Old 05-05-2014, 02:33 PM   #5236
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
Originally Posted by bayarearider View Post
The safari tank install has issues only with FE570 ( street version) USA version bikes. There are so many posts on this thread from the members who had issues.
The rear goes on nicely though
Seth S
Seth S is offline   Reply With Quote
Old 05-05-2014, 04:23 PM   #5237
johnno950
Oddometer: 1,049
Originally Posted by galbo950 View Post
Ok I've tried searching and had no luck, can anyone tell me which Delo 400 is the one to use in the Berg. After searching for Delo 400 there appears to be several varieties. Any help would be appreciated.
Give outbackbiker a pm,sure he runs delo400 in his 570 berg.
johnno950 is offline   Reply With Quote
Old 05-05-2014, 10:17 PM   #5238
Koko
Oddometer: 89
So what do people use for rear "Tugger" straps? After yesterdays ride I can see the need for one. I've also searched and agree the sheet rock like screws that go into the sub frame are certainly not strong enough.
How about using a dog collar that just loops under the rear seat through the grab handle pass through. I was thinking this would be an easy solution.
Thoughts?
Koko is offline   Reply With Quote
Old 05-06-2014, 12:21 PM   #5239
Seth S
Seth S's Avatar
Oddometer: 4,474
thinking of switching to .48 springs in the forks and either 8.8 or 8.4 spring on the rear shock. 210 lb rider before gear...likely running a rear safari tank off and on...sound about right?...research and searches seem to point in this direction.
Seth S
Old 05-06-2014, 08:57 PM   #5240
SoilSampleDave
Oddometer: 1,911
Is it my imagination or is the motorcycle visible on the trailer on the web page for the upcoming Chevy Colorado a 70 degree Berg?
http://www.chevrolet.com/2015-colorado-small-truck.html
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is offline   Reply With Quote
Old 05-06-2014, 08:59 PM   #5241
Koko
Oddometer: 89
I think you are correct. Looks that way to me. Nice catch!
Old 05-06-2014, 09:02 PM   #5242
just jeff
Oddometer: 941
Absolutely! The blue anodized rims are a dead giveaway!!
Good eye!
jj
ErikMotoMan: "People struggle with many things in their lives. But the answer to struggle isn’t MORE struggle. It’s peace. If you want more joy, peace, love, happiness… you have to GIVE those things first. You have to THINK those things. You have to have faith that they’ll come to you, despite what you may see. The truth isn’t in what you see with your eyes. It’s what you feel in your heart."
just jeff is offline   Reply With Quote
Old 05-06-2014, 09:03 PM   #5243
mattadv93
mattadv93's Avatar
Oddometer: 206
Yeah you can see the plastic subframe
The world is a book and those who do not travel read only one page.
-Husaberg FE570
mattadv93 is offline   Reply With Quote
Old 05-06-2014, 09:12 PM   #5244
SoilSampleDave
Oddometer: 1,911
At least someone on Chevy's ad team has good taste! They are adding them to our company car program in the fall so I was sneaking a peek.
'14 690R
Old 05-07-2014, 06:51 AM   #5245
jwdub
Oddometer: 663
KOKO,
I'm not sure I'd want to use the strap under the seat idea if all of the stress is going to be placed on the seat release mechanism. I recently bought a FE450 that has a lift strap using the 5mm or so bolts on the rear subframe (mine has the 70* racing subframe tank) However, the strap ends are anchored at the bottom of the fender, not under the bolt heads at the top. This places most of the stress in shear, and it uses large washers to spread the load as well.
jwdub screwed with this post 05-07-2014 at 07:11 AM
jwdub is offline   Reply With Quote
Old 05-07-2014, 06:57 AM   #5246
Koko
Oddometer: 89
Thanks jwdub, Could you take a picture of the underside so I could see the mounting?
Old 05-07-2014, 07:47 AM   #5247
jwdub
Oddometer: 663
Koko,
I've got the rear dismantled at the moment to install turn signals. I discovered that the battery box mount tab had broken so I'm waiting to put things back together until I get my 3M 8005 structural adhesive order in at the end of this week. In the meantime, I'll see if I can lay the pieces out so you can see what it looks like. It may be this evening before I can get to it.
I just found the exact item at Cycle Buy -- here's the link with pictures. http://www.cyclebuy.com/shopping/tug...#Larger_Images
Currently on sale for $19.95 or, there's one from Moose Racing at $24.95.
John
jwdub screwed with this post 05-07-2014 at 07:59 AM
Old 05-07-2014, 08:06 AM   #5248
jwdub
Oddometer: 663
Front fork compression stack Mods?
I bought my '10 FE450 in Arizona recently. After playing around with the adjustments available, I still find the front fork harsh on the rocky trails I ride there. Even with the compression damping zeroed. Now that I'm back in the PNW, are there any suspension specialists in the Portland - Seattle area that anyone could recommend?
TIA
John
Old 05-07-2014, 11:10 AM   #5249
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,741
I have rear subframe tank and at 220 rider weight the 8.6 is just barely enough from my measurements and riding assessment. I think I ended up with .48 in front but maybe .50, can't find my notes on the forks
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 05-07-2014, 12:03 PM   #5250
Koko
Oddometer: 89
Originally Posted by jwdub View Post
Koko,
John
Thanks John. Those are the straps I was looking at. I just don't see how to mount it securely on the subframe. Especially the left side.
Times are GMT -7.   It's 09:22 AM.
