Old 01-08-2014, 11:41 AM   #4786
johnno950
Oddometer: 1,076
Originally Posted by BogeyMan View Post
I'm going through the bike servicing all those often missed parts. Can anyone confirm the correct KTM part number for the lower shock bearing (on the 570)? I have 50304090144 from the parts list. Even found it online at Amazon.
I'm going to replace the swing arm bearing(s) too. Went to Pivot Works for those (here).
Not sure about the steering head bearings - I have part number 54201081100 (top & bottom). Can anyone recommend a source for those (other than KTM OEM parts?
50304090144 from parts fisch description of part cv pivot bearing/bush pds'11
johnno950 is offline   Reply With Quote
Old 01-09-2014, 03:18 PM   #4787
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,761
Remapping ECU
Anyone know of a dealer in SoCal that I can trust to send my ECU to for a re-map? Or outside this godforsaken state works too.
Just dont want to send it to some unknown and have them lose my ECU or other horrific result..
Also, is the KW817EU0901001 euro comp map the most-current version for the FE570?
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 01-09-2014, 03:56 PM   #4788
1 lunger
1 lunger's Avatar
Oddometer: 1,286
Husaberg 70 Degree Owners Thread!
Can't help with dealer SoCal, but that's the good map #. I can tell you about a good dealer on the east coast. I bet you could have it back in a weeks time.
1 lunger is offline   Reply With Quote
Old 01-09-2014, 04:08 PM   #4789
vintagespeed
fNg
Oddometer: 1,761
Question
yeah i might do that, the responses i've had from a couple local dealers like; "...uh...husa...buh..what? that's a KTM??.." and "$65 and you need to bring the bike in", aren't giving me the warm fuzzy feeling...
also, one dealer here said he had to have the bike so they could contact Husaberg and get a release to do the map.
i'm not sure that applies to the 70degree Bergs, does it?
Old 01-09-2014, 06:03 PM   #4790
SRG
SRG
SRG's Avatar
Oddometer: 1,287
These guys, in North Carolina, know their Berg stuff.
http://ridepgpowersports.com/
Lazy Traveler
SRG is offline   Reply With Quote
Old 01-09-2014, 06:48 PM   #4791
TLtrials
TLtrials's Avatar
Oddometer: 274
Originally Posted by srg View Post
these guys, in north carolina, know their berg stuff.
+1
TLtrials is offline   Reply With Quote
Old 01-09-2014, 08:53 PM   #4792
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,973
you can see their work a little here.....
great customer service
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is online now   Reply With Quote
Old 01-10-2014, 08:07 AM   #4793
ChasM
Oddometer: 300
Battery Tender vs TurnTech Battery
Can you use a battery tender on a turn tech battery?
Yes, however a Battery Tender will not fully charge a lithium battery and the steady state 'floating mode' is not really high enough.
Trailbike Sportsmen Assoc/AMA
'14 BMW R1200GS LC
'09 Beta 565 RS (with Revloc)
'08 KTM HTR 350 XCF-W(Revloc
'74 Norton 850 Commando
ChasM is offline   Reply With Quote
Old 01-11-2014, 02:27 PM   #4794
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
I have a TurnTech 10 amp in my 990. Left something on for I don't know how long(couldn't remember the last time I was playing with the bike). Went to start the bike and it was at 1.7 volts. Thought the battery was toast. 10 amp charger for twenty minutes and started the bike. Then did the 1.25 amp trickle overnight. All is well and that was a year ago. Battery is 3 years old+ .
tahoeacr is offline   Reply With Quote
Old 01-11-2014, 04:21 PM   #4795
1 lunger
1 lunger's Avatar
Oddometer: 1,286
Good to know!! Thanks!
Old 01-12-2014, 11:04 AM   #4796
1 lunger
1 lunger's Avatar
Oddometer: 1,286
Took the berg out today with the studs in. I love crossing slick logs on a 45* angle without worry and hanging wheelies across long stretches of ice!
Old 01-14-2014, 11:00 AM   #4797
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,973
Suspension Testing....
Old 01-14-2014, 11:50 AM   #4798
vintagespeed
fNg
Oddometer: 1,761
It appears to be working...
-jb
Posted with TapaTalk on i5
Old 01-17-2014, 06:51 AM   #4799
Ghostbrother
Ghostbrother's Avatar
Oddometer: 106
"IP-Rider"
Is there life before death ... I believe that.... RW Offroad
Ghostbrother is offline   Reply With Quote
Old 01-20-2014, 08:58 AM   #4800
vintagespeed
fNg
Oddometer: 1,761
got the Berg out to the dez yesterday, almost have the suspension where i want it. and the Rekluse works well in the sand, digging it! this bike is the easiest to ride of my bunch and after just a few trips out with it, i really feel comfortable just mobbing it through the hard stuff. i traded bikes with my buddy and he had the same impression of the Berg, smooth, powerful, nimble and well suspended. and no vibes! (although his bike is a kx500 in a 250 frame, so "no vibes" is kindof relative.)
edit: got the 70degree subframe tank on, what a pain in the arse!
vintagespeed screwed with this post 01-20-2014 at 09:25 AM Reason: blah
Times are GMT -7.   It's 10:18 AM.
