Old 04-29-2014, 02:47 PM   #5206
rensho
Oddometer: 179
Originally Posted by BK.RD.RNR View Post
What is the deal with the oil drain/ screen combo on my 390.
HB gives torque values for the bolts, but no room for a torque wrench, even my small 1/4" drive.
Anyone found a way to use a socket with extension, or some such combination, on these?
Not that I actually need it, but it would be nice to be able to use a socket instead of a wrench on these.
I use a wobble extension and socket thru the frame and engine gap, from the rear brake side. Agreed, the design on this is silly for no reason.
rensho is offline   Reply With Quote
Old 04-29-2014, 02:53 PM   #5207
CrazyTed
CrazyTed's Avatar
Oddometer: 63
Never found the need to use a torque wrench on them. I use a six point box end to ensure I don't strip them. Then just snug them up, not really tight. They seem to get tighter over time anyhow.
CrazyTed
Virginia Beach, VA
08 Triumph Rocket III
2010 Husaberg FX450 for sale
CrazyTed is offline   Reply With Quote
Old 04-29-2014, 04:31 PM   #5208
bayarearider
Oddometer: 139
Originally Posted by bj4x4 View Post
Anyone know if you can get grafics for the safari tank for the 570?
Sent from my GT-N5110 using Tapatalk
I recently got graphics from OMX for my 570 with a safari front tank and I would say they look real good. I will try to post a pic soon.
bayarearider is offline   Reply With Quote
Old 04-30-2014, 09:53 AM   #5209
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,394
Anyone have a 70deg racing subframe tank they want to sell? Now that I am ready to buy one I found out they are not making them anymore :(
n16ht5 is offline   Reply With Quote
Old 04-30-2014, 09:59 AM   #5210
1 lunger
1 lunger's Avatar
Oddometer: 1,296
I posted this same ad in the flea market a month or two ago and got no answer. If people have them, they don't want to sell them. Good luck!
Life is good!
1 lunger is offline   Reply With Quote
Old 04-30-2014, 10:07 AM   #5211
n16ht5
ride the night
n16ht5's Avatar
Oddometer: 2,394
OK thanks. I can't find any info on sealing up the stock subframe. Who has done it successfully?
Old 04-30-2014, 01:34 PM   #5212
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,402
from memory, someone did post a few years back about how to plug up the subframe and use as a fuel tank but it got taken down after someone had a leak and the bike caught fire? consensus seemed to be far too risky...
B1 is offline   Reply With Quote
Old 04-30-2014, 02:50 PM   #5213
bayarearider
Oddometer: 139
My FE570 with a front safari, sub frame tank & a HDB rally lite kit with Trail Tech Halogen headlight, Scheffelmeier Metall Bash Plate, & a bunch of other goodies that are too many to list.
The graphic template.
Old 04-30-2014, 05:48 PM   #5214
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,310
Nice Hari!
I forgot to ask about the front fender template. I'll be in LV this week, and I'll see if I can get a hold of that...
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 04-30-2014, 06:04 PM   #5215
bayarearider
Oddometer: 139
Originally Posted by GalacticGS View Post
Nice Hari!
No worries. I got that done already. Just too lazy to stick it on the fender.
Old 04-30-2014, 06:22 PM   #5216
mattadv93
mattadv93's Avatar
Oddometer: 221
Nice bike! .... are led front blinkers hard to install on the 570? I remember on my drz400 there were s pain in the ass and I ended up useing the std ones again.
The world is a book and those who do not travel read only one page.
-Husaberg FE570
mattadv93 is offline   Reply With Quote
Old 04-30-2014, 08:35 PM   #5217
Koko
Oddometer: 95
Leds were easy to install on my 390. Previous owner had installed the ktm cev multi function switch. I bought Sicass racing handguards with integrated turn signals. Mounted them to my KTM barkbusters. After that I swapped in a Sicass led flasher http://sicassracing.com/store/produc...signal_flasher
And this:
http://sicassracing.com/store/produc...dicator_wiring
End result works perfect with rear led flushmounts.
Koko is offline   Reply With Quote
Old 05-01-2014, 10:50 AM   #5218
BogeyMan
BogeyMan's Avatar
Oddometer: 451
Damage report...
I've seen the damage... and it's not good
I'll post pics later. EDIT: Pics here
At a minimum, I'm going to need a new head (and all associated parts) - it got REALLY hot and one valve impacted the piston, so that means a new piston too. Also will need a new cam chain & all associated bits. Most of the debris in the oil was from the melted cam chain tensioner & plastic parts. Possibly need a rod - won't know about the bottom end until we can split the case.
Also needed - does anyone know where I can get a primary gear puller and a case/crank puller for the 570 motor? With Husaberg disappearing, these tools seem to be hard to come by.
My mechanic/shop is asking for the primary gear puller and/or crank puller so that he can split the case and check the gears/gearbox to see what (if any) damage the gearbox suffered. With all that melted and shredded plastic debris floating around I don't want to leave some bits to clog up a bearing somewhere and repeat the mess again.
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan screwed with this post 05-01-2014 at 05:27 PM
BogeyMan is offline   Reply With Quote
Old 05-01-2014, 03:05 PM   #5219
rensho
Oddometer: 179
Big bummer Bogeyman. Sorry to see. I'll look around if anyone is selling motor parts.
Old 05-01-2014, 03:43 PM   #5220
mattadv93
mattadv93's Avatar
Oddometer: 221
There was a whole 570 engine for sale in the racing flea market a coupl of weeks back. I think it was somewhere around $3000.
-Husaberg FE570
Times are GMT -7.   It's 05:56 AM.
