Old 03-26-2014, 01:35 PM   #5041
Koko
Oddometer: 105
Originally Posted by bayarearider View Post
I am looking to get a couple of spare air filters and I can only find 1 Twin Air filter on e-bay but there are several from HiFlow. I have never used HiFlow before and was wondering whether anyone here have used and their recommendation on it.
What about a DT1. These are good filters.
https://www.denniskirk.com/306625.sk...FYN0Ogod2wMA2g
Koko is offline   Reply With Quote
Old 03-26-2014, 02:30 PM   #5042
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
I have no problems with them.....lost of dust in my world....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 03-26-2014, 03:02 PM   #5043
1 lunger
1 lunger's Avatar
Oddometer: 1,302
+1 on the DT filter!
Life is good!
1 lunger is offline   Reply With Quote
Old 03-26-2014, 03:44 PM   #5044
mattadv93
mattadv93's Avatar
Oddometer: 228
@bayarearider - what range do you get out of tbe subframe tank and safari tank? Thinking about getting the same set up for my 570.
The world is a book and those who do not travel read only one page.
-Husaberg FE570
mattadv93 is online now   Reply With Quote
Old 03-26-2014, 05:39 PM   #5045
bayarearider
Oddometer: 139
The range I am not sure. But I can fill up 5 gallons with the combination. I will be in Death Valley, starting tomorrow. So I will check the range. I know I can go 200 miles for sure on dirt roads, but on dunes it might be a different story. If you are thinking about the sub frame tank, please get it asap as they stopped making them officially as of the end of Feb. You might still get some from Cyclebuy.com but those are the last batch. If you have problems fitting all 3 together send me a PM and I will give you some tips. I had a lot of problems before I finally sorted them out. But once sorted I am very happy with the set-up. The good thing about getting the sub frame tank is the aluminum fuel pump housing which comes with the kit that makes a huge difference if you want to add the safari tank.
bayarearider is offline   Reply With Quote
Old 03-26-2014, 06:54 PM   #5046
mattadv93
mattadv93's Avatar
Oddometer: 228
Bugger looks like they sold out. Might just have to go with the safari tank. Thank
Matt
-Husaberg FE570
Old 03-27-2014, 04:20 PM   #5047
mattadv93
mattadv93's Avatar
Oddometer: 228
Hi
A used scotts steering damper has come up for sale in my area for a good price. It says on the ad that it suits KTM EXC 200-525 2000-07 and SX 2000 - 06, anyone know if this will fit a 09 fe570?
Cheers
Matt
-Husaberg FE570
Old 03-27-2014, 05:40 PM   #5048
1 lunger
1 lunger's Avatar
Oddometer: 1,302
Got these in the mail today. I'll let you all know what I think.
Life is good!
Old 03-27-2014, 06:30 PM   #5049
SmileyRider
With lots of Teeth
SmileyRider's Avatar
Oddometer: 37
Life is good!
Please share your thoughts on them when installed
SmileyRider is offline   Reply With Quote
Old 03-28-2014, 06:12 AM   #5050
1 lunger
1 lunger's Avatar
Oddometer: 1,302
installed
Life is good!
Old 03-28-2014, 08:41 AM   #5051
Dao1
Oddometer: 120
Hi
Cheers
Matt
I called Scott's on this, b/c I have a Husaberg stabilizer mount posted up here f/s and I wanted to know whether it would also interchange w/ KTM.
According to Scott's,
The top mount and the stabilizer itself will work for both ktm & husaberg FE slanted motors, but the post mount for the slanted motor Husaberg is specific, and will not interchange w/ KTM.
Dao1 is offline   Reply With Quote
Old 03-28-2014, 09:50 AM   #5052
pne
pne's Avatar
Oddometer: 888
installed
Life is good!
what are those supposed to do?
Touring USA on a KTM Superduke, I have no idea what I'm doing:
http://advrider.com/forums/showthread.php?t=890358
pne is offline   Reply With Quote
Old 03-28-2014, 10:58 AM   #5053
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,715
they look like the little things that some people use as an aid for resting their boots against for long periods of standing..they also give you another leverage point to push the bike with...just my guess
Seth S
Seth S is offline   Reply With Quote
Old 03-28-2014, 11:30 AM   #5054
LukasM
Oddometer: 5,426
Yup, that's exactly it.
Old 03-28-2014, 08:31 PM   #5055
Reidy008
I,m in if we go fast
Reidy008's Avatar
Oddometer: 2,277
Fan install
Ok fan install is going well but now I need a little help. The wiring harness ....
The white connector was behind the radiator on the right but am I meant to pull the temp switch from the motor and reinstall the one in the kit for the harness to go to? If so then what do I do with the wiring and cap that cam e off the plug in the motor?
In the instructions the plug would go in the bottom or the radiator but my radiator doesn't have the place for that.
Reidy008 is online now   Reply With Quote
Times are GMT -7.   It's 06:59 PM.
