Old 01-27-2012, 07:11 PM   #151
schultzy
schultzy's Avatar
Oddometer: 156
No problems getting parts so far....... I plan on a top end rebuild next month, that might be a problem. Dan at MotoXotica has been very good with what I need so far.
schultzy is online now   Reply With Quote
Old 01-28-2012, 12:02 AM   #152
Bushmechanic
Bushmechanic's Avatar
Oddometer: 73
Hello Husaberglers
you guys have some nice bikes there, I particularly like the 501s
fwiw there are some more pics of husabergs here (some are pre 09s)
http://www.husaberg.org/forum/viewtopic.php?f=1&t=15189
heres a pic of my "700", link to the build in my signature,
have a great Weekend,
cheers
Bushie
2008 Husaberg 700F 104kgs all fluids no fuel
frame build http://www.husaberg.org/forum/viewtopic.php?f=8&t=13268
engine http://www.husaberg.org/forum/viewtopic.php?f=5&t=12131
Bushmechanic screwed with this post 01-28-2012 at 12:37 AM
Bushmechanic is offline   Reply With Quote
Old 01-28-2012, 01:37 AM   #153
Huskyfatman
Huskyfatman's Avatar
Oddometer: 1,539
Originally Posted by Idle View Post
I'm using ww also. I've never heard that before, but I'll flush it out and skip the water wetter
Great looking SM Idle!
I've used WW for years with no problems, only on bikes that had overheating issues, and I mix just a little bit with straight distilled water. (My bikes never get near freezing temps)
I actually think the rad cap cured my Berg from boiling over, but I covered a few bases. I have a complete electric fan set up for it, but don't think it will be needed, or removing the thermostat as recomended.
On my bikes that ran hot, KTM 520sx and a WR250 2 stroke with an Ohlins 360 big bore kit, 95% distilled water and 5% WW eliminated boiling over and the Yamaha actually ran super cool for many years with no issues.
http://www.sharetrails.org/
http://www.americansandassociation.org/
"YOU KNOW. . . . . .WE ARE LIVING IN A HEAT LAMP SOCIETY!"-Ron Perez 2002
Huskyfatman is offline   Reply With Quote
Old 01-28-2012, 05:52 AM   #154
brucifer OP
brucifer's Avatar
Oddometer: 2,526
Originally Posted by Bushmechanic View Post
Hello Husaberglers
cheers
Bushie
Hi Bushmechanic! Good to see you here.
I'm always interested in your builds and sage advice over at husaberg.org.
Thanks for stopping by.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-28-2012, 06:08 AM   #155
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Good to see people keeping this thread on the first page.
Those 70 degree guys get all the love.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 01-28-2012, 06:43 AM   #156
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,743
I'm using ww also. I've never heard that before, but I'll flush it out and skip the water wetter.
New bike with Redline WW, pic of the Teflon just being eaten away.
I replaced the bearing with Orangebergs kit to prevent the classic weep hole leak, it never gave me a problem. Not sure where to find this kit now but certainly a must mod.
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 01-28-2012, 06:54 AM   #157
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
I wonder if theres a KTM part cross over.Like a 400 RFS,,,famus water pump problems.
Thumper racing will have a good water pump rebuild kit,,,,for a KTM.
Old 01-28-2012, 03:03 PM   #158
Bushmechanic
Oddometer: 73
no worries Bruce!
FWIW my pump cover looks like that too, paint started coming off at about 100 hours, I don't use water wetter
I broke my orangeberg water pump seal kit im good at testing stuff
the first ones had a very small bearing (1.2KN rating) to replace an 8.2KN one
John has updated the kit to a bigger bearing, he's great to do business with and a tops aussie stand up Bloke, was already working on a bigger bearing when I let him know mine broke.
for contact details see last post here http://husaberg.org/forum/viewtopic....12518&start=30
I don't think there is any cause for concern if you have the small bearing kit, Im really really hard on my bike.
the kit is for the oil side, the best seal for the water side is from a ktm65sx its a wee blue trinket, very nice and soft. the oem seal has a steel outer.
KTM 65 water seal #PN is 46035056100 SHAFT SEAL RING 10X18X4 or you can use a 10x18x6 from a bearing shop its a tight fit but it moves the seal lip along the shaft a bit.
I put a shim under the impeller cir clip and made a new pin out of a drill to tighten up the impeller
ive also tapped the weep hole with a 3mm thread and take some 3mm screws for long rides. if one seal fails (happened once) I can plug the hole.
also just FWIW I've never had my bike overheat and sometimes I ride in 40 degree + (celcious) heat. the only time Im concerned about it is going slow 1st 2cnd gear etc so i make sure the pilot and idle are a tad rich. a bit of extra fuel is lighter than a fan and a battery
Old 01-30-2012, 11:19 AM   #159
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
So,,whats everyone using for chain guides and chain sliders?
For some reason i can find any for my 08 450.
Or whats the cross over number from a KTM model?
Old 01-30-2012, 02:14 PM   #160
Idle
Oddometer: 719
KTM 625 and 640 are right side drive, maybe the bolt holes line up.(for the rear guard)
Here's mine. I robbed it from my FE550. I needed a full guard in back to keep the chain off the tire. It doesent have a # or a name on it, so can't help you there.
The chain slider is a Husaberg part. I got one from Motoxotica a couplefew months ago.
Idle is offline   Reply With Quote
Old 01-30-2012, 02:30 PM   #161
Idle
Oddometer: 719
[/QUOTE]
Bushie, are you tearing up your fancy Kevlar/glass fuel tanks?
Old 01-30-2012, 03:07 PM   #162
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
The chain guide looks like a 07-up KTM.
If i can get 5 minutes i'll pull the TM designs off my XCW and see if it lines up.I'm more worry'd bout the chain slide,,,its beat bad,and has to be replaced.Front sproket will touch the swing arm on a good bump.
PO had the sdjuster blocks in backwards with a new chain,and had maybe half inch of play in the chain.Luckly it didn't pop and output shaft.
Old 01-30-2012, 04:03 PM   #163
tobyremington
Oddometer: 30
awm
why dont you ask these guys why you cant get fliud to go through your clutch line? Does it have to be pushed from bottom or pulled down thru top? There has to be a trick.I seemed like it worked fine till it ran out of fluid now it does not want to refill.
tobyremington is offline   Reply With Quote
Old 01-30-2012, 04:28 PM   #164
tomatoe333
tomatoe333's Avatar
Oddometer: 2,298
Fill it from the bleeder on the slave cylinder with a syringe and a short section of hose. I have a couple of LARGE hypodermic needles that I got from the local Agway that I removed the sharp tips from. They work well for that.
And AWM, I'll take responsibility for the chain being too tight. The chain slide was like that when I bought it, probably thanks to the 15-tooth front sprocket that was on it then.
"Keep the standard settings will be useful to learn more about the bike. One should reach a sufficient technical level, when then humbly questioning calibration of your motorcycles."
tomatoe333 is offline   Reply With Quote
Old 01-30-2012, 04:32 PM   #165
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Not bitch'n old pal,,just try'n to figure some stuff out.I knew you'd be watching.
Times are GMT -7.   It's 05:07 AM.
