Old 03-23-2014, 05:01 AM   #5011
Koko
Oddometer: 91
I'm horrible at reading wire schemetics. I don't understand how to read them. I guess that's why I'm an accountant.
These wires are all behind my headlight. I have one plug out back under my seat with a KTM connector. It has Brown, purple and black. Since there is two connectors up front with Brown/Black and Purple/Black I'm assuming this is the turn signals. Now I'm trying to figure out what a black yellow wire is with a butt connector and which connector is for the horn.
Koko screwed with this post 03-24-2014 at 07:33 AM
Koko is offline   Reply With Quote
Old 03-23-2014, 06:50 AM   #5012
Duken4evr
Duken4evr's Avatar
Oddometer: 342
Originally Posted by Tee2 View Post
Post up some photos of the install. I need to o this too.
Here is my sorry redneck setup, complete with coathanger wire and old radiator hose for cushioning.
The filter goes in place of the quick connect. When pulling the tank, I leave the filter on the line, that way the sensitive injector side is never exposed to the dusty dirty cruel world.
DJH sells the manual cam chain tensioner. I put these on all my dirt bikes. Don't even really know of KTM has an issue with this, but so many brands do have CCT issues that it is a reflex action at this point. Not much to go wrong with a screw and locknut. Set it properly, keep clean oil in it and forget about it :)
Bonus 'Berg photo. The weep hole on the water pump faces forward. Over time fine grit can get in and work on the seal. "DaleEO" over on the Unofficial Husaberg Forum came up with this mod - adding a nipple and hose to the weep hole. I did mine in 'Berg blue! Got the tiny tubing at an RC supply store.
2010 Husaberg FE450 (plated)
2001 Honda CR250 (out of state riding buddy's bike stored in CO for his annual epic ride) fills my need for the occasional 2 stroke hit!
2006 Yamaha FZ1
Duken4evr is offline   Reply With Quote
Old 03-23-2014, 11:10 AM   #5013
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,753
Originally Posted by Duken4evr View Post
.... Set it properly, keep clean oil in it and forget about it :)...
I agree the manual CCT is the cats pajamas. My cam chain must be worn more than yours because it is adjusted correctly..
-jb
Posted with TapaTalk on i5
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 03-23-2014, 07:33 PM   #5014
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,198
Over heating
Ok guys, what fan kit are you installing to help with over heating? I did some tougher single track today and over heating was definately an issue.
Reidy008 is offline   Reply With Quote
Old 03-23-2014, 08:46 PM   #5015
Dao1
Oddometer: 106
KTM Fan kit.
Dao1 is offline   Reply With Quote
Old 03-24-2014, 05:41 AM   #5016
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 637
Originally Posted by Dao1 View Post
KTM Fan kit.
Part # 81235941044
http://www.surdykeyamaha.com/pages/C...Product/209672
$112. Not sure if there is a better price but this one is the best I have found so far.
SCExpat screwed with this post 03-24-2014 at 05:44 AM Reason: URL
SCExpat is offline   Reply With Quote
Old 03-24-2014, 06:07 AM   #5017
Duken4evr
Duken4evr's Avatar
Oddometer: 342
Added the KTM fan kit and still was not entirely happy as the KTM thermo switch does not kick in until it is around 220F coming off the head. (I have a Trail Tech Temp gauge). I think this is a hangover from the older RFS bikes, which have little stator output and drain the battery if the fan runs too much.
I think the KTM switch is 100/105C. I am running a 90/95C switch meant for a 1984 BMW 318i car has my fan coming on around 206F, again measured coming off the head. The earlier activation of the fan creates more "reserve" before it gets stinky hot, and keeps the temp below 215 pretty much no matter how tortuous the trail, and I ride some rocky gnarly stuff here in CO in the thin air. If you are reasonably nimble, you can unscrew the KTM switch and screw in the car one with almost no coolant loss. The Napa part number is ATM 1435033, here is a link to the switch I am using.
http://www.napaonline.com/Catalog/Ca...033_0257596936
Also spliced in a manual fan switch but I honestly don't use it much since adding the car thermo switch. These bikes have 211 watts of stator output and can run the fan continuously, so draining the battery is not an issue. The only downside to all this cooling goodness is my right thigh can get roasted medium rare at times, particularly if I am sitting. This encourages me to stand up more as I ride, something I should be doing anyway
The 'Berg wiring harness has pigtails for the KTM fan kit. It is all plug and play.
2006 Yamaha FZ1
Duken4evr screwed with this post 03-24-2014 at 06:17 AM
Old 03-24-2014, 07:53 AM   #5018
Koko
Oddometer: 91
Updated my post #5015 above with labels. At least what I think the wiring is for. Just looking for someone to help and confirm.
The previous owner told me all 'Bergs come with the map switch. Is this true and the handlebar mount is just for convenience? Or did he pull one over on me?
Old 03-24-2014, 08:52 AM   #5019
PABiker
Anywhere but here
Oddometer: 3,892
Husaberg 70 Degree Owners Thread!
The yel/blk is engine kill just like the other one in the pic, the Berg has two. I have one connected to the CEV kill button and the other to a Sicass key switch.
As for the Map switch, it is not factory installed, his dealer may have given it to him for free. The plug for it is there from the factory but the actual switch has to be added.
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 03-24-2014, 10:10 AM   #5020
vintagespeed
fNg
Oddometer: 1,753
Originally Posted by Koko View Post
I'm horrible at reading wire schemetics...
how about a color coded one?
yes, the purple/black & brown/black wires are turn signals, those are the plugs going to the TS lights themselves coming out of your turn signal switch on the bars.
your turn signal relay should have a purple/black & brown/black wire going to it from the light switch on the bars.
the horn plug should be purple/yellow & grey according to the diagram. can't tell from the pic.
edit:
(i may be color blind, and/or your model year may be different colors....this is for '09)
H2 - LF turn signal
H8 - parking lamp
H9 - headlight
H7 - HI beam indicator light
H4 - TS indicator light
H3 - RF turn signal
B8 - map switch (IIRC)
P1 - dashboard
K3 - TS flasher
S2 - front brakelight switch
S4 - turn signal switch (CEV switch half on bars)
S5 - headlight/kill/horn switch (CEV switch half on bars)
H10 - horn
S6 - rear brakelight switch
X200 - Tail/Brake light wire harness plug under the seat (white 4 PIN plug, only 3 wires)
X400 - Turn signal wire harness plug under the seat (white 3 PIN plug, 3 wires)
H6 - LR turn signal
H11 - license plate light
H12 - brake light
H5 - RR turn signal
vintagespeed screwed with this post 03-24-2014 at 10:33 AM Reason: blah
Old 03-24-2014, 10:59 AM   #5021
Koko
Oddometer: 91
This is great. Thank you very much.
Additional wiring question.
Sicass racing told me the Husaberg comes with the Horn wiring. They said the wiring is tied back in the harness under the frame.
I removed the tank but still don't see it. Next step is to remove the radiators so I can see what's in between.
Is the horn wiring there? Or am I. On a witch hunt. Is it a set of spade connectors?
Koko screwed with this post 03-25-2014 at 08:24 AM
Old 03-25-2014, 09:26 AM   #5022
SmileyRider
With lots of Teeth
SmileyRider's Avatar
Oddometer: 37
It is there, I honestly searched for 5 minutes and thought sicass was mistaken, but it is there, right hand side of the bike. Its tucked up and hidden really well.
It's not very long though
SmileyRider is offline   Reply With Quote
Old 03-25-2014, 09:55 AM   #5023
Koko
Oddometer: 91
Did you have to remove the radiators? My enduro engineering radiator support just completely in the way I can't see or reach anything.
Old 03-25-2014, 12:37 PM   #5024
Diravi
Oddometer: 45
I've just installed the KTM fan kit on my 390, but with a 87/82C switch, it was recommended by a local KTM racer. Best would be to measure oil temps, as we do on the XRs.
Diravi is offline   Reply With Quote
Old 03-25-2014, 03:12 PM   #5025
Cruz
Lost but laughing.
Cruz's Avatar
Oddometer: 6,031
Diravi, what info do you have on your 87/82c switch so we can have a look for it locally?
"I reckon it would be good getting a heap of XR's in the one spot and watching a heap of blokes kicking fuck out of there bikes and swearing."
xronly
Cruz is offline   Reply With Quote
Times are GMT -7.   It's 11:15 AM.
