Old 05-07-2014, 07:47 AM   #5251
jwdub
Oddometer: 621
Koko,
I've got the rear dismantled at the moment to install turn signals. I discovered that the battery box mount tab had broken so I'm waiting to put things back together until I get my 3M 8005 structural adhesive order in at the end of this week. In the meantime, I'll see if I can lay the pieces out so you can see what it looks like. It may be this evening before I can get to it.
I just found the exact item at Cycle Buy -- here's the link with pictures. http://www.cyclebuy.com/shopping/tug...#Larger_Images
Currently on sale for $19.95 or, there's one from Moose Racing at $24.95.
John
jwdub screwed with this post 05-07-2014 at 07:59 AM
jwdub is offline   Reply With Quote
Old 05-07-2014, 08:06 AM   #5252
jwdub
Oddometer: 621
Front fork compression stack Mods?
I bought my '10 FE450 in Arizona recently. After playing around with the adjustments available, I still find the front fork harsh on the rocky trails I ride there. Even with the compression damping zeroed. Now that I'm back in the PNW, are there any suspension specialists in the Portland - Seattle area that anyone could recommend?
TIA
John
Old 05-07-2014, 11:10 AM   #5253
Some Dude
what attitude problem???
Some Dude's Avatar
Oddometer: 4,732
Originally Posted by Seth S View Post
thinking of switching to .48 springs in the forks and either 8.8 or 8.4 spring on the rear shock. 210 lb rider before gear...likely running a rear safari tank off and on...sound about right?...research and searches seem to point in this direction.
I have rear subframe tank and at 220 rider weight the 8.6 is just barely enough from my measurements and riding assessment. I think I ended up with .48 in front but maybe .50, can't find my notes on the forks
Just some dude on the internet,..
Some Dude is offline   Reply With Quote
Old 05-07-2014, 12:03 PM   #5254
Koko
Oddometer: 89
Originally Posted by jwdub View Post
Koko,
John
Thanks John. Those are the straps I was looking at. I just don't see how to mount it securely on the subframe. Especially the left side.
Koko is offline   Reply With Quote
Old 05-07-2014, 02:08 PM   #5255
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,734
TIA
John
i'll bet you have the stiffer springs in the fork (and then probably shock). what color is your shock spring? if it's not yellow then you might have something else in it.
once i got mine back to stock weight springs it's super plush, took some playing with spring preload but now it rides like a cadillac even when attacking 2' deep whoops in JV.
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Old 05-07-2014, 02:11 PM   #5256
vintagespeed
fNg
Oddometer: 1,734
maybe loop the ends of the strap around the horns of the subframe ahead of the fender bolt to keep the strap from sliding.
Old 05-08-2014, 01:26 AM   #5257
frostyuk
frostyuk's Avatar
Oddometer: 271
i use the kriega haul loops, the rear one is looped around the handgrips under the seat on both sides, doesnt interfere with the seat coming off or the seat release
Mine's a 70Degree Berg 09 FE450
"Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take
away"
- Antoine de Saint-Exupery (1900-1944)
frostyuk is offline   Reply With Quote
Old 05-08-2014, 01:32 AM   #5258
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 217
I am using 8.8NM with rear Safari tank on it (190lbs rider) this give me the right sag.
Kept the .44 in front though.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 05-08-2014, 04:23 AM   #5259
galbo950
galbo950's Avatar
Oddometer: 575
Injector cleaner / removal
Having a hot start issue with the 570 and it appears it may be caused by a dirty / dripping injector. The question is do fuel injector cleaners work or am I better off removing it and having it cleaned properly? With regards to removal is there anything I should be aware of? I've got the fuel tank off at the moment and after having a look at it, it appears I need to remove the rubber airfilter housing from the throttle body to access the 2 screws on the top of the fuel rail. Then it looks like I just remove the 2 screws and the injector should just pull out from the throttle body. Does that sound about right? Last thing, how tight of a fit is the breather hose that goes on top of the valve cover meant to be? My hose isn't a tight snug fit as I can slide it off without any issue. Any info would be great.
galbo950 is online now   Reply With Quote
Old 05-09-2014, 06:30 AM   #5260
SCExpat
SCExpat's Avatar
Oddometer: 635
I have had real good luck with Sea Foam. Bought a 1999 Moto Guzzi that the owner was not riding so it had sat for over a year without any gas stabilizer. It ran really rough but a can of Sea Foam split between 3 tanks of gas cleaned it right up. Cheap and easy to do. If it doesn't work you can always send the injector to be cleaned. Good luck.
SCExpat is offline   Reply With Quote
Old 05-09-2014, 07:15 AM   #5261
bkowal
Oddometer: 246
Injector cleaner probably won't work. You need to remove the injector, use a 9V battery to open the injector, and spray cleaner through it. I made a little jig with bits of hose.
I had problems when the bike got hot as well. It turns out it was the KTM inline fuel filter. There is a little plastic screen just before the injector. When it got hot it would swell slightly, blocking fuel flow. Removing it was the answer.
bkowal is offline   Reply With Quote
Old 05-09-2014, 08:35 AM   #5262
jwdub
Oddometer: 621
Vintagespeed,
The rear shock spring is yellow. I haven't checked the fork springs yet, or the fluid level -- I saw a post that the '10 FE570 was 110mm down from the top, no springs, compressed. I assume that it would be the same for the '10 FE450. I couldn't find a reference in the owners manual for the mm measurement.
FWIW, I just looked at my suspension notes again:
Fork: CD = 28; RD = 18; Preload = 0
Shock: HSCD = 2 turns; LSCD = 24; RD = 23; Preload = haven't measured
Old 05-09-2014, 10:17 AM   #5263
vintagespeed
fNg
Oddometer: 1,734
...Fork: CD = 28; RD = 18; Preload = 0
yeah, maybe you're just too light for the springs? when you're not in the right weight range for your springs the clickers will do little for you. and if your race sag & rear preload aren't set properly first, the front will feel 'wrong'.
Old 05-09-2014, 04:59 PM   #5264
rensho
Oddometer: 167
Vintagespeed,
Can't just go by color. You can get springs for WP shocks in white, yellow and orange. The spring should have numbers on it, eg, 72/250(my stock 2011 FE570).
Any of the linear springs should be 250-260mm.
http://slavensracing.com/product-cat...shock-springs/
rensho is offline   Reply With Quote
Old 05-09-2014, 07:25 PM   #5265
jwdub
Oddometer: 621
Uh, I doubt if I'm too light -- more like 230# ready to ride and 69, so I'm not exactly doing moto cross through the whoop de doos. I have been riding in the dirt for many of the 53 years I've been riding, just older and slower now and still having fun . I just need to get with the program and take the shock out and pull the fork springs to see where I'm at.
Thanks for the Slaven's Racing link, Rensho.
Update: The rear spring is a 72/250 so, 7.2 Kg/250mm long. Looks like I should be up around 8.0 Kg, but I want plush so I'd rather be slightly under, say 7.8 Kg. That should transfer more weight to the front.
jwdub screwed with this post 05-10-2014 at 11:34 AM
Times are GMT -7.   It's 05:12 AM.
