-450
Are any of the husa's dual sport ? (49 state legal for road use).
Really want FI -no carb but may have to do a exc.
xcflyn is offline   Reply With Quote
Old 11-29-2010, 05:33 PM   #40
PABiker
Anywhere but here
Oddometer: 3,892
Only the 2011 570 is street legal from the factory in the US.
But all the '09 and '10 models as well as the '11 390 and 450 can be made street legal very easily, mine is.
'12 Suzuki DR650SE
Old 11-29-2010, 05:57 PM   #41
CodeMonkee
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,573
Thanks in advance
I believe this is the default springs:
Weight of rider: 75... 85 kg (165... 187 lb.) 4.4 N/mm (25.1 lb/in)
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 11-29-2010, 07:38 PM   #42
toro618
toro618's Avatar
Oddometer: 978
I am not so sure it would be easy here in NJ if the title says "Offroad Only". But it would be worth a try to just walk in to a DMV and go through the process and hope it works.
Old 11-29-2010, 07:49 PM   #43
toro618
toro618's Avatar
Oddometer: 978
Thank you. The stock suspension then should work fine for my wieght. I am 154 lbs without gear. With riding gear and hydration pack, I should be around 175 lbs. I don't really care for taking the bike apart to send out the forks and shock for retuning.
Old 11-30-2010, 07:43 AM   #44
PABiker
Anywhere but here
Oddometer: 3,892
The COO for my '10 said motorcycle, so the DMV never questioned it.
But if you are buying one that is already titled as off-road, then you may have a problem.
'12 Suzuki DR650SE
Old 11-30-2010, 07:48 AM   #45
toro618
toro618's Avatar
Oddometer: 978
May I ask which dealer you bought yours at? Maybe I can get one from them.
Times are GMT -7.   It's 11:17 AM.
