Old 04-06-2014, 06:28 AM   #5146
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Originally Posted by cyborg View Post
And, I bet it was MSTIL too!
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 04-06-2014, 10:35 AM   #5147
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,203
HF
It sure was as you know, since you rode it too just before me. Only difference is I rode over a large "roller" rock during the bumpy climb. Sometimes the trail gets you.
cyborg is offline   Reply With Quote
Old 04-06-2014, 11:54 AM   #5148
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,386
ouch. blame the luggage! with an existing rear weight bias i find the 570 really starts to handle strangely with luggage on the rear.
B1 is offline   Reply With Quote
Old 04-06-2014, 02:08 PM   #5149
1 lunger
1 lunger's Avatar
Oddometer: 1,264
Husaberg 70 Degree Owners Thread!
Originally Posted by 1 lunger View Post
Anyone have any trouble with the seat coming off in the front? I stand 90% of the time, but when it's nasty and I'm sitting, my seat will sometimes come off the front pins. I put 2 spacers behind it and hope that will help. Just wanted to know if it's me or the Gutz Racing tall seat or a common thing.
Edit: the spacers worked perfect. They're 3/16" - 1/4". I put them behind the pin / air filter arm assembly and it was just enough to stop the seat from coming off up front. I used spacers I found in this over priced tray of nuts and bolts.
Life is good!
Life is good!
1 lunger is offline   Reply With Quote
Old 04-06-2014, 09:12 PM   #5150
just jeff
Oddometer: 1,036
Well I was very disappointed today. I attempted to install the rear Safari Tank on my 2011 570 and it doesn't fit. It doesn't fit over the subframe on the left side where the emissions canister used to be. Can someone enlighten me on this issue? Will I have to change out the subframe? There doesn't seem to be anything mentioned on Safari's website and after many searches on the forum I have found no mention here either. HELP!!
Regards....justjeff
ErikMotoMan: "People struggle with many things in their lives. But the answer to struggle isn’t MORE struggle. It’s peace. If you want more joy, peace, love, happiness… you have to GIVE those things first. You have to THINK those things. You have to have faith that they’ll come to you, despite what you may see. The truth isn’t in what you see with your eyes. It’s what you feel in your heart."
just jeff is offline   Reply With Quote
Old 04-06-2014, 10:21 PM   #5151
Dahlin
Need more time...
Oddometer: 169
17" to 21" ?
Is there a way to change front wheel size in the speedometer display?
On other Husaberg/KTM's, I am used to see 2205 in the display as an indication that the front wheel is a 21"
But now I am working on a 570FE -09 that indicates 1700-1800-something (can not remeber now) as for a Supermoto 17" front wheel.
In 2009 the FS model didn't exist, so I'm guessing that somehow , the wheelsize in the dispaly has been changed.
Any ideas?
2003 Honda CB1300
2009 Yamaha XT660Z
2011 Husqvarna TE630
2012 Husaberg FE390
Dahlin screwed with this post 04-06-2014 at 10:38 PM
Dahlin is offline   Reply With Quote
Old 04-07-2014, 02:38 AM   #5152
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 256
Regards....justjeff
Did you cut the side cover just under the subframe?
Picture 6
http://www.safaritanks.com.au/home/i...nstruction.pdf
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 04-07-2014, 09:11 AM   #5153
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
Regards....justjeff
You need to trim the plastic on the fender
Seth S
Seth S is offline   Reply With Quote
Old 04-07-2014, 10:08 AM   #5154
pinevalley
pinevalley's Avatar
Oddometer: 101
Jeff,
I assume you have the cut out for the smog equipment on you 2011, correct? I had to trim my sub frame (quite a bit) to get the tank to fit. The folks that have the subframe without the smog cutout or the sub-frame tank require only the fender to be trimmed. If you are interested I can see if I can dig up some photos.
pinevalley
Regards....justjeff
pinevalley is offline   Reply With Quote
Old 04-07-2014, 11:55 AM   #5155
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,753
Originally Posted by pinevalley View Post
Jeff,
I assume you have the cut out for the smog equipment on you 2011, correct?...The folks that have the subframe without the smog cutout or the sub-frame tank require only the fender to be trimmed...
should be fairly easy to find a non-smog subframe, i'm sure someone would sell you one.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 04-07-2014, 12:08 PM   #5156
Dahlin
Need more time...
Oddometer: 169
Any ideas?
This is how it's done:
Disconnect the speedo from the loom 3 pin connector (black, red & brown?) or diconnect bike battery.
It does work on all 03 to 08 exc models and LC4 motors with EXC style display, but you have to start with the display showing running hours, not miles, then press and hold the MODE button till display blinks, cycle through with the MODE button, then when WS blinks you can adjust up/down with + and - buttons, then press MODE again, then press and hold MODE button
I leave my connector undone all the time for quick changes from SM to dirt wheel size. The light does not work, thats all
2003 Honda CB1300
2009 Yamaha XT660Z
2012 Husaberg FE390
Old 04-07-2014, 12:43 PM   #5157
B1
B1's Avatar
Oddometer: 3,386
hate to say it, but i think it's time to start prepping the FE570 to sell it.
a few of us have got into trials lately so have been cross training on the dirt bikes. i had a play on a mate's 300EXC yesterday and it's so much easier to do the trials riding techniques on.
pivot turns are a struggle on the berg, and rear wheel hops are almost impossible but it was a piece of cake on the two stroke.
Old 04-07-2014, 05:26 PM   #5158
just jeff
Oddometer: 1,036
Jeff,
pinevalley
Thanks guys for the replies! I tried it with the fender completely off and the fit issue is definitely the smog subframe. I find it odd there is no mention of this on Safari's website. I thought maybe I got the wrong tank.
Pinevalley,
I was reluctant to start cutting the subframe in case it would compromise the strength. Have you had any issues since you doctored yours? If you could find any pics it would be very appreciated! I don't mind cutting he subframe if it remains strong.
Best Regards to all....justjeff
Old 04-08-2014, 06:50 AM   #5159
woods wizard
woods wizard's Avatar
Oddometer: 838
Great pic....yeah not so easy to muscle the big Swede girl around. I took off my Safari frt tank & swapped out the stock muffler for a SXF one . 2 distinct advantages ,1st is noticeably less engine heat, fan only came on when stopped for a bit. You can touch the can even when the engine is running, not even hot. The weight difference is only 2.5 -3 lbs but feels like a ton . Removing weight up high is always a good thing. Also the engine of course feels much snappier , & does not pop on decal so the EFI is able to deal with the freer flowing exhaust. Win/Win. only drawback ,of course is more noise.
Husaberg 570FE Tagged & Tarded / KTM 250 EXC
woods wizard is offline   Reply With Quote
Old 04-08-2014, 07:24 AM   #5160
pinevalley
pinevalley's Avatar
Oddometer: 101
Pinevalley,
I have not noticed any issues with integrity post trimming. However, if you can find one used like vintage suggested I would go that route. I'll send you a PM with photos if I can find them.
pinevalley
Times are GMT -7.   It's 03:17 AM.
