Old 11-27-2013, 05:46 PM   #4651
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,392
Sorry to hear about this major issue.
Not much choice here as I suspect you already know. Buy a new wiring harness is what I recommend.
You can remove the stocker and replace all the wires but that would be a major pain. Hope none of the fuel injectors or fuel pump got hit either.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 11-27-2013, 06:41 PM   #4652
shooter114
Oddometer: 5
project maifurberg
I'm assuming this is where you post things about your own bike for discussion ?!
Well here goes anyway, my usual trail blaster/weekend warrior - 2009 - 450 berg ... its all love and hate with this bike... one day it'll all be love. .. one day
Got it second hand in 2011 with an akro slip on, low km's, some suspension work done ( unknown ) .. and an incorrectly installed impeller shaft seal >.<
First ride it boiled over, got the thermofan and liquid intelligence "coolant", fixed impeller seal and added force radiator gaurds/barkbuster handgaurds.
Then the mods/bolts on's flowed from there and it now sits with ...
Barkbuster handgaurds
BRP handgaurd mounts on BRP vibration dampening submount
Scotts steering dampner
Renthal enduro high bend bars. ( still a bit low might have to raise with risers ) with bar end mirrors mounted under bars between top clamps and brake levers
Balanced wheels, pirelli xcmh front and rear, awaiting nuetech tubliss for both
Moose species headlight, upgaded to dual 35W HID, retrofitted into berg front fender and headlight mask.
DRC turn signals - flush mount rear triangular front.
Rekluse core exp 2
Left hand rear brake, with MC off quad that has park mech built in to stop bike rolling also using foot brake by using rekluse brake cylinder sleeve.
Drilled radiator shrouds for more airflow with funnel web filter air filter (nice power gain across range)
Extra cushioning added to seat and new seat gripper seat cover - couch like
Fastway pegs in low boy postion
Kush sprocket ( noticeable difference on road )
G2 ergonomics throttle tamer
Stegpegz
Weep hole mod
Powersport lithium battery
DIY rotary dial MAP switch MOD
BRP chain guide
All thats needed now is to get the suspension serviced/set up for my weight, raise the bars to open the riding position up ( too far forward ),add charger lead for battery, do all the "berg mods" , install security and GPS, add more protection to bike - bash plate, exhaust wrap or ceramic coating etc, fit super moto wheels and the last but not least graphics.
No decent pics atm, if requested pics of certain mods could be taken.
shooter114 is offline   Reply With Quote
Old 11-27-2013, 07:07 PM   #4653
shooter114
Oddometer: 5
Lukas m
Lukas, for your melted wire situation
Do you have a megger( insulation resitance tester ) ?!
The easiest way to test and fault find electrical problems is to divide the circuit into components and wiring sections, e.g pumps, switch blocks, single cables and looms. From there you can test/inspect each component to see if there is a fault, e.g dead short in a motor, down to ground faults from active circuits.
You can do this with a normal multimeter with resistance function, but depending on brand and type will only pick up a certain value( generally will only pick up dead shorts )
However an insulution resistane tester will pump out up to 1000v DC with minimal current and if say a cable is chaffed and near a frame say .5mm, the spark can jump and will indicate a fault. CAUTION has to be taken with components, as certain components can't handle the high voltage- electronics, certain electrical motors etc.
From this you could test all the suspected components by using manufacturers methods to see if they are within spec and eliminate where the fault started from.
I dare say as its limited to a certain section of the circuit and that there was a ground cable loose, that the high resistance pathway of the loose ground caused an overload of the section causing it to melt ( increased resistance = increased current ).
Depending on the connection type you could replace that certain section of cable. If this is a race/ compeition bike( from memory it is ) it might be best to replace the whole loom regarding to this part of the circuit, test each component thoroughly, add extra protection to the cabling ( to stop cables rubbing against frame etc ) and to use methods to prevent water/ dirt ingress to connectors etc and check that upgrades and mods that you have done arent overloading or affecting circuits in any way ( heat - friction - electrical load )
Old 11-27-2013, 07:13 PM   #4654
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,218
Originally Posted by LukasM View Post
Hey guys,
I think I've got a serious problem.....
I took my bike apart recently to fix what I believe is a partially clogged injector (the engine would sputter in the top RPMs if you give it full gas ), replace the battery, and finally clean off all the sand that got everywhere from running the Tuareg Rally earlier this year.
Everything was going smoothly until I put everything back together and tried to fire up the bike: the starter relay just clicked and the bike didn't manage to turn the engine over, which was strange as the new battery was fully charged. Then all of a sudden I saw smoke coming from the headstock area, and I think a little bit from under the battery box. I immediately disconnected the battery so it didn't last more than a couple of seconds, but the damage was done:
I have now traced the melted ground wire up front that is part of the main harness, and apparently the other end goes to the left side handlebar switch? I also found out that the ground bolt was fairly loose, which might explain why it didn't turn over properly. I couldn't find any chafed or melted wires under the battery box, but almost everything there is wrapped or covered so it's hard to see. Quite possible that even more wire burned up in the main harness, it was very warm to the touch right after this happened...
Really frustrated right now, and I would very much appreciate some pointers on how to go about finding the cause of the meltdown and then how to fix this mess.
Cheers,
Lukas
Hi Lukas, yes that's a bit of a mess for sure and you are right to worry about the rest of the wiring harness. A new harness is really the only good answer and probably less work overall than trying to rebuild what you have.
As you know the wires are tightly packed on this bike, especially the area under the battery box to the main frame going up front. Lots of places for chafing and crushing wires. A loose main ground would also cause lots of problems and maybe even rerouting of the current to the smaller ground wires, overheating them. Wires can often get crushed up at the steering head where forks can grind them against the frame if they are too close. It's hard to see because they are in an outer sheath. Your sensors should be OK as long as the connectors and wires to them look OK
Racing at high revs puts a lot more vibes on the harness and any area where it could chafe/rub/scarpe, will chafe/rub/scrape and of course bolts get loose like the main ground. I went through my FE and put thin polyurethane self-stick film under every spot the wires rubbed mounts, frame, engine etc. and tie-wrapped them in place to reduce movement.
I used to rebuild and rewire small commercial aircraft many years ago and there you have to be hyper-vigilant about anything that can rub on anything else and cut, short, burn.
Not much fun, but strip it down and lay in a new wiring set (groan).
cyborg is offline   Reply With Quote
Old 11-27-2013, 08:33 PM   #4655
mathews42
mathews42's Avatar
Oddometer: 336
I think I would attempt to fix each wire and trace back each one to follow damage. Its worth trying. Good luck to you and sorry about your luck.
Post back if it was a faulty ground and where it was located maybe you can prevent others the same issue.
Beads in the headlight a Flying Aga Tale by Isabel Dyson I met these two travelers on their Journey from the UK to Alaska and through South America on a 1979 BMW R100RS. Their book is now on Amazon for Kindle.
mathews42 is offline   Reply With Quote
Old 11-27-2013, 08:35 PM   #4656
mathews42
mathews42's Avatar
Oddometer: 336
Question
What is the best deal you have found on a new Front Safari tank for the FE570?
I'd love to not spend 700 on one. If anyone has one sitting around I'd be interested.
Old 11-28-2013, 12:14 AM   #4657
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,573
I have a rear I would let go for $450
Seth S
Seth S is offline   Reply With Quote
Old 11-28-2013, 12:54 AM   #4658
frostyuk
frostyuk's Avatar
Oddometer: 274
Fork offset
My berg is one of the early 09 models that had the 19mm offset rather than the 22mm of the later bikes, i bought a set of factory triples from LukasM which can be either and after about a year i've just tried moving to the 22mm to see what its like ...... wow i can see why you guys have steering dampers, a lot sharper steering, holds a line a lot better but more twitchy and less stable, not sure how i feel about it at the moment but will give it a few more rides before i decide to leave there or go back, not that its difficult to change. Just thought i'd let you know :)
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 11-28-2013, 05:11 AM   #4659
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,751
I'm with Cyborg,...It will be a lot easier to replace the whole wiring harness then to test every single circuit. With the main ground being loose that's a 90% probability the cause of it all. By going with a new harness it will be a lot of time saved and more assurance that you're starting fresh as it very improbable any components that the harness plug into caused the issue at hand.
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 11-28-2013, 07:12 AM   #4660
mathews42
mathews42's Avatar
Oddometer: 336
Thanks for the offer, but I really jut want the front safari. The rear limits hmm luggage options.
Sent from my iPhone using Tapatalk - now Free
Old 11-28-2013, 07:46 AM   #4661
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Shooter - That's a long list of some v. nice mods. My '10 FX450 has some of the same ones. Getting to suspension dialed in is a top priority.
If you aren't a expert w/ setting up the Berg suspension, get help from someone that is. They respond to adjustments a little differently.
My bike has the ceramic coated exhaust (all parts from head to can, inside and out), a free flowing can, Engine Ice coolant, NO thermostat and NO fan. I have NO overheating or boiling gas issues. Virginia is quite warm and humid in the summer.
Rox brand risers are nice, providing maximum adjustability. Because of their design, they are 2" long/high, so if you only need to go up a little they may not be for you.
Lazy Traveler
SRG is offline   Reply With Quote
Old 11-28-2013, 09:32 AM   #4662
LukasM
Oddometer: 5,425
Thanks for all the detailed feedback and instructions guys, I appreciate it!
The main harness is about $650 here, so buying a new one is really a last resort if I have exhausted all my options, and it would have to wait until I return from my RTW trip which starts in January.
Obviously I'm being optimistic, but what are my chances of the damage being limited to the one wire up front? I didn't get a chance to look at it in detail since this happened at 1am last night, but it appears that the one melted brown wire leads to a bundle of them being terminated near the headstock, and then they all go to the back together. If they are merged into one thicker gauge wire, maybe the thinner gauge one at the front acted as a fuse before causing any more damage?
If I could just find out for sure that the loose ground was the cause of the problem, that would be a great start...
Old 11-28-2013, 12:09 PM   #4663
kito
Oddometer: 278
I once burned out a loom . That was only because of a lose earth. . At $650 I'd rewire. Remove the loom from the bike replace 1 wire at a time . Maybe make 1 of the wires with a temp link with a fuse ( to be on the safe side ) to test to see if it was just a loose earth
kito is offline   Reply With Quote
Old 11-28-2013, 03:29 PM   #4664
shooter114
Oddometer: 5
Thanks mate !
Ironically, I just popped back on here to talk about suspension. There's a suspension shop near me that specialises in enduro set ups and in particular WP suspension. Good rep and price from what I hear, but before I go to them ....
I have some x-trig adjustable offset tripples that I picked up off flea bay - they are suited for 50mm forks. Do I buy an old set 98-00 set off 50mm WP forks and then get them adjusted serviced with all my suspension and sell off my current forks and tripple ? ( how much would they be worth ?! ) or sell the xtrig tripples and put that towards suspension servicing/upgrades ?!
Interested to know if you got the ceramic coating done at a shop or DIY? Free flowing as in no spark arrestor and silencer insert?
Mine still boils if going through tight slow sections or getting stuck on a hot/humid aussie day. Its using 50/50 coolant with water wetter and a radiator temp sticker, which normally reads in an acceptable range, so im putting it down to exhaust and heat shielding.
The rox risers do look nice and functional in the sense that you can raise the bars and rotate them forward/back - guessing in need between 1-2 inches atm... actually i might get a set as i could raise the bars and move my riding postion back ....
Old 11-28-2013, 04:46 PM   #4665
SRG
SRG
SRG's Avatar
Oddometer: 1,287
Shooter - I don't know about the adjustable triples if you have to change the forks to use them. I do know that the Berg is sensitive to small adjustments of the forks and shock. The light front end makes it respond differently from the KTM's. I had a guy at genuinedirtracer.com/‎ give me some advice - which was a bit different from even what's in the Berg manual. I would seek advice from someone familiar w/ the 70* Bergs in particular.
The PO had my bike set up by them (GDR) at purchase. They did (or had done) the ceramic coating, so it was a pro job. Still looks very good at 150+ hours. The PO had the can swapped out at purchase too. It's an FMF Powercore 4. It has a sparkie but no silencer insert. It's a little loud at full throttle, less so if you behave a bit.
Lazy Traveler
Times are GMT -7.   It's 08:46 AM.
