Old 11-16-2013, 09:01 AM   #4576
mathews42
mathews42's Avatar
Oddometer: 336
I guess I never got the engine braking down with the z-start. I'll probably give it a try. Good to hear the positive feedback on the Core exp.
I have looked at the charts for rekluse and the different settings on how it engages and how quickly. So I'll likely have to fool with it a bit.
Thanks for the input.
Sent from my iPhone using Tapatalk - now Free
Beads in the headlight a Flying Aga Tale by Isabel Dyson I met these two travelers on their Journey from the UK to Alaska and through South America on a 1979 BMW R100RS. Their book is now on Amazon for Kindle.
mathews42 is offline   Reply With Quote
Old 11-16-2013, 07:12 PM   #4577
D.B.Cooper
Unaffiliated
D.B.Cooper's Avatar
Oddometer: 21
I have the CoreEXP in my 570 and had a problem with my slave cyl on the second ride. The slave stuck in and started leaking. In all fairness, this is my first experience with a Rekluse, and I may have had it misadjusted, I donno, I have never ridden one before.
Has anyone had a problem with their slave cylinder after adding the Rekluse? I notice that most are using the Rekluse slave as well, is it only for adjustment purposes?
D.B.Cooper is offline   Reply With Quote
Old 11-16-2013, 09:58 PM   #4578
BogeyMan
BogeyMan's Avatar
Oddometer: 449
For me, yes.
I mounted the CoreEXP on my 570 and never had a single problem.
My thoughts is that your slave cylinder was gonna go with or without the Rekluse. There's no need to even touch the slave when installing the CoreEXP.
I haven't needed to adjust my Rekluse much, but it's so much nicer now just having to whip out a 4mm hex wrench and be able to fine tune things whenever I feel like it.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 11-17-2013, 05:19 AM   #4579
D.B.Cooper
Unaffiliated
D.B.Cooper's Avatar
Oddometer: 21
I figured it was just a coincidence, but then I started thinking that the Rekluse is constantly modulating the clutch at low RPM's and wondered if it hastened the failure of the slave I am not passing any blame, this is the first problem I have had with the bike (besides the battery), and I have beat the living crap out of it. I love this bike I have 37 hrs on it and just over 200 miles if that says anything about the way it is used
Old 11-17-2013, 09:38 AM   #4580
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,456
Guys, any idea where I can get spare plastics for my FS570?
06 950S, YZ250WR, 300 TXT Pro
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV,Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Old 11-17-2013, 11:54 AM   #4581
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,573
Give edelmans a call in troy ny
Seth S
Seth S is offline   Reply With Quote
Old 11-17-2013, 03:24 PM   #4582
LukasM
Oddometer: 5,425
Any Husaberg dealer, nobody makes aftermarket plastic.
Old 11-17-2013, 09:50 PM   #4583
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,207
http://www.ktm-parts.com/SBMHUSPL.html
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 11-18-2013, 01:18 AM   #4584
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,079
http://www.cyclebuy.com/husaberg/acc...Graphic_Kit_FE
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Old 11-18-2013, 08:55 AM   #4585
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,761
i bought white tank shrouds from cyclebuy and got them in a few days.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 11-18-2013, 09:09 AM   #4586
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,390
I used to run a Z start pro rekluse on my WR450 to bandaid the tall gearing... I wouldn't use a auto clutch again, the bergs simply dont need them, unless you race motocross. On mountain trails the rekluse becomes a safety issue as there is zero engine braking at idle or when the motor is off... so when you are on the edge of a cliff going to make a turn up a tight switchback, there is nothing holding you if you cant get your foot on the brake (almost lost a bike from this). If you don't ride technical singletrack it probably won't be an issue for you, but I still don't see the need with the super wide tranny that these bikes have.
n16ht5 is offline   Reply With Quote
Old 11-18-2013, 10:03 AM   #4587
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,973
Fuel Solution......
Bought a 3L bash plate from Force....added some heat shield and a larger bung with a vented cap.....true to its claim...I was able to put .8 gallons in....
The plate is a one bolt release...sized to use the stock T-handle in the tool kit...plate off or on in under 30 seconds....
Ran in Death Valley this weekend...averaged just under 40mpg...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 11-18-2013, 05:16 PM   #4588
just jeff
Oddometer: 1,084
Hi Nowwhat!
I am wondering where you found that bashplate. Do you have a link?
Regards....just jeff
just jeff is offline   Reply With Quote
Old 11-18-2013, 06:40 PM   #4589
rensho
Oddometer: 178
Originally Posted by Nowwhat View Post
Fuel Solution......
Is the fuel connected to the main fuel tank? Looks great!
rensho is offline   Reply With Quote
Old 11-18-2013, 06:55 PM   #4590
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,973
http://www.forceaccessories.com.au/
The bash plate tank doesn't connect....any break in the action after 40 miles and I take 90 seconds and dump the 3l into the main tank......
added this:
http://www.bungking.com/bungs-18/fil...ng-vented.html
Times are GMT -7.   It's 10:19 PM.
