Old 05-01-2014, 05:30 PM   #5221
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Husaberg 70 Degree Owners Thread!
Installing a Rekluse clutch slave and in the process of removing the OE slave, the paper gasket got ruined. I'm going to make one from a sheet of gasket paper. It seems a c-hair thicker, but I don't think that should matter. Anyone disagree?
Edit: won't work:( need OE gasket. Very small and my ham fists can't do it
Life is good!
1 lunger screwed with this post 05-01-2014 at 06:14 PM
1 lunger is offline   Reply With Quote
Old 05-02-2014, 12:33 PM   #5222
BogeyMan
BogeyMan's Avatar
Oddometer: 447
Originally Posted by BogeyMan View Post
I've seen the damage... and it's not good
I'll post pics later. EDIT: Pics here
At a minimum, I'm going to need a new head (and all associated parts) - it got REALLY hot and one valve impacted the piston, so that means a new piston too. Also will need a new cam chain & all associated bits. Most of the debris in the oil was from the melted cam chain tensioner & plastic parts. Possibly need a rod - won't know about the bottom end until we can split the case.
Also needed - does anyone know where I can get a primary gear puller and a case/crank puller for the 570 motor? With Husaberg disappearing, these tools seem to be hard to come by.
My mechanic/shop is asking for the primary gear puller and/or crank puller so that he can split the case and check the gears/gearbox to see what (if any) damage the gearbox suffered. With all that melted and shredded plastic debris floating around I don't want to leave some bits to clog up a bearing somewhere and repeat the mess again.
Got some info on the primary gear extractor over on husaberg.org. But I'll ask the same question here - anyone know of a source for a used (or even new for that matter) 570 engine?
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 05-02-2014, 03:20 PM   #5223
bayarearider
Oddometer: 135
Contact Cyclebuy. I usually get all my spare parts from them.
http://www.cyclebuy.com/husaberg/parts.htm
bayarearider screwed with this post 05-02-2014 at 03:44 PM
bayarearider is online now   Reply With Quote
Old 05-02-2014, 03:20 PM   #5224
Knobbiethrower
ADV in ADK
Knobbiethrower's Avatar
Oddometer: 1,266
Originally Posted by bayarearider View Post
My FE570 with a front safari, sub frame tank & a HDB rally lite kit with Trail Tech Halogen headlight, Scheffelmeier Metall Bash Plate, & a bunch of other goodies that are too many to list.
The graphic template.
How horrible was the front safari install?
Knobbiethrower is offline   Reply With Quote
Old 05-02-2014, 04:00 PM   #5225
bayarearider
Oddometer: 135
It was horrible to begin with. But after reading the problems posted by riders in this thread and on Husaberg.org, my mechanic was able to sort the installation issues and he did a good job. The issues are mainly due to the cross brace at the bottom not lining up with the holes at the bottom of the tank on either side and also the filler adaptor is too big ( by about 1mm) to fit in the OEM tank filler hole. So it needs to be grinded. For the cross brace I just took it to a mufler shop and gave them a small template and had them weld an additional piece of metal on either side to extend it to line up with the holes. Because I had the sub frame tank which comes with a aluminum fuel pump housing I used that to drill an additional spigot and plumb all 3 tanks. This was the hardest part as we realized this was the best way to go a little too late. Initially we used brass compression fittings to plumb all 3 tanks but that was taking up too much space and causing the hoses to kink. Simply drilling an additional spigot resolved the issue and we used quick disconnects in all possible locations to quickly disconnect the tanks.
Having done all that and after spending a lot of money on man hours, I can say that I am happy with the final finish. I have a 5+ gallon range and the weight of the fuel is evenly distributed and sits low and doesnt interfere with the riding position.
Old 05-02-2014, 06:08 PM   #5226
Knobbiethrower
ADV in ADK
Oddometer: 1,266
Thanks for sharing. I'm toying around with idea of doing the same on my own. What do mean by "drilling an extra spigot" ? You modified the base of the safari tank to allow another point of fuel to be drawn from?
Knobbiethrower screwed with this post 05-02-2014 at 06:16 PM
Old 05-02-2014, 06:35 PM   #5227
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Anyone have a JD tuner on their 570 ? Where do I find the plug to plug in the tuner?
Life is good!
Old 05-04-2014, 10:47 AM   #5228
Koko
Oddometer: 89
Finally popped my Hymenburg!
First real ride on my Berg this morning. 32.5 miles. Here's a couple of short vids.
Troy & Koko: http://youtu.be/s_HtOcX_JTg
Troy & Koko prt2: http://youtu.be/81-1ERLemMw
Koko screwed with this post 05-04-2014 at 06:34 PM
Koko is offline   Reply With Quote
Old 05-04-2014, 12:45 PM   #5229
1 lunger
1 lunger's Avatar
Oddometer: 1,253
Cranked my rear brake foot lever on some low cut trees today. Will a Ktm lever fit the 2011 Berg 570? Or a link to aftermarket lever would be cool. Thanks!
Life is good!
Old 05-04-2014, 01:30 PM   #5230
dirtyoffroad
dirtyoffroad's Avatar
Oddometer: 536
Life is good!
instructions say black connector for the fi throttle body.I'm interested in the results if anyone has done this.
07 Honda XR 650R
11 BMW R1200GSA
dirtyoffroad is offline   Reply With Quote
Old 05-05-2014, 01:10 AM   #5231
mattadv93
mattadv93's Avatar
Oddometer: 205
I be installing one next weekend. I report back how it goes
Sent from my GT-N5110 using Tapatalk
The world is a book and those who do not travel read only one page.
-Husaberg FE570
mattadv93 is offline   Reply With Quote
Old 05-05-2014, 05:10 AM   #5232
Knobbiethrower
ADV in ADK
Oddometer: 1,266
Thanks much
2013 KTM 990 Baja
2011 Husaberg FE 570
Old 05-05-2014, 05:58 AM   #5233
galbo950
galbo950's Avatar
Oddometer: 575
I have the front Safari Tank, first time fitment probably took an hour at the most. The fit for mine was straight forward. Prior to installation I was advised by Safari Tanks to follow the instructions to the letter and if I did I wouldn't have any issues, they were 99% correct. the only issue I faced was that the template used to mark the fuel pump housing prior to drilling was 1 or 2mm out, no real issue though as it just required some shaving of the plastic fuel pump housing with a Stanley knife (if your using the alloy 70 degree fuel pump housing you won't have to worry about it). Now it probably takes a maximum of 20 minutes to remove or install the tank.
Thanks much
galbo950 is offline   Reply With Quote
Old 05-05-2014, 02:21 PM   #5234
galbo950
galbo950's Avatar
Oddometer: 575
Caltex (Chevron) Delo 400
Ok I've tried searching and had no luck, can anyone tell me which Delo 400 is the one to use in the Berg. After searching for Delo 400 there appears to be several varieties. Any help would be appreciated.
Old 05-05-2014, 02:32 PM   #5235
bayarearider
Oddometer: 135
The safari tank install has issues only with FE570 ( street version) USA version bikes. There are so many posts on this thread from the members who had issues.
Times are GMT -7.   It's 05:06 PM.
