Old 11-24-2010, 11:50 AM   #1
B.Curvin OP
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,730
Buell engine rebuild advice, or
always look on the bright side of life?
Maybe it's a good thing the previous owner was ham fisted. I started changing out
the exhaust studs etc as recommended in my other Buell thread. The PO had insisted
on repairing an exhaust leak before we traded bikes. I said leave it alone but
he did it anyway. I found the front cylinder exhaust studs were finger tight.
The rear cylinder only had a nut on one stud and the stud without a nut was
cross threaded. I pulled the head off to get better access to the stud and found this.
Scratches can be felt with a fingernail in the band the red arrow points to.
The piston
The different colors are not a reflection.
So, do I need to strip it all the way down and hone the cylinders and install new pistons?
Mutt'n the custard.
Porsche Audi VW
B.Curvin is offline   Reply With Quote
Old 11-24-2010, 12:40 PM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 55,973
Nothing here, let's move this to The Garage.
Old 11-24-2010, 12:47 PM   #3
Tosh Togo
Oddometer: 1,594
By the look of those scratches, it more likely will be next oversize. Honing enough to make them go away will probably have the original pistons trying to go sideways with all the extra elbow room. Take both jugs to a machine shop (NOT the dealer!) and see how much they think will need to be taken off to start over.
Pics help, but a machinist with the part in hand is better.
Let's say you your friendly neighborhood machinist miraculously makes things like new again with only .003" material removal.
That's not three thou bigger, it's that much gone from each side of the cylinder.
With that much unhappiness upstairs, you should also have a good look at the bottom end while you're that far into it.
If that shows more problems, a better/cheaper answer would be to find another complete engine.
Or button it back up and sell it.
Tosh Togo is offline   Reply With Quote
Old 11-24-2010, 01:15 PM   #4
B.Curvin OP
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,730
Originally Posted by Tosh Togo
(NOT the dealer!)
No worries there. I never taken anything to a dealer.
I've got a local cylinder/head guy that is top notch. Reeves in Asheville.
I figured I'd be going up a size. I'll get Reeves input then grab a set of Wisecos.
Mutt'n the custard.
Porsche Audi VW
Old 11-24-2010, 01:18 PM   #5
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,634
90 cubic inches.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 11-24-2010, 01:42 PM   #6
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 11,240
fear not -- Tuber motors were ridden in ways Milwaukee never dreamed of, and you can see wear like that in the cylinders all day long without having any appreciable wear in the lower end of the mill.
1250 kits are reasonable, and you get new pistons and cylinders . . . . . no more work to put together than reassemebling what you've got.
but, yeah your cylinders/pistons need attention -- maybe valve guides/seal, as well.
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 11-24-2010, 02:02 PM   #7
Bobthebiker
not normal
Oddometer: 493
did the PO run it with low oil or someting? or no air filter? those are some NASTY scoring marks in that cylinder, with what looks like oil buildup on the piston.
personally, I'd go for new jugs and pistons, along with redoing the heads.
Where does this road go? screw your maps! we're gonna find out the FUN way!
error 404: common sense not found.
Bobthebiker is offline   Reply With Quote
Old 11-24-2010, 06:55 PM   #8
fatboy
Oddometer: 308
Seriously? The answer is that you measure it and make decisions based on the data. If you are not sure how then take it to a machine shop and ask them to do it. Work with the facts.
fatboy is offline   Reply With Quote
Old 11-24-2010, 07:16 PM   #9
B.Curvin OP
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,730
Mutt'n the custard.
Porsche Audi VW
Old 11-24-2010, 07:43 PM   #10
RJW
Oddometer: 57
Good info on sportster v twins here - www.nrhsperformance.com
the rear cyl always runs hot - nature of the beast
RJW is offline   Reply With Quote
Old 11-24-2010, 09:02 PM   #11
ian03xl
ian03xl's Avatar
Oddometer: 160
This company is an excelent source for sportster and buell engines. I've used their 1250 kit amazing products and customer service is top notch. Talk to Dan he can set you up with a rebore or anything you may want to do.
ian03xl is offline   Reply With Quote
Old 11-24-2010, 09:29 PM   #12
B.Curvin OP
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,730
Thanks for the tips. I had already spoken with NRHS earlier today. I was
quiet disappointed when I found out their cylinders are cast in china. I'm going to
go with Wiseco pistons and have my local guy rebore my stock cylinders
and possibly redo the heads.
Mutt'n the custard.
Porsche Audi VW
Old 11-24-2010, 10:50 PM   #13
RJW
Oddometer: 57
make sure they use torque plates when boring cylinders, otherwise they'll be out of round when installed and heads torqued down
Old 11-25-2010, 05:14 AM   #14
B.Curvin OP
Feral Chia tamer
B.Curvin's Avatar
Oddometer: 2,730
Thank you thank you for that. I've read that torque plates must be used with Harley
cylinders in American Iron and such but had not thought about it since I rarely
(never before actually) work on Harleys. I'm sure Reeves knows this and has them, or would
send me to someone that does but it's nice to have the info so I know to ask.
Mutt'n the custard.
Porsche Audi VW
Old 11-25-2010, 07:00 AM   #15
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,408
This. Hard to judge the scoring from the image, the cross hatch honing pattern is still visible all the way up to and between the scoring. I'd offer an overheating event (like stuck in traffic) was the culprit. It wasn't normal wear, as witnessed by the cross hatch still being visible.
Times are GMT -7.   It's 04:09 AM.
